VPNMON VPNMON-R2 v2.0 -Jul 10, 2022- Monitor your VPN connection's Health (Thread locked/closed)
I would guess no. Not always.
If WAN0/WAN1 don't correlate to eth0/eth1, why would that be? Do you think people are manually manipulating which eth# they're linking things to? Can you think of any instances where this is happening? Nothing to do with different router models, right?
Luckily, there apparently is an NVRAM value for this! Thank goodness...
nvram get wan0_ifname
This script has code to determine if dual-wan is active, which mode, and which ifname.
As an example, the AX58U uses eth4 for wan. You never know…
try out
ip a | grep global
interesting the order things appear..... maybe make note...
also
ip a | grep global | grep -E '\b.*eth.*\b'
I'm thinking, if I query "nvram get wan0_ifname", it should spit back "eth4" for example in the case of an AX58U.
On my AC86U, this line spits back "eth0"... would that logic work?
Rhetorical question... WAN0 and WAN1 always correlate to eth0 and eth1 on our routers, right?
At least not for AC86U.
ip a | grep global | grep -oE '\beth.*\b'
what does this spit back?
or
route | grep default | grep -oE '\beth.*\b'
That's great info... thanks for validating that eth1 == port4
Unless pppoe is in use. Then you need wan0_pppoe_ifname. I was surprised how complicated it can get.
OMG... can't things ever be straighforward! LOL
What are you gonna do once you know the interface name?
Something like this...
Surprise, BTW! ;) Letting the cat out of the bag here before 1.5 goes live...
Ppp user here
dmin@RT-AC86U-DBA8:/tmp/home/root# ip a | grep global | grep -oE '\beth.*\b'
admin@RT-AC86U-DBA8:/tmp/home/root# route | grep default | awk '{ print $8 }'
ppp0
I will be sure to test for this... thanks for the heads-up!
