Asuswrt-Merlin 380.59 is now available
Uptime 6 days 18 hours 26 minute(s) 31 seconds
RT-AC5300
May 13 23:08:20 disk_monitor: Got SIGALRM...
I have disabled all disk functions from day one, what is this?
Normal the first day when you just flashed your router.Its a scan for usb device
May 20 08:24:28 rc_service: httpd 524:notify_rc restart_wlcscan
I did a search and found some reference to changing the Preamble Type to short is the fix, not sure if it will?
Normal, you have performed a manual "Survey scan" in Wireless Section
I did not reboot the router yet, all I did was change the preamble to short so far.
If I see the problem again I will revert back to the alpha (I have it) and test further.
May 18 02:00:13 rc_service: rc 9243:notify_rc restart_wrs
Log from TrendMicro engine, but im not sure
I noticed the same thing. It's consistently a little slower. I ran multiple speed tests from different sites and never got above ~700 Mbps download until I reverted back to .58. RT-AC68P.
380.58 Speeds:
380.59 Speeds:
This doesn't look good. Hopefully a fix can be found
Has anyone else had problems with SMB shares with this release? I upgraded from .57 to .59 and now am unable to access my SMB share from my Windows 7 boxes:
Strangely, I can still access the share fine from my Android devices. If I flash .57 back, the problem disappears. I have not changed any settings.
@RMerlin that Samba issue I posted about back in the 380.59 beta thread with my RT-AC68P has come back three times now. It is very strange. I just saw @knubbze post about an issue and I saw that somebody else recently created a thread about samba issues, so I figured I would post again to see if you had any ideas.
Switched from 380.1842 to 380.58 and NAS speed went from 50/30 to 21/4. Switched to 380.2695 and the speed immediately went back to 50/30. Switched to 380.59 beta 2 and NAS speed dropped again. Spent a night switching between various versions to try and track down when the issue started but it stayed at 21/4 even when going back to 380.2695 until a reboot of the router magically fixed it. Switched back to 380.59 beta 2 and it was about 40/20. Switched to 380.59 and it went back up to 50/30. About 5 days later, it fell to 21/4. I rebooted the router but it stayed at 21/4. Rebooted WINDOWS and it went back to 50/30. Another few days later it fell to 21/4. Rebooted windows and it went back up to 50/30. Now it has been a few days and it suddenly dropped to 21/4 again. I was thinking maybe an issue with my machine except it seems directly tied to the Merlin branch and I see others posting about Samba strangeness. Also, the wireless speed is completely unaffected from this windows box, only the Samba speed and when the issue happens, connecting through a wired connection fixes it but going back to wireless without a reboot does not. I also tried switching from 5.0 to 2.4 while the issue is happening and NAS speed dropped to 10/3. Some type of incompatibility between Windows and something introduced in 380.58?
Up and running for 5 days now with no issues on RT-AC87R with 380.59. Smooth upgrade from the previous release. Only thing I am not going to do is re-enabled IPv6 on AT&T's UVERSE service due to their unreliable tunneling in the network.
Hi, I'm trying to understand where is my fault, but I'm not able to upload 380.59 on AC68U:(. I Really need local dns service, thanks for
suggest☺
16.05.22 hi forum, is there anybody with an idea for my problem please? Many thanks.
I believe it may be a bug. For a temp fix, I've found that:
LAN > Switch Control > NAT Acceleration
Initially for me, after factory reset, upgrading, and downgrading it only states:
CTF(Cut Through Forwarding) is enabled.
I max out at 600-700 Mbps
Disabling Nat Acceleration yields 250 Mbps on speed test.
Re-enabling Nat Acceleration after disabling then changes:
to
CTF(Cut Through Forwarding) and FA(Flow Acceleration) accelerator are enabled.
The key being "FA(Flow Acceleration)" as enabled. Not sure what it is, but when that message shows I then begin to see my normal 1 gig speeds on speed test.
I know this is for ASUS routers only and I'm using XVortex on the R7000, but has anyone noticed a power drain on his/her smartphone/tablet when on this FW version? I have a Galaxy J5 phone and found out that on the wireless log it's constantly switching between powersave and normal mode (PSTAU vs STAU) back and forth. If I flash the previous .58 version of XVortex, the powerdrain goes away and the device, according to logs, stays in powersave mode like virtually all the time... so I have no choice but to use .58 for the time being.
Had the firmware 59. alpha 2 on the asus rt-ac88u run without problems. Now runs the firmware 59. and I have with all apple mobile phones problems quickly drain the batteries.
There are more people who have the same problem.
I have battery drain on my samsung tablet. It's bad. I can go to bed at 10pm and the tablet will lose all power by morning.
to
Disable/Re-enable, I do not see FA, still just CTF
Yes there is.. I mentioned it a few pages back as well.
I too cannot see "FA" it still shows CTF. I have followed the steps listed in the link to the other thread describing how to but still no luck. I have tried it 2x.
Me too, I know I had this working when I first got the router and flashed it with merlins.
I just flashed, cleared NVRAM, disabled QOS and Spanning tree, power off the router after turning off NAT acceleration turned back on , rebooted and still nothing.
Must be some setting doing it.....
Are there any plans on supporting the 4G-AC55U modem/router? I'm getting fcked by bufferbloat on my Huaweii e5183 and looking for a replacement one in all solution and would like to avoid having to use a router and bridge modem combo...
Gesendet von meinem SM-G920F mit Tapatalk
http://asuswrt.lostrealm.ca/about
Merlin supports routers , not modem / routers.
Have it working now CTF (Cut Through Forwarding) and FA (Flow Acceleration) are both enabled. Spanning-Tree Protocol is disabled. What i had to do was turn off "parental controls". I then disabled NAT Acceleration and power cycled router. Then put NAT Acceleration back to "Auto" and power cycled router. This is on RT-AC87R.
Why is it such a PITA to enable this?
I don't use parental controls.
I did turn off ST and QOS and disabled NAT , power cycled and then re enabled NAT and still no go.
must be some other setting i have??
