[Alpha] Preview builds for Asuswrt-Merlin 380.60
I'm on Alpha 3 for the RTAC68U (AC68U,rev A2)
Direct connection to Internet modem.
occurs whether
ipv6 is enabled or not
openvpn is enabled or not
I keep seeing this error in the logs ever 5 seconds.
Jun 11 19:24:06 kernel: TCP: time wait bucket table overflow
Jun 11 19:24:11 kernel: net_ratelimit: 1397 callbacks suppressed
Jun 11 19:24:11 kernel: TCP: time wait bucket table overflow
Jun 11 19:24:16 kernel: net_ratelimit: 896 callbacks suppressed
Jun 11 19:24:16 kernel: TCP: time wait bucket table overflow
Jun 11 19:24:21 kernel: net_ratelimit: 1697 callbacks suppressed
Jun 11 19:24:21 kernel: TCP: time wait bucket table overflow
Any ideas to troubleshoot?
Applied 380.60 few hours ago and so far it's good. Was the client traffic monitor removed on this build? I'm failing to find it.
Sent from my D6633 using Tapatalk
Is this a know bug?
AC68U / 380.60 Alpha 3 / factory reseted.
When trying to specify paths to UPNP Server it wont render the folder structure from my USB disk.
Waited for alpha3 and loaded it on my 68U last night. Mine is one of the 1ghz 68U's. Working fine. I don't do anything fancy. Wireless solid, performance is great. Did not have the menu gui lag as when I went to the 59 version.
Have discovered one issue with the Wireless Site Survey on both Alpha 2 & 3 with the 87u .
It starts ok but never returns a result and is stuck at the following
"Searching for available networks, please wait...
Open your web browser console and look for any Javascript error.
I just noticed the WAN packet overhead options, any insight into what they do specifically?
To properly calculate packet delay and performance, the packet scheduler needs to know the exact size of a packet. Modems and ISP equipment adds some overhead to each packet when using protocols such as VDSL2, and transmitting packets over ATM. This allows to adjust the packet size calculation by specifying the overhead that gets added to each packet, providing more accurate traffic performance calculations.
Media Server is ON?
Under Tools = DLNA: Rebuild entire database at start (default: No)= YES?
Did you unplug and replug your drive?
Yeah media server is on and working fine. what is missing is the option to specify paths. If I choose share all disk it works like a charm.
  • Like
Reactions: eaz
Since upgrading to the Alpha release of .60 I've been looking into setting up QoS but have noted that on Mac Safari (9.1.2) the QoS Configuration dropdown (priorities & rules) is not present, when changing over to Chrome (52) though it is present.
Anyone else noted this on Mac Safari?
Hi, would like to report that my internet access has become very unstable, with webpages refusing to load or taking a lot more time to access after activating ipv6 on my ISP.
Everything is back to normal, snappy loading of webpages after disabling the ipv6 though.
Still works fine for me on my 87U.
Sent from my  iPhone using Tapatalk
Lots of different issues caused by Safari. Avoid it, and switch to a better compliant browser such as Chrome or Firefox.
I have been using the third alpha of the 380.60 FW. I have not had any issues with ipv6. I use Hurricane Electric for ipv6. No problems. I have the RT-AC87U router. No wireless issues that I can detect. Windows 10 tracking and malware ipsets functioning well. Thanks for what you do, RMerlin.
Hello! . Its the first post for me but iv'e been around for quite awhile. What differs Merlin realeses from Asus original for me is
Merlin =+ 10-15ms in gaming wired Connection.
merlin = slower respons time over gaming in general, online gaming compared to asus original.This is compared with all the latest realeses of both original and merlin.
Just curious.... what versions of the 380.60 alpha can you flash back? Anybody have any experience? I figure going back to an old alpha build might be a way to go old or alternate firmware in the future.
