Hi all,
I have an ASUS RT-AC68U and I've been running Asuswrt on since I bought it. I haven't upgraded the firmware, as everything's been working properly, but I think it's finally time. Problem is, I don't seem to be able to make the upgrade work.
The version of the firmware I have running now is: 3.0.0.4.374.39
I rebooted the router and attempted to update to 380.59 by downloading and unzipping RT-AC68U_380.59_0.zip and uploading RT-AC68U_380.59_0.trx using the administration panel.
What happened was the progress bar went all the way through and then told me it succeeded. However, when I came back to the main router control screen it was still showing the the old firmware version. I rebooted to see if that would make a difference, and it didn't.
At that point I did a full factory reset on the router (backing up my configuration first) and then tried the upgrade again. It did the exact same thing, telling me the upgrade succeeded, but actually doing nothing.
So, for the time being I've reloaded my old configuration file, and I'm stuck on 374.39.
Can anyone suggest what I might do here? It's obviously been a LONG time since I upgraded. Do I need to do a series of firmware upgrades? Like install a few legacy versions to get to current? Am I just stuck?
Any help is greatly appreciated!
