USB Wifi 7 adapter - USB-BE92 Nano
RMerlin
Asuswrt-Merlin dev
Staff member
I see the product is now available for sale, so I guess I can talk about it.
New USB dongle that adds Wifi 7 support. It's based on an RTL8922AU, which unfortunately is limited to 160 MHz. MLO support is expected to be added at a later time.
The current driver still seems a bit iffy, Windows reports its link PHY as AX, while the router does specify the PHY is really BE.
You say the Driver is iffy, are you using it currently? Have one in hand?
Would have been great to have Mac driver/compatibility - since 2024 Macs are lacking wifi 7 for the most part…
