Beta Asus RT-AX89X_9.0.0.4_388_31185 Beta
I have the ax89x with 3 tuf-5300. And all perfect.
Before this i have 1 ax92 with dual 5ghz band (one wifi 6 and other wifi 5) and have a lot of problems in mesh.
I dont know what was the problem, but changing the ax92 for the tuf-5300 solves all my problems
Is fan tuning broken for anyone else? According to the graph, my fan seems to be running at 2500RPM regardless of what settings I use.
Same issue
I read about it
And there is issue with the fan
For me even on low is very noisy
I'm not seeing this issue on the latest beta firmware (32100). My fan is running around 1900rpm. Set to auto. Start is 45/75/90. Stop is 40/70/85.
mesmo problema
eu li sobre isso
E há problema com o ventilador
Para mim, mesmo no baixo é muito barulhento
RT-AX89U_9.0.0.4_388_32100
Set the power save mode to "Auto". Even if the fan speed setting is set to "Auto", it will not be enabled.
Sfp restart?
My log only shows this:
Jun 19 14:54:06 WAN Connection: WAN(0) link up.
Jun 19 14:54:06 rc_service: wanduck 1415:notify_rc restart_wan_if 0
Jun 19 14:54:14 wan: finish adding multi routes
Jun 19 14:54:17 WAN Connection: WAN was restored.
Check your router temperature
It happened to me before
I set the fan speed to Medium
And on lan settings i disable “ cpu nat acceleration”
try to disable it
No, because all the traffic would then be processed by the CPU which means my internet speed would drop to ~200mbit instead of >1gbit.
Enabling NAT acceleration in this setting means disabling NAT acceleration by the CPU.
When I disabled this i get more internet speed
