Yes
Yes
PC is Asus ZenBook Duo (UX482EG.316) with Intel AX200 ;Welcome to the forums @yangbodavid.
From which two devices are you testing? Be specific as to the hardware.
Is this with the latest beta? If it is with the stock firmware, then you will want to create a different thread. If it is with the current beta, and you have a way to repro (from a Windows system) I could try. I get over 5 gbit up and down for TCP (on speedtest) so I don't have an ISP limitation in testing beyond what you are seeing.PC is Asus ZenBook Duo (UX482EG.316) with Intel AX200 ;
Server is Truenas Scale with Intel X710-DA4 / E5-2618Lv4 / 128GiB LRDIMM/8T HDD*10 ;
Switcher is TP-LINK TL-ST5008F ;
AX89X (b1) is running APmode 160mhz at Channel48 ;
When I use QNA-T310G1S on my PC, I can get 1.13BiG/S in SMB test, both upload and download .
ASUS had conformed that issue ,but no solution .
Don't have an issue with my SFP+ port though it is running to the LAN. Have you tried switching the WAN to the RJ45 port and/or do you have a different transceiver to try to see if that is the cause?My log only shows this:
Code:Jun 19 14:54:06 WAN Connection: WAN(0) link up. Jun 19 14:54:06 rc_service: wanduck 1415:notify_rc restart_wan_if 0 Jun 19 14:54:14 wan: finish adding multi routes Jun 19 14:54:17 WAN Connection: WAN was restored.
with 388.32100Is this with the latest beta? If it is with the stock firmware, then you will want to create a different thread. If it is with the current beta, and you have a way to repro (from a Windows system) I could try. I get over 5 gbit up and down for TCP (on speedtest) so I don't have an ISP limitation in testing beyond what you are seeing.
I have to use the SFP+ module for my fiber. It only happens every few days and I think it could be Wireguard. But I will further investigate when it's becoming a problem to me - which it's not at the moment thanks to DynDNS.Don't have an issue with my SFP+ port though it is running to the LAN. Have you tried switching the WAN to the RJ45 port and/or do you have a different transceiver to try to see if that is the cause?
What exactly do you think is "urgent" in this thread you linked to? If it is a question about having received the beta firmware when you replied to Asus, that information is already discussed in this thread which you should probably read, with whatever urgency you feel appropriate.everyone who installed this VERSION
pls view my topic urgent
Ax-89x Beta
So i run on my router diagnostic to send to Asus Today i got this email. Is this legit? I got this email in the time i did diagnostic from my router with my email . The from address is: mark078524@gmail.com Not from asus That’s super weirdwww.snbforums.com
Nothing in your message shows that. The fact that it came from a reply to your request would actually indicate the opposite. Given your support "request", I assume English is not your first language so you may be reading something incorrectly in the replies. Also, again, I suggest you read through at least the last half of this thread.It’s not legit firmware.
this is not true.It’s not legit firmware.
i dont know if exist new beta.Hello fellow x89x users! any new beta update? looks like the good weekly rate is dead
Hi mate,Firmware Version 9.0.0.4.388_32386
works fine
thanks man.
Is your connection still working?At WAN -> DHCP query frequency there is a new "Continuous Mode". Since I enabled this, it looks like it has been fixed. No reconnection for 5 days now.
Welcome To SNBForums
