Asuswrt-Merlin 376.49 is out
First of all, thanks Merlin for all the hard work and the excellent firmware result of it.
Just upgraded from 48_3, did a Factory Reset and when configuring everything again I noticed that "Advertise DNS to clients" option is missing from OpenVPN Server settings.
Is this a bug (i think so) or was removed for some reason?
I was able to enable it manually in case anyone has the same problem by executing the following command:
nvram set vpn_server1_pdns="1"
Thanks, fixed. It's an issue in Asus's code that I had fixed a few months ago, but came back as I switched to their webui code in 3677.
https://github.com/RMerl/asuswrt-merlin/commit/c16febc682e42a7d2b789ae7b173f7f1af9fc3de
These past few weeks I've had 2-3 reports of issues with MAC filter names, yet I've been unable to reproduce any of it so far. Can you describe in details the steps you are taking, and the actual results?
Hi Merlin,
All it is is the name disappears and just shows the mac address twice.
Perhaps if I were to factory reset and re enter the whole lot that may cure it, but it doesn't bother me if I dont look at it !
I'm sorry there is not much detail to add.
When I add a new name to filter either the whole list disappears and just shows mac ads where name should be. or some work and some dont.
Either you really haven't updated as you think or you need to clear your cache. ;)
No problems here with my RT-N66U - updated, pulled the power plug and waited 5 minutes. Started the router and after 10 minutes did a gui Reboot.
Solid ever since.
So weird but it works now after i updated again. Weird that it didnt work the first time when i just repeated what i did then now. :D
Had DHCP issues with 376.49_2 on my AC87R
Just got home today from my pre-Christmas vacation and saw there was a new update.. I decided to take the chance even though Merlin moved the version to beta due to a boot loop. After the update everything looked ok until my DHCP hosts started to renew. The system log kept stating:
no leases left​
Well I took the plunge and deleted all the static leases and tested and the DHCP clients were correctly getting addresses from the pool. Then I stared to re-add the statistic leases and everything seems to reverted back to normal.
Very strange but just wanted to see if anyone else had DHCP issues when they did the update? So far everything seems to working fine after the DHCP issue. I will be testing out QOS later next week after this smokes in.
Just an update:
I am seeming memory utilization at 61% now vs on the previous version of Merlin on the router only hovered about 35%. I can't seem to find what is using the additional memory but this could cause some issues with folks that use other applications such as BitTorrent and media sharing from the router.
free -m
             total         used         free       shared      buffers
Mem:        255752       161480        94272            0         2140
-/+ buffers:             159340        96412
Swap:            0            0            0
Media Bridge
Hi, I have been using 376.48 for a while now in media bridge mode. I bridge the 5ghz band to my primary router and then it would rebroadcast on the 2.4ghz band to other wireless clients. Although asus says it is not supposed to work this way (both radios active) it worked perfectly. After upgrading to 376.49 this stops working. Is that by design as a fix or is there someway around that? I even try enabling the 2.4 radio using telnet (wl -i eth1 up) but it won't stay on, and the wl -i eth1 status message show a BSSID of all zeros.
Ideas?
Dave
no leases left​
Check /etc/dnsmasq.conf to see how many leases are available total. Also make sure the message you are seeing isn't caused by a bug in Windows 8 where it requests a DHCPv6 lease even tho it's obtaining an IP through stateless configuration (RA).
free -m
Swap:            0            0            0
You must be running something that takes up memory, because mine has a lot more available:
admin@Stargate87:/tmp/home/root# free -m
Mem:        255752        71784       183968            0          428
-/+ buffers:              71356       184396
Swap:            0            0            0
Check with "top" what's consuming your memory. Also check the content of the ram disk (/tmp).
Solved a problem by changing the Encryption cipher setting in Advanced settings.
For some reason the openvpn server now in 376.49 doesn't start if the Encryption cipher is set to None!
Might be a limitation of the auto-cert generation code (which is from Asus).
Personally I never understood why the original OpenVPN code even allowed setting encryption to "None" (or to the even more confusing "Default" value). I'm often tempted to remove these two settings.
Same with "Compression" settings - there are "Disable" and "None". Any difference between them?
I installed RT-N66U_3.0.0.4_376.49_2
and yet it tells me that ive got 3.0.0.4.376.45_0 installed?
This simply means that the installation/upgarde failed!
Typically this has one three reasons:
  1. Either there was not enough memory for doing the upgrade (remove the USB devices and reboot before you upgrade), ;)
  2. or it was the beginners errror 1: you did not unzipp the downloaded firmware (should be a .trx file), :rolleyes:
  3. or beginners error 2: wrong file downloaded (check carefully the router name). :o
With kind regards
Joe :cool:
NAT Acceleration
It seems that in 376.49 setting NAT Acceleration to Auto on my AC68U will show "CTF only" yet in 376.48 I could select "Level 2 CTF+FA" and it seemed to be enabled and working.
Was this a bug in the previous version, by showing CTF+FA but was only actually CTF? Or is there a problem in this version not allowing FA on AC68U?
The 2.4ghz band is broken for me. Laptop only connects at 54Mbps and Galaxy S4 connects at 13Mbps. I changed every setting and i cant get it past 54Mbps for laptop and 13Mbps on S4.
Turbo QAM no longer works either, unless you set Wireless Mode to "AUTO". But if you set it to "AUTO", then Galaxy S4 connects at 6Mbps regardless if Turbo QAM is ON or OFF.
At 40mhz, the connected speed is half of 20mhz for both devices.
Done speed test and full reset. All settings entered manually.
5Ghz band works fine.
With kind regards
Joe :cool:
lol out of those options it has to be #1!
kernel: SKIPPED false Type 2 Radar Detection. min_pw=268 pw_delta=0 pri=27628 fm_min=0 fm_max=0 nconsecq_pulses=3. Time from last detection = 475, = 7min 55sec. Detected pulse index: 0
Dec 25 12:22:27 kernel: Type 1 Radar Detection. Detected pulse index=6 fm_min=0 fm_max=0 nconsecq_pulses=3. Time from last detection = 10, = 0min 10sec
Dec 25 12:31:36 kernel: SKIPPED false Type 7 Radar Detection. min_pw=209 pw_delta=0 pri=4953 fm_min=1030 fm_max=0 nconsecq_pulses=4. Time from last detection = 344, = 5min 44sec. Detected pulse index: 8
ive been getting this in the log after the update. Anything to be worried about?
Anyone else having problems with the 2,4GHz radio dying on RT-N66U? Suddenly my 2,4GHz SSID disappears and I have to disable the radio and enable it again for it to appear.
Updated to this firmware today on my RT-AC87U. At the top of the GUI, where the SSID names are listed, my 2.4G SSID name is listed properly, and the 5G SSID is listed as 'undefined'. Everything seems to be working properly, and the 5G network can be seen with the correct name. Seems to just be a graphical bug.
same hear except 2.4 is labeled as "undefined"
Now im getting these messages after the update
Dec 25 16:07:05 crond[358]: time disparity of 2094666 minutes detected
Dec 25 16:29:17 kernel: SKIPPED false Type 1 Radar Detection. min_pw=12 pw_delta=0 pri=52679 fm_min=0 fm_max=0 nconsecq_pulses=3. Time from last detection = 1383, = 23min 3sec. Detected pulse index: 5
Dec 25 16:51:18 kernel: SKIPPED false Type 1 Radar Detection. min_pw=13 pw_delta=0 pri=52696 fm_min=0 fm_max=0 nconsecq_pulses=3. Time from last detection = 1320, = 22min 0sec. Detected pulse index: 5
Dec 25 17:07:18 kernel: SKIPPED false Type 1 Radar Detection. min_pw=14 pw_delta=0 pri=52638 fm_min=0 fm_max=0 nconsecq_pulses=3. Time from last detection = 960, = 16min 0sec. Detected pulse index: 5
Dec 25 17:11:18 kernel: SKIPPED false Type 1 Radar Detection. min_pw=14 pw_delta=0 pri=52724 fm_min=0 fm_max=0 nconsecq_pulses=3. Time from last detection = 240, = 4min 0sec. Detected pulse index: 5
Not using IPv6 since AT&T Uverse is unreliable with their current implementation. I use 100% static addresses assignment I leave a pool of 20 open just to bring on new devices. Oh well re-adding the statics took a while but fixed the issue.
Nothing else running I do have startup scripts that add a couple of hostnames to the DNSmasq for lookup purposes. Here is my top you can see nothing is using up a lot of memory httpd is the biggest consumer of 1.1% of physical.
 1  [                              0.0%]     Tasks: 66 total, 1 running
  2  [|                             0.7%]     Load average: 0.00 0.01 0.05
  Mem[|||||||||||||||||||||||  139/249MB]     Uptime: 17:32:42
  Swp[                             0/0MB]
  PID USER     PRI  NI  VIRT   RES   SHR S CPU% MEM%   TIME+  Command
  671 admin     20   0  6584  2736  1848 S  0.0  1.1  1:25.95 httpd
    1 admin     20   0  6184  1960  1620 S  0.0  0.8  0:08.25 /sbin/preinit
  931 admin     20   0  5532  1600  1444 S  0.0  0.6  0:00.08 /usr/sbin/smbd -D -s /etc/s
  614 admin     20   0  6168  1432  1132 S  0.0  0.6  0:00.81 /sbin/wanduck
  677 admin     20   0  6224  1364  1028 S  0.0  0.5  0:21.60 watchdog
  684 admin     20   0  6160  1316  1036 S  0.0  0.5  0:00.28 bwdpi_check
  890 admin     20   0  6160  1256   984 S  0.0  0.5  0:00.05 ntp
  930 admin     20   0  5328  1252  1132 S  0.0  0.5  0:00.45 nmbd -D -s /etc/smb.conf
  906 admin     20   0  6160  1236   964 S  0.0  0.5  0:00.30 disk_monitor
  680 admin     20   0  6160  1188   912 S  0.0  0.5  0:00.02 ots
  916 admin     20   0  2668  1176   848 S  0.0  0.5  0:01.02 avahi-daemon: running [RT-A
  643 admin     20   0  6160  1172   900 S  0.0  0.5  0:00.03 wpsaide
  324 admin     20   0  6152  1116   856 S  0.0  0.4  0:00.03 console
 2752 admin     20   0  1696   868   628 R  0.0  0.3  0:00.64 htop
  645 admin     20   0  2032   864   428 S  0.0  0.3  0:00.44 nas
 1769 admin     20   0  1768   840   500 S  0.0  0.3  0:03.07 rstats
  642 admin     20   0  2172   740   576 S  0.0  0.3  0:00.62 /bin/wps_monitor
 2723 nobody    20   0  1088   604   376 S  0.0  0.2  0:01.19 dnsmasq --log-async
  675 admin     20   0  1640   592   420 S  0.0  0.2  0:02.71 networkmap --bootwait
  736 admin     20   0  2536   592   424 S  0.0  0.2  0:00.02 u2ec
  743 admin     20   0  2536   592   424 S  0.0  0.2  0:00.12 u2ec
  744 admin     20   0  2536   592   424 S  0.0  0.2  0:00.00 u2ec
  674 admin     20   0  1528   480   396 S  0.0  0.2  0:00.16 /usr/sbin/infosvr br0
 2741 admin     20   0  1396   452   360 S  0.0  0.2  0:00.21 -sh
  738 admin     20   0  1600   448   364 S  0.0  0.2  0:00.02 lpd
  900 admin     20   0   800   428   328 S  0.0  0.2  0:13.46 miniupnpd -f /etc/upnp/conf
  326 admin     20   0  1392   412   328 S  0.0  0.2  0:00.01 /bin/sh
  638 admin     20   0  1556   404   312 S  0.0  0.2  0:00.36 /bin/eapd
  654 admin     20   0  1640   396   272 S  0.0  0.2  0:03.85 /usr/sbin/acsd
  673 admin     20   0  1396   364   276 S  0.0  0.1  0:00.09 crond
  634 admin     20   0  1388   352   272 S  0.0  0.1  0:00.04 telnetd
  687 admin     20   0  1572   352   224 S  0.0  0.1  0:00.00 lld2d br0
  892 admin     20   0  1400   348   252 S  0.0  0.1  0:00.04 udhcpc -i eth0 -p /var/run/
  335 admin     20   0  1384   332   264 S  0.0  0.1  0:10.75 syslogd -m 0 -S -O /tmp/sys
  635 admin     20   0  1060   304   236 S  0.0  0.1  0:00.00 dropbear -p 22 -j -k
  338 admin     20   0  1384   296   228 S  0.0  0.1  0:00.03 /sbin/klogd
  287 admin     20   0   664   244   200 S  0.0  0.1  0:00.13 hotplug2 --persistent --no-
  622 admin     20   0   652   176   136 S  0.0  0.1  3:40.40 tftpd
    2 admin     20   0     0     0     0 S  0.0  0.0  0:00.00 kthreadd
    3 admin     20   0     0     0     0 S  0.0  0.0  0:01.99 ksoftirqd/0
    4 admin     20   0     0     0     0 S  0.0  0.0  0:00.00 kworker/0:0
    6 admin     RT   0     0     0     0 S  0.0  0.0  0:01.26 migration/0
    7 admin     RT   0     0     0     0 S  0.0  0.0  0:01.18 migration/1
    8 admin     20   0     0     0     0 S  0.0  0.0  0:00.00 kworker/1:0
    9 admin     20   0     0     0     0 S  0.0  0.0  0:00.69 ksoftirqd/1
   10 admin      0 -20     0     0     0 S  0.0  0.0  0:00.00 khelper
  252 admin     20   0     0     0     0 S  0.0  0.0  4:01.24 mtdblock3
  274 admin     20   0     0     0     0 S  0.0  0.0  0:00.40 kworker/0:1
  275 admin     20   0     0     0     0 S  0.0  0.0  2:24.25 kworker/1:1
  278 admin     20   0     0     0     0 S  0.0  0.0  0:00.00 mtdblock4
  344 admin     20   0     0     0     0 S  0.0  0.0  0:00.00 khubd
  488 admin     20   0     0     0     0 S  0.0  0.0  0:00.75 usb-storage
  332 admin     30  10     0     0     0 S  0.0  0.0  0:00.12 jffs2_gcd_mtd4
    5 admin     20   0     0     0     0 S  0.0  0.0  0:00.02 kworker/u:0
Here is my DF tmp isn't using much either....is tmpfs static or dynamic? It does show 124.9M as the size.
Filesystem                Size      Used Available Use% Mounted on
/dev/root                35.0M     35.0M         0 100% /
devtmpfs                124.8M         0    124.8M   0% /dev
tmpfs                   124.9M      9.3M    115.6M   7% /tmp
/dev/mtdblock4           62.8M      2.0M     60.7M   3% /jffs
/dev/sda2                10.9G      3.6G      6.7G  35% /tmp/mnt/data1
/dev/sda1                 3.8G    421.9M      3.3G  11% /tmp/mnt/optware
/dev/sda1                 3.8G    421.9M      3.3G  11% /tmp/opt
it wasn't. The BCM4708A used by the RT-AC68U does not support FA.
It's DFS doing what it's meant to do: ensure that the 5 GHz channel you are using does not conflict with nearby radars that use the same band. Looks like Asus left logging enabled for it - or at least it's the first time someone posts DFS log entries.
