Release Asuswrt-Merlin 386.12_6 is now available for AC models
Not at the moment. I'm already using newer GPL than the stock firmware for multiple models, I'm in no hurry to merging a newer one. The 386 platform is a legacy one, and won't get as active development as the 388 branch. The next major release will most likely be the final release for the SDK 7 models (RT-AC88U, RT-AC3100 and RT-AC5300) as these have already been EOL by Asus for a few months now.
I was just wondering whether a newer GPL wouldn't perhaps fix some of the issues reported lately for the AC models (i.e. when using 386.9 - 386.11 based on GPL 50757 and 386.12 based on GPL 51997).
That one's on my bookmarked list of things to track already
Thank you. I remember reporting to Asus broken things around QoS with IPv6 enabled, but it was with the previous firmware release. I believe the bugs are still present after Trend Micro quick fix release. Will bring home one RT-AC68U next week and run the tests again. I know it's in closed source part and Asus has to look at it, eventually.
Are the wifi issues present in 386.12_2/4 but not in 386.12 fixed with this release on RT-AC68U???
This is the only change since 386.12_4:
386.12_6 (26-Feb-2024)
- UPDATED: dnsmasq to 2.90 (resolves CVE 2023-50868 and CVE 2023-50387).
Unrelated to Wi-Fi. Please, read the first post of this very same thread.
Somehow amtm and Diversion major upgrades (December 2023), which e.g. disabled uiDivStats and removed pixelserv-tls, fixed my serious radio problems which I faced with earlier Merlin firmware versions 386.12_2/4. Of course I have no real proof of this. But my wifi has been up and running very reliably since the amtm and Diversion upgrades.
Haven't got any wifi issues after updating to fw 386.12_6 either. Uptime 3 days 12 hours.
15:25:58 kernel: Pid: 1700, comm: wred
Mar 4 15:25:58 kernel: CPU: 0 Tainted: P (2.6.36.4brcmarm #1)
Mar 4 15:25:58 kernel: PC is at 0x40085a8c
Mar 4 15:25:58 kernel: LR is at 0x401547ac
Mar 4 15:25:58 kernel: pc : [<40085a8c>] lr : [<401547ac>] psr: 80000010
Mar 4 15:25:58 kernel: sp : bd5ffdf0 ip : 4015df60 fp : bd5ffe6c
Mar 4 15:25:58 kernel: r10: 40162020 r9 : 401623dc r8 : 00000000
Mar 4 15:25:58 kernel: r7 : 000000b3 r6 : bd5ffea0 r5 : bd5ffe00 r4 : 4015dd74
Mar 4 15:25:58 kernel: r3 : 00000000 r2 : 80000000 r1 : 00000008 r0 : fffffdfe
Mar 4 15:25:58 kernel: Flags: Nzcv IRQs on FIQs on Mode USER_32 ISA ARM Segment user
Mar 4 15:25:58 kernel: Control: 10c53c7d Table: 9cf8804a DAC: 00000015
A few of the above in the log today. What is wred?
You also forget to mention which version you are upgrading from, if you had prior issues etc. Not much to work with, floods the thread with nonsense.
Upgraded from 12_4. No prior issues. 5 days uptime on 12_6, with no issues.
I don’t consider thanking the person who works hard on this project as “nonsense”, but I appreciate your feedback.
The saga continues. After 6 days of stable operation, my AC86U crashed again.
BUT this time I actually managed to connect by wire and extract some interesting logs!
Context:
When I connected via ethernet in my wired Aimesh node and accessed the Asus Web-interface, I could see that:
  • all the wireless clients on all 3 Aimesh nodes (1 wired, 2 wireless) had no clients connected (this happened as a result of the crash).
  • Only the AC86U (main) had wireless clients connected
Background:
I had connection drops with .12 and downgraded to .11. After over a week of seemingly stable operation with .11, it crashed just like in this case (but I couldn't get the logs), and now .10 crashed with this log.
Possible cause?:
The only remotely possible cause I can think of is that I remember a long time ago connecting through Putty and entering some code in order to save the logs between reboots in the routers internal partition. But I have set "Enable JFFS custom scripts and configs" to "No", so that would disable such a script anyways? Besides, I don't see a steady buildup of RAM usage until crash. So I doubt this has anything to do with the issue.
Factory reset is unfortunately hard to do in this environment, so it is not something I can easily attempt, partly because of a know issue with AC66U_B1 routers that refuse to pair with Aimesh, so I cannot afford the risk of erasing its current pairing with the AC86U main.
Log (had to split it in two messages because of limit):
Mar 5 13:56:12 kernel: hotplug triggered out of memory codition (oom killer not called): gfp_mask=0x201da, order=0, oom_score_adj=0
Mar 5 13:56:14 kernel: CPU: 0 PID: 27065 Comm: hotplug Tainted: P O 4.1.27 #2
Mar 5 13:56:14 kernel: Hardware name: Broadcom-v8A (DT)
Mar 5 13:56:14 kernel: Call trace:
Mar 5 13:56:14 kernel: [<ffffffc0000876d8>] dump_backtrace+0x0/0x150
Mar 5 13:56:14 kernel: [<ffffffc00008783c>] show_stack+0x14/0x20
Mar 5 13:56:14 kernel: [<ffffffc000508bf8>] dump_stack+0x90/0xb0
Mar 5 13:56:14 kernel: [<ffffffc000100198>] __out_of_memory.isra.4+0xc8/0x238
Mar 5 13:56:14 kernel: [<ffffffc000100698>] out_of_memory+0x48/0x68
Mar 5 13:56:14 kernel: [<ffffffc0001045a8>] __alloc_pages_nodemask+0x610/0x6a0
Mar 5 13:56:14 kernel: [<ffffffc0000ff254>] filemap_fault+0x15c/0x3c0
Mar 5 13:56:14 kernel: [<ffffffc00011cc0c>] __do_fault+0x34/0x90
Mar 5 13:56:14 kernel: [<ffffffc000120fc4>] handle_mm_fault+0xa04/0x1178
Mar 5 13:56:14 kernel: [<ffffffc00008fd84>] do_page_fault+0x1d4/0x260
Mar 5 13:56:14 kernel: [<ffffffc000080aa0>] do_mem_abort+0x40/0x98
Mar 5 13:56:14 kernel: Exception stack(0xffffffc003d33e30 to 0xffffffc003d33f50)
Mar 5 13:56:14 kernel: 3e20: 00400000 00000000 00000000 00000000
Mar 5 13:56:14 kernel: 3e40: ffffffff ffffffff f735882c 00000000 f6cb0000 00000000 00000011 00000000
Mar 5 13:56:14 kernel: 3e60: 00000184 00000000 0000007d 00000000 00516000 ffffffc0 03d30000 ffffffc0
Mar 5 13:56:14 kernel: 3e80: 00000000 00000000 00084470 ffffffc0 03d33eb0 ffffffc0 00087228 ffffffc0
Mar 5 13:56:14 kernel: 3ea0: 00400008 00000000 f7365bec 00000000 00000000 00000000 00084354 ffffffc0
Mar 5 13:56:14 kernel: 3ec0: 00400000 00000000 190f8178 ffffffc0 00000259 00000000 0006808c 00000000
Mar 5 13:56:14 kernel: 3ee0: f6df7394 00000000 f6db0004 00000000 f6da7000 00000000 f7374ac0 00000000
Mar 5 13:56:14 kernel: 3f00: 00001588 00000000 f737c000 00000000 f6db1234 00000000 f737bce8 00000000
Mar 5 13:56:14 kernel: 3f20: f6db14f4 00000000 fffd8234 00000000 f737c560 00000000 fffd8170 00000000
Mar 5 13:56:14 kernel: 3f40: f7357ea4 00000000 00000000 00000000
Mar 5 13:56:14 kernel: Mem-Info:
Mar 5 13:56:14 kernel: active_anon:41558 inactive_anon:452 isolated_anon:0
Mar 5 13:56:14 kernel: active_file:0 inactive_file:0 isolated_file:0
Mar 5 13:56:14 kernel: unevictable:0 dirty:0 writeback:0 unstable:0
Mar 5 13:56:14 kernel: slab_reclaimable:494 slab_unreclaimable:32937
Mar 5 13:56:14 kernel: mapped:120 shmem:951 pagetables:720 bounce:0
Mar 5 13:56:14 kernel: free:5915 free_pcp:265 free_cma:0
Mar 5 13:56:14 kernel: DMA free:23660kB min:20480kB low:25600kB high:30720kB active_anon:166232kB inactive_anon:1808kB active_file:0kB inactive_file:0kB unevictable:0kB isolated(anon):0kB isolated(file):0kB present:481280kB managed:426020kB mlocked:0kB dirty:0kB writeback:0kB mapped:404kB shmem:3804kB slab_reclaimable:1976kB slab_unreclaimable:131748kB kernel_stack:7536kB pagetables:2880kB unstable:0kB bounce:0kB free_pcp:1064kB local_pcp:704kB free_cma:0kB writeback_tmp:0kB pages_scanned:716 all_unre
Mar 5 13:56:14 kernel: lowmem_reserve[]: 0 0 0
Mar 5 13:56:14 kernel: DMA: 1414*4kB (UEM) 971*8kB (UEM) 85*16kB (UEM) 23*32kB (UER) 2*64kB (R) 0*128kB 1*256kB (R) 1*512kB (R) 1*1024kB (R) 1*2048kB (R) 1*4096kB (R) = 23584kB
Mar 5 13:56:14 kernel: 983 total pagecache pages
Mar 5 13:56:14 kernel: 0 pages in swap cache
Mar 5 13:56:14 kernel: Swap cache stats: add 0, delete 0, find 0/0
Mar 5 13:56:14 kernel: Free swap = 0kB
Mar 5 13:56:14 kernel: Total swap = 0kB
Mar 5 13:56:14 kernel: 120320 pages RAM
Mar 5 13:56:14 kernel: 0 pages HighMem/MovableOnly
Mar 5 13:56:14 kernel: 13815 pages reserved
Mar 5 13:56:14 kernel: [ pid ] uid tgid total_vm rss nr_ptes nr_pmds swapents oom_score_adj name
Mar 5 13:56:14 kernel: [ 285] 0 285 4627 21 6 2 0 0 swmdk
Mar 5 13:56:14 kernel: [ 292] 0 292 392 12 3 2 0 0 wdtctl
Mar 5 13:56:14 kernel: [ 296] 0 296 428 15 5 2 0 0 hotplug2
Mar 5 13:56:14 kernel: [ 299] 0 299 438 20 5 2 0 0 envrams
Mar 5 13:56:14 kernel: [ 1029] 0 1029 2959 94 9 2 0 0 PS_pod
Mar 5 13:56:14 kernel: [ 1033] 0 1033 831 21 4 2 0 0 syslogd
Mar 5 13:56:14 kernel: [ 1035] 0 1035 831 23 5 2 0 0 klogd
Mar 5 13:56:14 kernel: [ 1100] 0 1100 2959 105 9 2 0 0 wanduck
Mar 5 13:56:14 kernel: [ 1132] 0 1132 2716 138 10 2 0 0 asd
Mar 5 13:56:14 kernel: [ 1137] 0 1137 3393 89 11 2 0 0 nt_monitor
Mar 5 13:56:14 kernel: [ 1138] 0 1138 594 169 5 2 0 0 haveged
Mar 5 13:56:14 kernel: [ 1140] 0 1140 1453 49 6 2 0 0 protect_srv
Mar 5 13:56:14 kernel: [ 1141] 0 1141 3471 93 8 2 0 0 netool
Mar 5 13:56:14 kernel: [ 1151] 0 1151 2873 99 9 2 0 0 nt_center
Mar 5 13:56:14 kernel: [ 1161] 0 1161 734 46 4 2 0 0 eapd
Mar 5 13:56:14 kernel: [ 1163] 0 1163 2959 94 9 2 0 0 wpsaide
Mar 5 13:56:14 kernel: [ 1164] 0 1164 1166 54 6 2 0 0 wlc_nt
Mar 5 13:56:14 kernel: [ 1165] 0 1165 982 192 6 2 0 0 nas
Mar 5 13:56:14 kernel: [ 1170] 0 1170 1723 76 7 2 0 0 bsd
Mar 5 13:56:14 kernel: [ 1178] 0 1178 1261 58 6 2 0 0 wlceventd
Mar 5 13:56:14 kernel: [ 1184] 0 1184 1253 33 5 2 0 0 nt_actMail
Mar 5 13:56:14 kernel: [ 1191] 0 1191 783 58 4 2 0 0 acsd
Mar 5 13:56:14 kernel: [ 1193] 0 1193 725 33 4 2 0 0 dhd_monitor
Mar 5 13:56:14 kernel: [ 1204] 0 1204 831 25 6 2 0 0 crond
Mar 5 13:56:14 kernel: [ 1205] 0 1205 2722 382 9 2 0 0 httpds
Mar 5 13:56:14 kernel: [ 1206] 0 1206 2790 455 9 2 0 0 httpd
Mar 5 13:56:14 kernel: [ 1208] 0 1208 1356 67 6 2 0 0 vis-dcon
Mar 5 13:56:14 kernel: [ 1211] 0 1211 1204 56 7 2 0 0 vis-datacollect
Mar 5 13:56:14 kernel: [ 1212] 0 1212 1744 75 8 2 0 0 infosvr
Mar 5 13:56:14 kernel: [ 1214] 0 1214 1299 504 7 2 0 0 sysstate
Mar 5 13:56:14 kernel: [ 1215] 0 1215 2959 114 9 2 0 0 watchdog
Mar 5 13:56:14 kernel: [ 1216] 0 1216 2959 94 9 2 0 0 check_watchdog
continued...
Mar 5 13:56:14 kernel: [ 1217] 65534 1217 808 85 6 2 0 0 avahi-daemon
Mar 5 13:56:14 kernel: [ 1218] 0 1218 2959 100 10 2 0 0 amas_lanctrl
Mar 5 13:56:14 kernel: [ 1221] 0 1221 1071 432 5 2 0 0 rstats
Mar 5 13:56:14 kernel: [ 1237] 0 1237 805 53 6 2 0 0 lld2d
Mar 5 13:56:14 kernel: [ 1244] 0 1244 6252 127 15 2 0 0 vis-dcon
Mar 5 13:56:14 kernel: [ 1250] 0 1250 11111 8854 27 2 0 0 networkmap
Mar 5 13:56:14 kernel: [ 1253] 0 1253 2781 156 9 2 0 0 mastiff
Mar 5 13:56:14 kernel: [ 1254] 0 1254 2959 94 10 2 0 0 bwdpi_check
Mar 5 13:56:14 kernel: [ 1256] 0 1256 2960 105 8 2 0 0 pctime
Mar 5 13:56:14 kernel: [ 1311] 0 1311 5239 133 13 2 0 0 roamast
Mar 5 13:56:14 kernel: [ 1315] 0 1315 22675 18663 47 2 0 0 conn_diag
Mar 5 13:56:14 kernel: [ 1325] 0 1325 829 41 5 2 0 0 lldpd
Mar 5 13:56:14 kernel: [ 1329] 65534 1329 829 43 5 2 0 0 lldpd
Mar 5 13:56:14 kernel: [ 1338] 0 1338 23505 5250 50 2 0 0 cfg_server
Mar 5 13:56:14 kernel: [ 1365] 0 1365 3831 260 11 2 0 0 amas_lib
Mar 5 13:56:14 kernel: [ 1374] 0 1374 592 23 5 2 0 0 dropbear
Mar 5 13:56:14 kernel: [ 1436] 0 1436 2959 97 9 2 0 0 usbled
Mar 5 13:56:14 kernel: [ 1437] 0 1437 1990 56 6 2 0 0 usbmuxd
Mar 5 13:56:14 kernel: [ 1441] 0 1441 2959 95 10 2 0 0 pc_block
Mar 5 13:56:14 kernel: [ 1532] 0 1532 920 31 6 2 0 0 ntp
Mar 5 13:56:14 kernel: [ 1538] 0 1538 479 66 5 2 0 0 mcpd
Mar 5 13:56:14 kernel: [ 1567] 0 1567 2959 99 9 2 0 0 disk_monitor
Mar 5 13:56:14 kernel: [ 1598] 0 1598 1644 83 6 2 0 0 vpnserver1
Mar 5 13:56:14 kernel: [ 1600] 0 1600 1644 76 6 2 0 0 vpnserver1
Mar 5 13:56:14 kernel: [ 1680] 0 1680 603 48 4 2 0 0 miniupnpd
Mar 5 13:56:14 kernel: [ 1723] 0 1723 3369 742 10 2 0 0 wred
Mar 5 13:56:14 kernel: [ 1777] 0 1777 2959 99 10 2 0 0 bwdpi_wred_aliv
Mar 5 13:56:14 kernel: [ 1839] 0 1839 831 22 5 2 0 0 udhcpc
Mar 5 13:56:14 kernel: [ 1852] 65534 1852 690 102 5 2 0 0 dnsmasq
Mar 5 13:56:14 kernel: [ 1853] 0 1853 658 59 5 2 0 0 dnsmasq
Mar 5 13:56:14 kernel: [ 1870] 0 1870 464 31 4 2 0 0 wsdd2
Mar 5 13:56:14 kernel: [ 1871] 0 1871 2372 106 8 2 0 0 nmbd
Mar 5 13:56:14 kernel: [ 1872] 0 1872 2442 94 8 2 0 0 smbd
Mar 5 13:56:14 kernel: [ 1873] 0 1873 2366 31 7 2 0 0 nmbd
Mar 5 13:56:14 kernel: [ 1173] 0 1173 1275 27 6 2 0 0 AiProtectionMon
Mar 5 13:56:14 kernel: [ 1167] 0 1167 2959 91 8 2 0 0 dhcpc_lease
Mar 5 13:56:14 kernel: [ 1139] 0 1139 831 13 5 2 0 0 sh
Mar 5 13:56:14 kernel: [ 1142] 0 1142 876 15 5 2 0 0 wl
Mar 5 13:56:14 kernel: [20033] 0 20033 2349 104 8 2 0 0 asusdiscovery
Mar 5 13:56:14 kernel: [24789] 0 24789 428 15 5 2 0 0 hotplug2
Mar 5 13:56:14 kernel: [24792] 0 24792 2959 97 8 2 0 0 hotplug
Mar 5 13:56:14 kernel: [24806] 0 24806 428 15 5 2 0 0 hotplug2
Mar 5 13:56:14 kernel: [24809] 0 24809 2959 97 8 2 0 0 hotplug
Mar 5 13:56:14 kernel: [24869] 0 24869 428 15 5 2 0 0 hotplug2
Mar 5 13:56:14 kernel: [24870] 0 24870 2959 96 9 2 0 0 hotplug
Mar 5 13:56:14 kernel: [24905] 0 24905 428 15 5 2 0 0 hotplug2
Mar 5 13:56:14 kernel: [24907] 0 24907 2959 96 8 2 0 0 hotplug
Mar 5 13:56:14 kernel: [27059] 0 27059 428 17 5 2 0 0 hotplug2
Mar 5 13:56:14 kernel: [27063] 0 27063 428 17 5 2 0 0 hotplug2
Mar 5 13:56:14 kernel: [27064] 0 27064 2926 280 7 2 0 0 hotplug
Mar 5 13:56:14 kernel: [27065] 0 27065 2929 81 7 2 0 0 hotplug
Mar 5 13:56:14 kernel: [27097] 0 27097 428 17 5 2 0 0 hotplug2
Mar 5 13:56:14 kernel: [27098] 0 27098 2929 87 8 2 0 0 hotplug
Mar 5 13:56:14 kernel: [27103] 0 27103 831 18 6 2 0 0 sh
Mar 5 13:56:14 kernel: [27114] 0 27114 797 13 4 2 0 0 touch
Mar 5 13:56:14 kernel: [27130] 0 27130 797 14 4 2 0 0 vpn-watchdog1.s
Mar 5 13:56:14 kernel: [27133] 0 27133 2372 46 7 2 0 0 nmbd
[/CODE]
Lots of log entries like "Assoc, Disassoch, Auth, Deauth_ind" etc... - from 13:56:14 to 14:03:59, for example:
wlceventd: wlceventd_proc_event(511): eth5:
dnsmasq-dhcp[1852]: DHCPDISCOVER(br0)
Then, the router reboots:
May 5 07:05:07 syslogd started: BusyBox v1.25.1
May 5 07:05:07 kernel: klogd started: BusyBox v1.25.1 (2023-03-10 16:22:52 EST)
May 5 07:05:07 kernel: Booting Linux on physical CPU 0x0
etc...
Then I had to log in via an ethernet connected computer, save the log, and then reboot the router. After reboot, everything works stable (until the next crash a week+ after).
I do not have a USB device attached.
@heywire It's some sort of memory leak related to hotplug, very interesting. Perhaps @RMerlin can tell us more.
This comes to mind: https://www.snbforums.com/threads/usb-hotplug-event.81708/
Hotplug isn`t necessarily the source of the leak. It just happens to be the process that tried to run, and there wasn't enough free memory for it to launch, causing it to crash.
I would first check that /tmp isn't getting filled by something, eating up all available memory.
I will keep taps on it in the coming days.
I guess nothing seems out of the ordinary right off the bat...?. How much do you expect /tmp/ to fill up before it looks like something is fishy?
admin@RT-AC86U-[XXXX]:/tmp# du -sh /tmp
2.8M /tmp
ASUSWRT-Merlin RT-AC86U 386.10_0 Fri Mar 10 21:22:55 UTC 2023
admin@RT-AC86U-XXXX:/tmp# ls -lh
-rw-r--r-- 1 admin root 31 Mar 5 14:21 AA:BB:CC:11:22:33.bi
-rw-r--r-- 1 admin root 172 Mar 5 14:21 AA:BB:CC:11:22:33.cap
-rw-r--r-- 1 admin root 360 Mar 5 14:21 AA:BB:CC:11:22:33.json
-rw-r--r-- 1 admin root 59 Mar 5 17:56 AA:BB:CC:11:22:33.port
-rw-r--r-- 1 admin root 31 May 5 2018 DD:EE:FF:44:55:66.bi
-rw-r--r-- 1 admin root 172 Mar 5 14:53 DD:EE:FF:44:55:66.cap
-rw-r--r-- 1 admin root 441 Mar 5 14:53 DD:EE:FF:44:55:66.json
-rw-r--r-- 1 admin root 31 May 5 2018 GG:HH:II:77:88:99.bi
-rw-r--r-- 1 admin root 71 May 5 2018 GG:HH:II:77:88:99.cap
-rw-r--r-- 1 admin root 31 Mar 5 14:22 JJ:KK:LL:00:11:22.bi
-rw-r--r-- 1 admin root 172 Mar 5 14:22 JJ:KK:LL:00:11:22.cap
-rw-r--r-- 1 admin root 441 Mar 5 14:22 JJ:KK:LL:00:11:22.json
-rw-rw-rw- 1 admin root 791 Mar 5 17:56 MON_CHECK_
-rw-r--r-- 1 admin root 782 Mar 5 17:55 allwclientlist.json
-rw-r--r-- 1 admin root 325 Mar 5 14:22 aplist.json
-rw-rw-rw- 1 admin root 0 May 5 2018 asd.init
drwxrwxrwx 2 admin root 80 May 5 2018 asdfile
drwxrwxrwx 2 admin root 60 May 5 2018 asusdebuglog
drwxrwxrwx 2 admin root 40 May 5 2018 asusfbsvcs
drwxrwxrwx 3 admin root 80 May 5 2018 avahi
drw-rw-rw- 3 admin root 480 Mar 5 14:35 bwdpi
-rw-r--r-- 1 admin root 1.5K Mar 5 14:54 chanspec_all.json
-rw-r--r-- 1 admin root 217 Mar 5 14:54 chanspec_avbl.json
-rw-rw-rw- 1 admin root 161 Mar 5 14:53 chanspec_avbl.txt
-rw-r--r-- 1 admin root 334 Mar 5 14:54 chanspec_private.json
-rw-r--r-- 1 admin root 1.4K Mar 5 17:56 clientlist.json
drwxr-xr-x 3 admin root 60 Jan 1 1970 confmtd
-rw-r--r-- 1 admin root 181 Mar 5 17:56 current_wired_client_list.json
drwx------ 2 admin root 60 Mar 5 17:56 db
-rw-rw-rw- 1 admin root 2.9K Mar 5 17:56 dev
lrwxrwxrwx 1 admin root 8 May 5 2018 dhcp6c -> /sbin/rc
drwxrwxrwx 4 admin root 80 Mar 5 14:22 diag_db_cloud
-r-s-wx--T 1 admin root 0 May 5 2018 ebtables.lock
drwxr-xr-x 12 admin root 1.6K Mar 5 14:21 etc
-rw-rw-rw- 1 admin root 888 May 5 2018 filter.default
-rw-rw-rw- 1 admin root 383 May 5 2018 filter_ipv6.default
-rw-rw-rw- 1 admin root 5.0K Mar 5 14:21 filter_rules
-rw-rw-rw- 1 admin root 92 May 5 2018 guest_vsie
drwxr-xr-x 3 admin root 60 Jan 1 1970 home
-rw-rw-rw- 1 admin root 14 Mar 5 17:56 hw_auth_clm
drwxr-xr-x 2 admin root 40 Jan 1 1970 inadyn.cache
-rw-rw-rw- 1 admin root 64 May 5 2018 lld2d.conf
-rw-rw-rw- 1 admin root 71 May 5 2018 lldpd_bind_ifnames
-rw-r--r-- 1 admin root 83 Mar 5 17:56 maclist.json
-rw-rw-rw- 1 admin root 5 May 5 2018 mastiff.pid
-rw-rw-rw- 1 admin root 0 May 5 2018 mastiff_log
drwxrwxrwx 2 admin root 40 Jan 1 1970 mnt
lrwxrwxrwx 1 admin root 24 Mar 5 14:21 nat_rules -> /tmp/nat_rules_eth0_eth0
-rw-rw-rw- 1 admin root 819 Mar 5 14:21 nat_rules_eth0_eth0
drwxrwxrwx 2 admin root 180 Mar 5 14:22 nc
drwxrwxrwx 2 admin root 40 May 5 2018 netool
-rw-r--r-- 1 admin root 12.2K Mar 5 17:45 nmp_cache.js
drwxr-xr-x 3 admin root 60 Jan 1 1970 notify
-rw-rw-rw- 1 admin root 1 May 5 2018 obstatus
-rw-rw-rw- 1 admin root 92 May 5 2018 obvsie
drwxrwxrwx 3 admin root 260 May 5 2018 ppp
srwxrwxrwx 1 admin root 0 May 5 2018 ps_sock
-rwxr-xr-x 1 admin root 724 Mar 5 14:21 qos
-rw-rw-rw- 1 admin root 54 Mar 5 14:53 rast_stc_idx0
-rw-rw-rw- 1 admin root 54 Mar 5 14:53 rast_stc_idx1
-rw-rw-rw- 1 admin root 989 Mar 5 14:21 redirect_rules
-rw-rw-rw- 1 admin root 107 Feb 27 05:37 release_note0.txt
-rw-r--r-- 1 admin root 357 May 5 2018 relist.json
-rw-r--r-- 1 admin root 50 May 5 2018 resolv.conf
-rw-r--r-- 1 admin root 104 May 5 2018 resolv.dnsmasq
-rw-rw-rw- 1 admin root 295 May 5 2018 run_lldpd.sh
-rw-r--r-- 1 admin root 0 Jan 1 1970 settings
drwxr-xr-x 2 admin root 40 Jan 1 1970 share
-rw-rw-rw- 1 admin root 205 Mar 5 14:23 sig_upgrade.log
-rw-rw-rw- 1 admin root 0 Mar 5 15:56 syscmd.log
-rw-rw-rw- 1 admin root 193.0K Mar 5 17:56 syslog.log
-rw-rw-rw- 1 admin root 256.0K May 5 2018 syslog.log-1
-rw-rw-rw- 1 admin root 10 Mar 5 17:32 udhcpc0.expires
lrwxrwxrwx 1 admin root 8 May 5 2018 udhcpc_wan -> /sbin/rc
-rw-rw-rw- 1 admin root 270 Mar 5 17:51 usb.log
drwxr-xr-x 4 admin root 80 Jan 1 1970 var
-rw-rw-rw- 1 admin root 495 May 5 2018 wan0_bound.env
-rw-rw-rw- 1 admin root 0 Mar 5 17:56 watchdog_heartbeat
-rw-r--r-- 1 admin root 725 Mar 5 14:54 wchannel.json
-rw-rw-rw- 1 admin root 194 Mar 5 14:23 webs_upgrade.log
-rw-r--r-- 1 admin root 434 Mar 5 17:56 wiredclientlist.json
lrwxrwxrwx 1 admin root 8 May 5 2018 wpa_cli -> /sbin/rc
lrwxrwxrwx 1 admin root 8 May 5 2018 zcip -> /sbin/rc
If it starts growing to multiple dozens of megabytes, I would start looking at what is using all that space in it.
@RMerlin
I have over 3 days of uptime now, and the size of the tmp folder has hovered stably between 2.6-2.9mb. Memory use overall according to the WebGUI is 435mb/512mb with CakeQOS and 19 clients on 3 aimesh nodes (1 wired, 2 wireless), low amounts of traffic.
Seeing as the crash seems to come after about 1-2 weeks, I think I should have seen some accumulation in the /tmp/ folder by now if that's where the culprit lies?
So do you have any other suggestions on possible culprits that i can check/keep tabs on?
Btw. regarding the logs i posted earlier: Any ideas on why the result of the memory leak is that the router runs for about 8 more minutes before it restarts, and after that renders all the Aimesh nodes useless/unable to connect clients (wired and wireless) and only the main AC86 router working? In other words, it is not a complete restart but a partial one that renders only the main router working again, not the Aimesh nodes, because when I manage to connect via ethernet and do a proper restart via the WebGUI, the whole network including the Aimesh setup is back to working. Is this something that can be improved in the code on your side, ie. that it does a proper restart when a memory leak crash happens, and not a partial one?
(For the record: I haven't even checked that the AC86 worked properly after the crash because it's placed a long distance from my computer. What happened was that it rolled over from the broken Aimesh connection to the AC86U at about 150mbps on the 2.4ghz network, and it only worked for very short bursts, minutes in-between. Spent 15 minutes trying to access the web interface on that weak connection before I gave up and connected by wire via the Aimesh node in order to access SSH and reboot. Which suggests to me that something is not working properly because 150mbps connection (according to MacOS) is supposed to provide me a stable enough connection, an almost completely unresponsive one. Anyways, dunno if that's relevant but I like to include everything just in case.)
