I finally went ahead, and upgraded my laptop with an Intel BE200 wifi card, and did a few file copy tests.
This is a file copy done from another room (so, with one wall between my laptop and my router proving that you don't need to be in the same room as some are claiming), and also without MLO - just a regular 6 GHz connection, at 320 MHz channel width:
I am now bottlenecked by the 2.5 Gbps interface on my NAS, so I don't even know what the real capability of the connection is. My link rate was around 3400 Mbps at the time, so it's probably just slightly above that. That means I can't test MLO's actual capabilities since I don't have anything else faster than 2.5 Gbps on my network to test against.
With the previous Wifi 6e card, I was previously hitting between 150 and 200 MB/s, depending on circunstances.
