[alpha] Asuswrt-Merlin 380.67 pre-beta test builds
No issues with flashing alpha3 for me on ac66u and AC88U. Smooth as silk!
I would check with your internet provider. I have seen mine install fiber at several sites I support with some MTU set at 1492 and others at 1500. I never have followed up as to why. But they both work.
my isp tech support is hopeless lastime i asked thw over seas rep has no i dead whar i asked, i hope if merlin has time he might be able to look into it. I do suspect it can be set lower than 1500 but the router refuses to reconnect this is under automatic ip, but under pppoe if the mru was set lower than 1492 it was refusing to reconnect but if the mtu was changed it was fine, the annoying part is if the isp says its lower than x value i cant set it becuase of the above issue.
Alpha 3 flashed and all is working well.
Previously (alpha 2) the date stamp was incorrect on the sig version.
Alpha 3 has similar "glitch"
1.170 Updated : 2017/06/03 15:11
As RMerlin stated, the sig is correct, yet date incorrect.
I can live with that.
Beta 1 is now available, locking this thread. Thank you everyone for the feedback.
