jeff288
I've upgraded to ver. 380.59 and quickly noticed that I'm not getting the full speed in my connections.
Currently I have a Gig connection with speedtest results ranging from 900 Mbps - 974 Mbps.
The firmware 380.59 beta appeared to work fine and then once it came out of beta I updated the new 380.59 firmware and noticed my speeds maxed out at 500-600 Mbps.
Speeds went back to normal when I directly wired into my PC and bypassed the router.
I factory reset the 380.59 release and tweaked a few settings and get the same 500-600 Mbps results.
The only solution I've found so far was to downgrade to 380.58 as it works fine.
Just a heads up! Any possible solutions?
At those speeds, make sure CTF is enabled. Also it's usually helpful to mention the router you have.
Dat ping! Dem speeds! Ummph!
