Unbound unbound_manager (Manager/Installer utility for unbound - Recursive DNS Server)
Only Adblock/Unbound. Here it works fine.
sh /jffs/scripts/unbound/gen_adblock.sh
Removing possible temporary files...
Get hosts list ...
################################################################################################################################################## 100.0%
Get domains list ...
Combining User Custom block host...
69447 domains compiled
Edit User Custon list of allowed domains...
Removing duplicate formatting from the domain list...
Generating Unbound adlist.....
65922 suspicious and blocked domains
Removing temporary files...
Run gen_unbound...
Removing unbound.conf files..
Removing log's files...
Restarting services...
 Shutting down unbound...              done.
 Starting unbound...              done.
 Shutting down haveged...              done.
 Starting haveged...              done.
 Shutting down suricata...              done.
 Starting suricata...              done.
 Shutting down clamav...              done.
 Starting clamav...              done.
Checking status services...
 Checking haveged...              alive.
 Checking unbound...              alive.
 Checking suricata...              alive.
 Checking clamav...              alive.
Checking unbound.conf...
unbound-checkconf: no errors in /opt/var/lib/unbound/unbound.conf
What is the output? How do you know it didn’t do both?
Why include the second? That file is already merged into the first.
I made some adjustments and cleaning. With support 127.0.0.1. It became more objective and efficient. Study and adapt.
tempoutlist="/opt/var/lib/unbound/adblock/adlist.tmp"
outlist='/opt/var/lib/unbound/adblock/tmp.host'
finalist='/opt/var/lib/unbound/adblock/tmp.finalhost'
permlist='/opt/var/lib/unbound/adblock/permlist'
adlist='/opt/var/lib/unbound/adblock/adservers'
blockhost='/opt/var/lib/unbound/adblock/blockhost'
echo "Get hosts list ..."
curl --progress-bar $hosts | awk  -F'[\\\\|\\\\^| \t]+' -v RS='\r|\n' '{if (($0 ~ /^\|\|.*\^$/ || $1 ~ /^0.0.0.0|127.0.0.1/) && $2 ~ /.*\.[a-z].*/)  printf "%s\n",tolower($2) }' | uniq | sort -f >> $tempoutlist
echo "Get domains list ..."
curl --progress-bar $domains >> $tempoutlist
echo "Combining User Custom block host..."
cat $blockhost >> $tempoutlist
numberOfAdsBlocked=$(cat $tempoutlist | wc -l | sed 's/^[ \t]*//')
echo "$numberOfAdsBlocked domains compiled"
echo "Edit User Custon list of allowed domains..."
awk 'NR==FNR{a[$0];next} !($0 in a) {print $NF}' $permlist $tempoutlist > $outlist
echo "Removing duplicate formatting from the domain list..."
cat $outlist | tr A-Z a-z | sort -u  > $finalist
echo "Generating Unbound adlist....."
awk '{print "local-zone: \""$1"\" always_nxdomain"}' $finalist > $adlist
numberOfAdsBlocked=$(cat $adlist | wc -l | sed 's/^[ \t]*//')
echo "$numberOfAdsBlocked suspicious and blocked domains"
It was just for testing. As for verification, you can see during the execution of gen_adblock.sh what is downloaded and later you can verify checking the stats file to see the count.
2 dumb questions;
1) I've disabled logging but that setting does not survive a reboot. Is this expected behavior and is there a way to keep the selected setting persistent?
2) After enabling @juched webUI, the "sgui" option does not appear in UM (Unbound Manager). Again, expected behavior? If it is, may I suggest leaving the "sgui" option available so that updates are simpler?
Thank you!
2 dumb questions;
Thank you!
[mention]Martineau [/mention] is best to answer these. For me logging stays disabled. You may want to try doing the I command again and answering the questions and for the last one allow it to replace your conf file and then see if the logging issue stays.
About the sgui command, you should always be able to just type it and it will redownload and install again even if the command isn’t shown on the screen. Easy way to update.
I’ve tried that a couple of times and it still turns back on. Hmmm. Guess it’s just me then. Can’t investigate much more at the moment lest the wife kills me for messing around with “a working internet” while she’s home. Will troubleshoot later and see if I can narrow this down.
Thank you.
Thank you.
Time they all realised It’s OUR router and it’s at our discretion that they’re allowed to browse the Internet.
2 dumb questions
Given the documented performance hit, logging should be OFF by default in 'unbound.conf', and the 'lo' ENABLE logging command is dynamic/temporary, which means a 'rs' or REBOOT should revert logging to OFF.
P.S. You can check 'unbound.conf' after a REBOOT using the 'v' command and examine the logging section and the three physical logging directives should be commented out.
I wanted to have the context menu reflect the current state of the available/installed features, and having added the frivolous 'sgui' URL, this alone should be enough to indicate that there is no point for the 'sgui - Install' option to be displayed to confuse users.
NOTE: I was going to re-add 'sgui uninstall' only when '3 - Advanced Tools' was displayed, but got bored i.e. why would you ever want to remove the excellent GUI statistics chart display? ;)
Anyway, as has been mentioned in several posts, most if not all of the commands (even if not shown in the menu's) are normally always available, so in the case of @juched's script, I don't track its .md5, so would rely on @juched posting the availability of a new release and to inform users to simply issue 'sgui' to manually retrieve/install the new version.
i am getting this error when trying to enable unbound:
@Milan what command did you issue immediately above what your screenshot shows? :)
Can you backup the corrupt 'unbound.conf'
e  = Exit Script
A:Option ==> vb
 Active 'unbound.conf' backed up to '/opt/share/unbound/configs/2020mmdd-hhmmss_unbound.conf'
then reset 'unbound.conf'
e  = Exit Script
A:Option ==> rl reset
If you upload the corrupt file to say Pastebin or post in the thread I will try and understand/identify how/why the file is corrupt.
here it is
# rgnldo Github Version=v1.07 Martineau update (Date Loaded by unbound_manager Wed Mar 11 18:23:35 CET 2020)
# v1.07 Martineau - Add     'control-use-cert:' "Fast Menu" template
# v1.06 Martineau - Add     'extended-statistics:' template
# v1.05 Martineau - Add     'DNS-Over-TLS support' & 'so-rcvbuf:' templates
#                   Remove  'prefetch:' & 'prefetch-key:' duplicates - Thanks @Safemode
# v1.04 Martineau - Change  'ip-ratelimit:'
# v1.03 Martineau - Remove  'dns64-prefix:' and 'module-config: "dns64 ..."' from auto ENABLE if IPv6 detected
# v1.02 Martineau - Add     '#use-syslog:' '#log-local-actions:' '#log-tag-queryreply:' Option placeholders
# v1.01 Martineau - Add     'auth-zone:', 'edns-buffer-size:' log-time-ascii: 'log-servfail:' IPv6 'dns64-prefix:' and 'module-config: "dns64 ..."'
#                   Change  'interface: 0.0.0.0' to 'interface: 127.0.0.1@53535'
#                   Add     If IPv6 detected, auto ENABLE 'dns64-prefix:' and modify to include 'module-config: "dns64 ..."'
server:
# port to answer queries from
port: 53535
# integration LOG's
verbosity: 1                               # v1.02 '1' is adequate to prove unbound is processing domains
logfile: "/opt/var/lib/unbound/unbound.log" # v1.01 as per @dave14305 minimal config
log-time-ascii: yes                         # v1.01 as per @dave14305 minimal config
log-tag-queryreply: yes                    # v1.02 @Martineau Explicitly Tag log-queries/replies with 'query'/'reply'
log-queries: yes
log-replies: yes
#use-syslog: yes                            # v1.02 @Martineau Let scribe/syslog-ng handle the log as it gets erased daily if Ad Block enabled :-(
#log-local-actions: yes                     # v1.02 @Martineau
log-servfail: yes                           # v1.01 as per @dave14305 minimal config
do-ip4: yes
do-ip6: no
do-udp: yes
do-tcp: yes
# don't be picky about interfaces but consider your firewall
#interface: 0.0.0.0
interface: 127.0.0.1@53535                  # v1.01 as per @dave14305 minimal config
access-control: 0.0.0.0/0 refuse
access-control: 127.0.0.0/8 allow
access-control: 10.0.0.0/8 allow
access-control: 172.16.0.0/16 allow
access-control: 192.168.0.0/24 allow
# RFC1918 private IP address - Protects against DNS Rebinding
private-address: 127.0.0.0/8
private-address: 169.254.0.0/16
private-address: 10.0.0.0/8
private-address: 172.16.0.0/12
private-address: 192.168.0.0/16
# integration IPV6
# do-ip6: yes
# interface: ::0
# access-control: ::0/0 refuse
# access-control: ::1 allow
# private-address: fd00::/8
# private-address: fe80::/10
#module-config: "dns64 validator iterator"      # v1.03 v1.01 perform a query against AAAA record exists
#dns64-prefix: 64:FF9B::/96                     # v1.03 v1.01
tls-cert-bundle: "/etc/ssl/certs/ca-certificates.crt"     # v1.01 as per @dave14305 minimal config
# no threads and no memory slabs for threads
num-threads: 1
msg-cache-slabs: 2
rrset-cache-slabs: 2
infra-cache-slabs: 2
key-cache-slabs: 2
# tiny memory cache
#extended-statistics: yes                        # v1.06 Martineau for @juched GUI TAB
key-cache-size: 8m
msg-cache-size: 8m
rrset-cache-size: 16m
cache-max-ttl: 21600
cache-min-ttl: 5
# prefetch
prefetch: yes
prefetch-key: yes
minimal-responses: yes
serve-expired: yes
serve-expired-ttl: 3600
incoming-num-tcp: 600
outgoing-num-tcp: 100
ip-ratelimit: 0                                  # v1.04 as per @L&LD as it impacts ipleak.net?
edns-buffer-size: 1472                           # v1.01 as per @dave14305 minimal config
# Ensure kernel buffer is large enough to not lose messages in traffic spikes
#so-rcvbuf: 1m                                   # v1.05 Martineau see DEFAULT /proc/sys/net/core/rmem_default
# Options for integration with TCP/TLS Stubby
# udp-upstream-without-downstream: yes
# gentle on recursion
hide-identity: yes
hide-version: yes
do-not-query-localhost: no
qname-minimisation: yes
harden-glue: yes
harden-below-nxdomain: yes
rrset-roundrobin: yes
aggressive-nsec: yes
deny-any: yes
# Self jail Unbound with user "nobody" to /var/lib/unbound
username: "nobody"
directory: "/opt/var/lib/unbound"
chroot: "/opt/var/lib/unbound"
# The pid file
pidfile: "/opt/var/run/unbound.pid"
# ROOT Server's
root-hints: "/opt/var/lib/unbound/root.hints"
# DNSSEC
module-config: "validator iterator"
auto-trust-anchor-file: "/opt/var/lib/unbound/root.key"
# Adblock blacklist
#include: /opt/var/lib/unbound/adblock/adservers
#include: /opt/var/lib/unbound/adblock/firefox_DOH
remote-control:
control-enable: yes
#control-use-cert: no                            # v1.07 Martineau "Fast Menu"
control-interface: 127.0.0.1
control-port: 953
server-key-file: "/opt/var/lib/unbound/unbound_server.key"
server-cert-file: "/opt/var/lib/unbound/unbound_server.pem"
control-key-file: "/opt/var/lib/unbound/unbound_control.key"
control-cert-file: "/opt/var/lib/unbound/unbound_control.pem"
## v1.05 Martineau
forward-zone:                                                        # DNS-Over-TLS support
forward-tls-upstream: yes
forward-addr: 1.1.1.1@853#cloudflare-dns.com
forward-addr: 1.0.0.1@853#cloudflare-dns.com
forward-addr: 9.9.9.9@853#dns.quad9.net
forward-addr: 149.112.112.112@853#dns.quad9.net
forward-addr: 2606:4700:4700::1111@853#cloudflare-dns.com
forward-addr: 2606:4700:4700::1001@853#cloudflare-dns.com
forward-addr: 2620:fe::fe@853#dns.quad9.net
forward-addr: 2620:fe::9@853#dns.quad9.net
forward-zone:
   forward-addr: 127.0.1.1@53
#   forward-addr: 0::1@5453 # integration IPV6
# v1.01 Added the following
auth-zone:
       url: "https://www.internic.net/domain/root.zone"
       fallback-enabled: yes
       for-downstream: no
       for-upstream: yes
       zonefile: root.zone
here it is
server:
port: 53535
# integration LOG's
log-queries: yes
log-replies: yes
do-ip4: yes
do-ip6: no
do-udp: yes
do-tcp: yes
#interface: 0.0.0.0
# integration IPV6
# do-ip6: yes
# interface: ::0
num-threads: 1
msg-cache-slabs: 2
key-cache-slabs: 2
# tiny memory cache
key-cache-size: 8m
msg-cache-size: 8m
cache-min-ttl: 5
# prefetch
prefetch: yes
prefetch-key: yes
serve-expired: yes
hide-identity: yes
hide-version: yes
harden-glue: yes
deny-any: yes
username: "nobody"
# The pid file
# ROOT Server's
# DNSSEC
# Adblock blacklist
remote-control:
control-enable: yes
control-port: 953
## v1.05 Martineau
forward-zone:
auth-zone:
       for-downstream: no
       for-upstream: yes
       zonefile: root.zone
So did you attempt to configure unbound DoT?
e  = Exit Script
A:Option ==> DoT
Do you want to ENABLE DoT with unbound?
    Warning: This will DISABLE being able to be your own trusted Recursive DNS Resolver
So, do you STILL want to ENABLE DoT with unbound?
    Reply 'y' or press [Enter]  to skip
here it is
server:
port: 53535
# integration LOG's
log-queries: yes
log-replies: yes
do-ip4: yes
do-ip6: no
do-udp: yes
do-tcp: yes
#interface: 0.0.0.0
# integration IPV6
# do-ip6: yes
# interface: ::0
num-threads: 1
msg-cache-slabs: 2
key-cache-slabs: 2
# tiny memory cache
key-cache-size: 8m
msg-cache-size: 8m
cache-min-ttl: 5
# prefetch
prefetch: yes
prefetch-key: yes
serve-expired: yes
hide-identity: yes
hide-version: yes
harden-glue: yes
deny-any: yes
username: "nobody"
# The pid file
# ROOT Server's
# DNSSEC
# Adblock blacklist
remote-control:
control-enable: yes
control-port: 953
## v1.05 Martineau
forward-zone:
auth-zone:
       for-downstream: no
       for-upstream: yes
       zonefile: root.zone
Far from my expertise level, and maybe it is just a formatting, cut n' paste issue, but wouldn't all of those '@' symbols under the DoT section wreak some havoc??
