Release Asuswrt-Merlin 386.2 is now available
Hi I just bought an rt-ax88u and I'am unable to connect my phone to the wifi, what am I doing wrong or is this a known problem?
My crystal ball says your generic phone will never work with any router and you need to send me the new AX88U to appease the wifi gods.
you need to start a separate thread for your question and you need to describe what you did.
iphones connect fine to ax88
And in this thread please provide way more details your original post is vague.
1. What phone
2. can your other devices connect
3. is this on 2.4 or 5Ghz
4. what channel are you on
5. what does the phone show when you are trying to connect?
1. What phone
Galaxy j5 2016 other phone won't connect either, channel 2 and phone doesn't even try to connect even after entering password.
Ok that is a start but as ugandy suggested you need to create a new thread for this.
Just make sure you are not using odd characters in your SSID and I have used many mobiles without issue on Wi-Fi both 5 & 6. As mentioned you should start a separate thread and supply more details for assistance as not a common issue for most.
Been reading here at snbforums for a long time. Just upgraded my main router from ac88u to ax88u. My setup before the upgrade is ac88u > ac88u(Aimesh wireless backhaul) Now ax88u > ac88u both running 386.2_2. What I'm experiencing right now (and even in my last setup) is the node randomly disconnects so it needed a power cycle. When I was using 384.19 it's almost stable with a few hiccups. , I have a synology nas connected to my main router and when I'm connected to my node and downloading from the nas, all other wireless connections in the node experience high pings when they are playing online. My max download speed in my node when downloading a file in my nas is around 12 to 14MB/s. Is this normal?
Silly me - I've been throwing virgins in volcanoes to appease them all these years...
It helps to keep a small campfire going and a wet blanket at the ready for really important communication.
(Did you want that in white or black smoke?)
The Delphi oracle is on leave.
The temple virgins ....? (They are down to one.)
Still Seeing the system log getting flooded with
Apr 20 15:19:36 RT-AC88U-EB98 kernel: udb_ioctl_copy_out: no handler for ioctl 0xd:0x4
Apr 20 15:19:36 RT-AC88U-EB98 kernel: udb_ioctl_copy_in: no handler for ioctl 0xd:0x3
I Cannot be the only one having this, Can this be looked at Pretty please.
Is there a limit on the number of Manually Assigned IP addresses in the DHCP scope
Its just that I am trying to setup another and after hitting apply it disappears
64
There are a couple of work arounds.
One is to assign static IP's at the client and narrow the DHCP pool.
Another is to use dnsmasq add file. I seem to remember a discussion in the forum about this.
I experienced the same thing twice since 386.2_2 installed. AC86U as main, AC68U as node.
YazDHCP is a great addon for having as many static addresses your router can give you. I have about 26 static addresses and YazDHCP tells me I can configure 241 more I think. YazDHCP just takes advantage of modifying the webui to enter and store the information in /jffs. Give it a spin.
64
Another useful workaround: YazDHCP.
I had that sort of behavior happening so regularly (when testing AiMesh2.0 last fall/winter) with the same combination of routers (connected wirelessly) that I gave up and moved to Media Bridge mode on the RT-AC68. Are yours also connected wirelessly? This combination of routers and AiMesh2.0 setup seems problematic by several reports
I have the exact same setup, but haven't had any issues. It appears to be very stable. Are you using Smart Connect and one single SSID, or do you have Smart Connect disabled and 2 SSID's for the separate bands (I have the latter setup)?
