It was working in my ac66u 38.1
Think you will add the feature back in the future build?
What Happen to the run command menu?
Yes, it's always soon - compared to somebody like Micro$oft!Someone new version soon of merlin?
RT-N66U FW: Merlin 374.40
But why not installing the current .42 version in the meantime?![]()
Perhaps because of broken 3G/4G modem support for example?
Ciao
Gerald
Wifi mac allow list is useless as wifi mac spoofing is easy and anyone can do it.
Wpa2 and turn off wps is enough.
That is totally your choice but I would not recommend it there are many security issues that have been addressed since the version you are using. If your comfortable with that then enjoy.![]()
Take screenshots of the router pages. It makes a pain in the arse an easy task.
gona try upgrade too 374.42.2
seing i actual took the time to right all the settings down.
So i flash to new firmware then factory defualt and put all settings back correct?
What about cron jobs do i have put them back in after this?
if so this is correct yes?
REBOOT CRON SCRIPT
cat << EOF > /jffs/scripts/services-start
#!/bin/sh
/usr/sbin/cru a ScheduledReboot "0 6 * * 4 reboot"
EOF
chmod a+rx /jffs/scripts/services-start
Attn: RMerlin,
Bug report for RT-AC68U with 374.42_2 firmware:
In USB Applications, Network Place Tab the Work Group is unable to accept a single character. I have been using single character Work Group names for the last year previously with your firmware.
The error that comes up is: 'Invalid character!' when Apply is clicked.
Hope you're able to fix this before 374.43 is finalized. Thank you.
I hope .43 is out sooon![]()
ok so basicly from 374 to 375 builds a factory reset is require but from say 374.42 to 374.43 its is not required?
Cause i vaguely remember having to update to 372.32 from previous 372.xx to fix the fact content from be deleted every time router reboots which was bug at some point and i didnt do factory reset then
BTW if i have feature request/sugesstion where would i go about asking it? is there topic for such things?
Be warned that I am very strict when it comes to adding any new feature, as this isn't the main focus of this FW project.
I was wondering if there's any change a fix will be available in a future release for the bug in the time management rules? (Any rule will be overruled for app. 30 seconds by reconnect to the AP, http://forums.smallnetbuilder.com/showthread.php?t=17337).
Welcome To SNBForums
