VPNMON VPNMON-R2 v2.0 -Jul 10, 2022- Monitor your VPN connection's Health (Thread locked/closed)
Correct, it never gets to the "WAN Down" screen of red text saying "reboot or reconnect your modem" (can't quite remember exact wording), it just sits at the normal monitoring loop screen trying to detect WAN but never going further ...
okay I am looking into the code now to see if I can figure out what is happening. It doesn't look like any variables are amiss , maybe it is something with the conditional arguments. I will keep @Viktor Jaep posted if I find anything.
Why must wan1_state_t equal 2 to break out of the loop? If you don’t use Dual WAN, why would wan1 even be relevant?
To be clear, I would have || instead of && because we are saying "or" instead of requiring in addition to.
checkwan () {
  # Using Google's 8.8.8.8 server to test for WAN connectivity over verified SSL Handshake
  Connectivity=1
  wandownbreakertrip=0
  vpnresettripped=0
  WAN_ELAPSED_TIME=0
  testssl=8.8.8.8
  # Show that we're testing the WAN connection
  if [ $1 == "Loop" ]
  then
    printf "${CGreen}\r[Checking WAN Connectivity]..."
  elif [ $1 = "Reset" ]
  then
    printf "${CGreen}\rChecking WAN Connectivity..."
  fi
  while [ $Connectivity == "1" ]; do
    # Start a timer to see how long this takes to add to the TX/RX Calculations
    WAN_START_TIME=$(date +%s)
    # Check the actual WAN State from NVRAM before running connectivity test
    if [ "$(nvram get wan0_state_t)" -ne 2 ] && [ "$(nvram get wan1_state_t)" -ne 2 ]
      then
        # The WAN is most likely down, and keep looping through until NVRAM reports that it's back up
        wandownbreakertrip=1
        while [ $wandownbreakertrip == "1" ]; do
          # Continue to test for WAN connectivity while in this loop. If it comes back up, break out of the loop and reset VPN
          if [ "$(nvram get wan0_state_t)" -ne 2 ] || [ "$(nvram get wan1_state_t)" -ne 2 ]
            then
              # Continue to loop and retest the WAN every 15 seconds
              echo -e "$(date) - VPNMON-R2 ----------> ERROR: WAN DOWN" >> $LOGFILE
              # clear screen
              clear && clear
                echo -e "${CRed}-----------------> ERROR: WAN DOWN <-----------------"
                echo ""
                echo -e "${CRed}VPNMON-R2 is unable to detect a stable WAN connection."
                echo -e "Trying to verify connection every $SPIN seconds...${CClear}\n"
                echo ""
                echo -e "${CRed}Please check with your ISP, or reset your modem to "
                echo -e "${CRed}re-establish a connection.${CClear}\n"
                spinner
            else
              wandownbreakertrip=2
          fi
        done
      else
        # If the WAN was down, and now it has just reset, then run a VPN Reset, and try to establish a new VPN connection
        if [ $wandownbreakertrip == "2" ]
          then
            vpnresettripped=1
            echo ""
            echo -e "${CGReen}WAN Connection Detected... waiting 30 seconds for connection to stabilize."
            echo -e "$(date) - VPNMON-R2 - WAN Connection Re-established -- Resetting VPN" >> $LOGFILE
            SPIN=30
            spinner
            clear && clear
            vpnreset
        fi
        # Else test the connection on active WAN using 443 and verifying a handshake... if this fails, then the WAN connection is most likely down... or Google is down ;)
        if nc -w1 $testssl 443 && echo |openssl s_client -connect $testssl:443 2>&1 |awk 'handshake && $1 == "Verification" { if ($2=="OK") exit; exit 1 } $1 $2 == "SSLhandshake" { handshake = 1 }'
          then
            if [ $1 == "Loop" ]
            then
              printf "${CGreen}\r[Checking WAN Connectivity]...ACTIVE"
              sleep 1
              printf "\33[2K\r"
            then
              printf "${CGreen}\rChecking WAN Connectivity...ACTIVE"
              sleep 1
              echo -e "\n"
            fi
            WAN_END_TIME=$(date +%s)
            WAN_ELAPSED_TIME=$(( WAN_END_TIME - WAN_START_TIME ))
            return
          else
        fi
    fi
  done
In the grand scheme of things && would require both wan1 and wan2 to be up and running, while || would accept either of the two as long as one was running?
Nice catch @dave14305
So both states must != 2 to indicate WAN down, but only one of them needs to = 2 to indicate WAN up? Is that the logic?
Sounds like it. I only use 1 wan and the other reports 2.
@RT-AX88U-C7C0:/tmp/home/root# nvram get wan1_state_t
0
0
@RT-AX88U-C7C0:/tmp/home/root# nvram get wan0_state_t
2
checkwan () {
  Connectivity=1
  vpnresettripped=0
  WAN_ELAPSED_TIME=0
  testssl=8.8.8.8
  if [ $1 == "Loop" ]
  then
  then
  fi
      then
            then
              # clear screen
              clear && clear
                echo ""
                echo ""
                spinner
            else
          fi
        done
      else
          then
            vpnresettripped=1
            echo ""
            SPIN=30
            spinner
            clear && clear
            vpnreset
        fi
          then
            if [ $1 == "Loop" ]
            then
              sleep 1
              printf "\33[2K\r"
            then
              sleep 1
              echo -e "\n"
            fi
            return
          else
        fi
    fi
  done
So the first if condition would be && and the second would be accepting or ||
checkwan () {
  Connectivity=1
  vpnresettripped=0
  WAN_ELAPSED_TIME=0
  testssl=8.8.8.8
  if [ $1 == "Loop" ]
  then
  then
  fi
      then
            then
              # clear screen
              clear && clear
                echo ""
                echo ""
                spinner
            else
          fi
        done
      else
          then
            vpnresettripped=1
            echo ""
            SPIN=30
            spinner
            clear && clear
            vpnreset
        fi
          then
            if [ $1 == "Loop" ]
            then
              sleep 1
              printf "\33[2K\r"
            then
              sleep 1
              echo -e "\n"
            fi
            return
          else
        fi
    fi
  done
But do you need to invert the logic from -ne 2 to -eq 2 and swap the if and else clauses so that if either wan state = 2, then you trip the breaker. In your snippet, if either are not 2, we will stay in the loop indefinitely.
As @dave14305
Has pointed out for the first check we want to confirm both Wans are simultaneously down. On the second we can break the chain on realizing one of them is functional.
I was led to believe that && means "AND IF", in order to handle a scenario of someone having dual WANs. One or the other would break that chain. I only have 1 WAN. WAN2 always indicates 0. It seems to work?
correct, so wouldn't && be appropriate then and maybe we are over looking at it?
What it is saying is that we require both to not be equal to 2 in order to declare the WAN down when && is used.
You have to use && to consider a fallback wan scenario.
I think you need to do double order check.
checkwan () {
  Connectivity=1
  vpnresettripped=0
  WAN_ELAPSED_TIME=0
  testssl=8.8.8.8
  if [ $1 == "Loop" ]
  then
  then
  fi
    if { [ "$(nvram get wan0_state_t)" -ne 2 ] && [ "$(nvram get wan1_state_t)" -ne 2 ] } || { [ "$(nvram get wan1_state_t)" -ne 2 ] && [ "$(nvram get wan0_state_t)" -ne 2 ]; }
      then
            then
              # clear screen
              clear && clear
                echo ""
                echo ""
                spinner
            else
          fi
        done
      else
          then
            vpnresettripped=1
            echo ""
            SPIN=30
            spinner
            clear && clear
            vpnreset
        fi
          then
            if [ $1 == "Loop" ]
            then
              sleep 1
              printf "\33[2K\r"
            then
              sleep 1
              echo -e "\n"
            fi
            return
          else
        fi
    fi
  done
@Viktor Jaep , You need to consider both sides of the coin.
