Beta Asuswrt-Merlin 388.1 Beta is available for select models
I have just updated my GT-AX6000 to Beta2 from 386.7.2
My DDNS (Google Domains) was showing an exclamation mark
I disabled IPv6 Update in DDNS (i have native ipv6) and its working fine now for ipv4
is this a google problem or router problem?
Have the same issue, just with an AX88, with different DDNS provider - same issue and result as you.
Dirty upgrade on my GT-AX6000, no problems in 3 days uptime, aimesh works (with AC68U), DDNS with Instant Guard working good.
Tried ROG "cosmetics", does not work for me (complexity, low visibility).
Same here. Disabled IPv6 for ddns on AX88U, voila!
Ddns is NoIP
Can anyone can confirm if port forwarding works with wireguard VPN Director?
I tested 2 different clients with Torguard VPN, the port still showing closed! if i try the same client with openvpn the port shows open.
any ideas? thx
Im not 100% sure what you are getting at, trying to connect back to a Wireguard server via a Wireguard client which offers port-forward?
Just want to add that a wireguard server will ONLY reply to packets carrying the right encryption. Port scan packets do not carry the right encryption so the port will appear as stealth. While I find this really cool it also makes debugging more difficult.
I am using the Asuscomm DDNS and although IPv6 didn't work at first after a dirty update (386.8 to beta1) after a reboot it has been fine. Also, no problems after the update to beta2.
That new portmap implementation is quirky on some models. It's closed source so outside of my control. On my GT-AXE16000 for instance it doesn't even appear at all, as the backend fails to generate the required data.
That would explain this, I guess-
Stock firmware for AX88U, I read earlier that your GPL there is having a one newer than the stock one. there they have a fix for these, on the other models (like yourselves AXE16000 and AX56U) it is not distributed yet.
If you have a word with them, maybe worth mention.
A week with Beta 2 and everything is running smooth, no drop-outs, clean logs and great performance!
Memory consumption on AX86U goes up by 2% every day on Beta2.
This did not happen on previous stable release.
It does auto-refresh for me. Look for any Javascript error in the browser console that may be preventing the refresh from happening.
I can't see any javascript errors on that page.
This page is in near default mode. Page layout may be affected. For default mode use "<!DOCTYPE html>".
Advanced_VPNStatus.asp Some cookies abuse the recommended "SameSite" attribute 3
Cookie "clickedItem_tab" does not have a correct "SameSite" attribute value. Soon cookies without the "SameSite" attribute or with an invalid value will be treated as "Salmon". This means that the cookie is no longer sent in external contexts. If your application depends on this cookie being available in such contexts, add the "SameSite=None" attribute to it. Read https://developer.mozilla.org/docs/Web/HTTP/Headers/Set-Cookie/SameSite to learn more about the "SameSite" attribute state.js:120:67 Cookie "notification_history" does not have a correct "SameSite" attribute value. Soon cookies without the "SameSite" attribute or with an invalid value will be treated as "Salmon". This means that the cookie is no longer sent in external contexts. If your application depends on this cookie being available in such contexts, add the "SameSite=None" attribute to it. Read https://developer.mozilla.org/docs/Web/HTTP/Headers/Set-Cookie/SameSite to learn more about the "SameSite" attribute state.js:128:14 Cookie "clickedItem_tab" does not have a correct "SameSite" attribute value. Soon cookies without the "SameSite" attribute or with an invalid value will be treated as "Salmon". This means that the cookie is no longer sent in external contexts. If your application depends on this cookie being available in such contexts, add the "SameSite=None" attribute to it. Read https://developer.mozilla.org/docs/Web/HTTP/Headers/Set-Cookie/SameSite to learn more about the "SameSite" attribute state.js:120:6
Synchronous XMLHttpRequest on the main thread is deprecated due to its negative impact on the user experience. For more help, see http://xhr.spec.whatwg.org/
when you refer to the previous stable release, do you mean the one based on 386? If so, I'm also seeing this behaviour on my tuf-ax5400 (not supported by @RMerlin ) on 388 stock. I used to have about 110/120mb of free RAM and now it hovers around 56/62MB, with no instability being detected. Maybe something was changed in terms of RAM management/showing with 388 from 386.
Yes, 386.7_2, this one was "RAM stable" for weeks, always same memory percentage used. 388 seems to eat more and more RAM daily. Not sure if it will sustain one month running.
I do recall a change being made in recent builds to not purge RAM in the same way that several older builds were doing so. RAM usage is not a bad thing as it is maintaining items in memory as required and can overwrite as necessary. This change does mean that usage will remain higher than in some of the older builds, though is by design rather than indicative of an issue.
My internet dl speed seems to be cut down to around 80% with beta 2.
I have 100/100 and usually get around 94/94, now i get 94/80 (ul/dl), tried with aiprot and qos off but no difference.
Tried today and got 94/94 as usual, it was probably a temporary problem with the city fiber network or my isp. I have been thinking of upgrading to 1Gbit but 100Mbit works fine with qos (appletv, htpc, mobiles, android tabs, 3 laptops ...) and i don't like to increase cost if it is not needed :D
Those are just warnings, they do not stop the page from loading properly. Errors would be in red.
Yes, that was my point.
