New one from yesterday
Below beta firmware fix https login issue.
RT-AX89U_9.0.0.4_388_32100-gd2badf4_for_user.trx
This will work with ax-89x ?
The filename is 89u
Isso funcionará com ax-89x?
O nome do arquivo é 89u
Is this the one where https://router_ip: port bypasses authentication? I'll try it out later and see if it fixes that issue. Thanks again for passing this along.Below beta firmware fix https login issue.
Try deleting the cookies for the router IP address (as well as router.asus.com and asusrouter.com).Is this the one where https://router_ip: port bypasses authentication? I'll try it out later and see if it fixes that issue. Thanks again for passing this along.
This fixed the https login issue. It now redirects to https://router_ip: port/Main_Login.asp and prompts for authentication as expected. Earlier when I was testing, if you used https://router_ip: port/index.asp it redirected and forced you to login. Just not with https://router_ip: port.Below beta firmware fix https login issue.
I try but they don’t give mewhen you have a support ticket open with asus reporting any problem. in some cases the asus technician, send you the link for a new beta.
Its the only way, we know
nobody. we cant see the futureCan someone get the release date?
Officially release
From here i see they update the beta once a week..nobody. we cant see the future![]()
beta once a week during last month. if you read all the post you can see that 5 betas before, was released in december!!From here i see they update the beta once a week..
I didn’t get any success to get the beta version from asus![]()
Confirmed. Those fields are empty.I've got (and reported) an issue with the Wireguard VPN server. In the advanced settings there are no public and private key shown. Can someone confirm this as well?
Revert to original firmwareich have a problem. I use the ax89x as main router and two xt8 as node devices. All versions after the 388.32094 do not work correctly in this constellation. All devices that are supposed to connect to the nodes won’t do this any more. They all connect to the ax89x even when the signal strength is at minimum. Does anyone else have this problem or a solution?
Welcome To SNBForums
