vpnmgr vpnmgr - Manage and update VPN Client configurations for NordVPN and PIA
Which VPN provider do you use?
  • Total voters
    318
@Jack Yaz been running v1 since release without problem. I use Nord is there any advantage updating to V2 , is the update mainly for PIA support or is there bugfixes / enhancements also.
Thanks Andy.
Thanks Andy.
Some minor fixes and enhancements went in, but I can't think of any significant ones off the top of my head
I uninstalled NVPNMGR, rebooted and installed VPNMGR. After updating all my settings via CLI, I went to VPNMGR tab on WebUI and noticed at the very top of the page the version number shows as v2.0.0. But then right next to it there is also a line that states “updated version available v1.0.0.” Then next to it is the Update button.
Since v2.0.0 is the most up-to-date version could this mislead others to think that they need to need to update to v1.0.0?
Or is this something that I am only experiencing?
check via the cli, i suspect a variable wasn't updated during the reinstall (in /jffs/addons/custom_settings.txt)
I see that the local and server versions are different:
/jffs/addons/custom_settings.txt ntpmerlin_version_local v2.5.1
connmon_version_local v2.6.0
spdmerlin_version_local v3.6.1
uidivstats_version_local v2.2.1
uidivstats_version_server v2.2.1
vpnmgr_version_local v2.0.0
vpnmgr_version_server v1.0.0
Div_ver 4.1.12
Div_mode enabled
Div_edt Standard
Div_logt enabled
Div_log on
Div_ps pixelserv-tls
Div_bIP 192.168.50.2
Div_adb on
Div_ver 4.1.12
Div_mode enabled
Div_edt Standard
Div_logt enabled
Div_log on
Div_adb on
yes, hopefully uf will solve this
That’s what I will try! Thanks and have a good weekend!
Tried both u and uf without success - see below
Don
ASUSWRT-Merlin RT-AC86U 384.17_0 Sun Apr 26 02:28:53 UTC 2020
xxx@RT-AC86U-A580:/tmp/home/root# cat /jffs/addons/custom_settings.txt
nvpnmgr_version_local v1.0.0
nvpnmgr_version_server v1.0.0
xxx@RT-AC86U-A580:/tmp/home/root# nvpnmgr
##  _ __ __   __ _ __   _ __   _ __ ___    __ _  _ __  ##
## | '_  \ \ / /| '_ \ | '_ \ | '_   _ \  / _  || '__| ##
## | | | |\ V / | |_) || | | || | | | | || (_| || |    ##
## |_| |_| \_/  | .__/ |_| |_||_| |_| |_| \__, ||_|    ##
##              | |                        __/ |       ##
##              |_|                       |___/        ##
##                  v1.0.0 on RT-AC86U                 ##
##         https://github.com/jackyaz/nvpnmgr          ##
##                forked from h0me5k1n                 ##
1.    List VPN client configurations
2.    Update configuration for a managed VPN client
3.    Search for new recommended server for a managed VPN client
4.    Enable management for a VPN client
5.    Disable management for a VPN client
6.    Update schedule for a VPN client configuration update
7.    Enable a scheduled VPN client configuration update
8.    Delete a scheduled VPN client configuration update
r.    Refresh country data
u.    Check for updates
uf.   Update nvpnmgr with latest version (force update)
e.    Exit nvpnmgr
z.    Uninstall nvpnmgr
Choose an option:    uf
nvpnmgr: Downloading latest version () of nvpnmgr
nvpnmgr: New version of nvpnmgr_www.asp downloaded
nvpnmgr: Mounting nvpnmgr WebUI page as user1.asp
##              | |                        __/ |       ##
##              |_|                       |___/        ##
e.    Exit nvpnmgr
Choose an option:    u
##              | |                        __/ |       ##
##              |_|                       |___/        ##
e.    Exit nvpnmgr
Choose an option:    u
@Jack Yaz thanks for the wonderful add-ons and shell scripts. I'm using many of your work. 1 quick question slightly off-topic, do you use any IDE to develop your ASP code (I've never written ASP before)? If you do can you recommend the one you used if any? Thanks in advance.
Don
##              | |                        __/ |       ##
##              |_|                       |___/        ##
e.    Exit nvpnmgr
##              | |                        __/ |       ##
##              |_|                       |___/        ##
e.    Exit nvpnmgr
Choose an option:    u
##              | |                        __/ |       ##
##              |_|                       |___/        ##
e.    Exit nvpnmgr
Choose an option:    u
Works fine here after doing “uf”
Ditto on ProtonVPN here. Great service, not cheap, but reasonable when bundled with email.
@DHLarson try now please
So, update ran but some glitches.
First:
I assume these should be the same...
Second:
Menu tab for VPN Mgr didn't appear. Only other addon with menu - Skynet tab is appearing fine. Per previous conversation, ran the following:
xxx@RT-AC86U-A580:/tmp/home/root# ls -la /tmp/menuTree.js
-rw-rw-r-- 1 xxx root 21585 Jul 25 14:32 /tmp/menuTree.js
Which was after I rebooted the router after the upgrade. In reviewing the syslog, I see:
Jul 25 14:30:50 vpnmgr: Mounting vpnmgr WebUI page as user1.asp
but then, 2 minutes later:
Jul 25 14:32:41 Skynet: Mounting Skynet Web Page As user1.asp
So, where does this get fixed? I installed NVPNMGR first, followed by SKYNET. When I updated to VPNMGR, SKYNET appears to be overwriting it.
I tried restarting VPNMGR and here's what happened:
xxx@RT-AC86U-A580:/tmp/home/root# vpnmgr startup
vpnmgr: Sleeping for 30s before running startup routine
/opt/bin/vpnmgr: line 2177: can't open /jffs/addons/vpnmgr.d/vpnmgr_www.asp: no such file
vpnmgr: Mounting vpnmgr WebUI page as user2.asp
cp: can't stat '/jffs/addons/vpnmgr.d/vpnmgr_www.asp': No such file or directory
-rw-rw-r-- 1 xxx root 21629 Jul 25 15:28 /tmp/menuTree.js
Consequently, the tab is now present in the menu but you get a 404 Not Found error
Suggestions to fixing the Skynet overwrite and resolving the missing asp file?
First:
Second:
Reran the UF option and, wonder of wonders, things seem to be OK. Gonna let it settle for a little while then try again with a reboot. But seem to be on V2 code with both Skynet and VPNMGR tabs appearing and functional. Not sure what went south but it seems to have self resolved.
Hi @Jack Yaz
I was referred to the thread by RMerlin (as we've spoken since my days working at PIA) and I would like to suggest WeVPN be added as well.
I'm the CXO and anything information which you need can easily be supplied.
Hi @Jack Yaz
Interesting, I've not heard of WeVPN. Are the OVPN files publicly accessible?
WeVPN is a new VPN launched (April 2020) and built by veterans of the VPN industry. Myself I was the Senior Vice President of PIA for 3 years before I left in March 2019. I've made a public article explaining who are the people behind WeVPN if that helps.
We do not have static OVPN files, however we do have a Config Generator within our members area (which offers OpenVPN 2.3 (for Synology devices), OpenVPN 2.4 (our standard) and Wireguard config generators). If you need files exported, I can easily create you a test account, though we offer a 7 day free trial for customers who sign up using either Google Play or Apple Store with the credentials being used without issue on other platforms such as routers, Windows, MacOS etc. Additionally, we have a 30 day refund policy.
If you want to email me directly, you can do so and I will set you up with a testing account (which I like to offer all people who we work with for technical testing). My email is Jayson (at) wevpn (dotcom)
I'll send you an email shortly. My immediate concern is how the script/router would be able to generate/obtain the OpenVPN configuration. Is the config generator an API, that I could access via an authenticated request?
You tell us what you need and we'll make it happen...
