Release Asuswrt-Merlin 388.1 is now available for all supported Wifi 6 models
Just wanted to mention that a factory reset (and jffs format) after upgrading was critical this time around, I generally always upgrade in place and go. This time a bunch of things weren't working though from web history to spdmerlin.
AX86U
True. Tested this release with factory/jffs reset with AX86S, was running smoothly and much better wifi. Dirty upgrade with AX86U, not sure what was going wrong. but buffer size was huge. Now factory reset with amtm + addon installed, RAM usage is lower than before and buffer size sort of in the normal range, I think,
Finally got WireGuard working on my RT-AX88U. Speeds are good. Latency is good.
So I guess this question is, Which router is even more powerful? Since I got an full duplex Gigabit connection.
Maybe the new Xiaomi router which has a Qualcom 4 core soc instead of a Broadcom it uses a WRT variant for their firmware:
Updated firmware on the 14th. Router (GT-AX6000) randomly rebooted just now. Very light load; watching twitch stream and running an online game/discord.
There doesn't seem to be any indication of a problem causing this reboot.. it just rebooted out of nowhere. Snip of log just before:
Dec 19 09:29:45 acsd: acs_set_chspec: 0x100b (11) for reason ACS_CSTIMER
Dec 19 09:29:45 acsd: eth6: selected_chspec is 100b (11)
Dec 19 09:29:45 acsd: eth6: Adjusted channel spec: 0x100b (11)
Dec 19 09:29:45 acsd: eth6: selected channel spec: 0x100b (11)
Dec 19 09:29:45 acsd: eth6: txop channel select: Performing CSA on chspec 0x100b
Dec 19 10:03:22 acsd: acs_set_chspec: 0x1008 (8) for reason ACS_CSTIMER
Dec 19 10:03:22 acsd: eth6: selected_chspec is 1008 (8)
Dec 19 10:03:22 acsd: eth6: Adjusted channel spec: 0x1008 (8)
Dec 19 10:03:22 acsd: eth6: selected channel spec: 0x1008 (8)
Dec 19 10:03:22 acsd: eth6: txop channel select: Performing CSA on chspec 0x1008
Dec 19 10:29:44 acsd: acs_set_chspec: 0xeb32 (48/160) for reason ACS_CSTIMER
Dec 19 11:03:04 acsd: acs_set_chspec: 0xeb32 (48/160) for reason ACS_CSTIMER
Dec 19 11:34:20 acsd: acs_set_chspec: 0x1007 (7) for reason ACS_CSTIMER
Dec 19 11:34:20 acsd: eth6: selected_chspec is 1007 (7)
Dec 19 11:34:20 acsd: eth6: Adjusted channel spec: 0x1007 (7)
Dec 19 11:34:20 acsd: eth6: selected channel spec: 0x1007 (7)
Dec 19 11:34:20 acsd: eth6: txop channel select: Performing CSA on chspec 0x1007
Dec 19 11:36:25 acsd: acs_set_chspec: 0xeb32 (48/160) for reason ACS_CSTIMER
Dec 19 12:43:03 acsd: acs_set_chspec: 0xeb32 (48/160) for reason ACS_CSTIMER
May  5 02:05:17 kernel: klogd started: BusyBox v1.25.1 (2022-12-03 13:16:10 EST)
May  5 02:05:17 kernel: Linux version 4.19.183 (merlin@ubuntu-dev) (gcc version 9.2.0 (Buildroot 2019.11.1)) #1 SMP PREEMPT Sat Dec 3 13:16:36 EST 2022
May  5 02:05:17 kernel: random: get_random_bytes called from start_kernel+0x9c/0x454 with crng_init=0
May  5 02:05:17 kernel: Kernel command line: coherent_pool=4M cpuidle_sysfs_switch pci=pcie_bus_safe console=ttyAMA0,115200 earlycon rootwait mtdparts=brcmnand.0:2097152(loader),264241152@2097152(image),524288@266338304(crashlog) root=/dev/ubiblock0_4 ubi.mtd=image ubi.block=0,4 rootfstype=squashfs cma=0M
May  5 02:05:17 kernel: mtusize 1500
May  5 02:05:17 kernel: CCI hardware cache coherency enabled
May  5 02:05:17 kernel: bootloader version  U-Boot 2019.07 (Dec 03 2022 - 14:08:33 -0500), Build: 5.04L.0
May  5 02:05:17 kernel: inMemNvramData.szBoardId GTAX6000_50991
Don't run any scripts or whatever that's normally talked about here; just using it as a simple person router.
No idea what to look for in the log though, so I can provide the full log and config with guidance on any personal information to scrub beforehand. Not educated in this stuff.
EDIT: It just rebooted again just over an hour later, what the hell?
Downgraded back to 386.7_2 for now. Have a suspicion what's causing it but that'd be completely insane if it was.
I'm unable to check Asus servers since updating to the latest firmware with my GT-AX11000. I have two mesh nodes (XT8's) still on stock Asus firmware. I've been getting this ever since updating the main unit:
I manually downloaded and updated the mesh nodes to the latest Asus firmware, but that didn't help.
RT-AX88u on 388.1 All good here :)
Thanks RMerlin
View attachment 46483\
I just tried this check and it worked fine for me. Not really sure why you'd be trying that though if on RMerlin firmware. What upstream DNS is your router using? I'm using Quad9.
Also, FWIW, I have one AIMesh node (also another GT-AX11000) on RMerlin firmware as well with no issues whatsoever. I've read time and again that it's not recommended to do that, but it's never been an issue even when I had the same setup with RT-AC5300s.
Checking for my mesh nodes, as that's an easier way to update them than manually. Also just handy as a notification when an update is available.
I did a dirty on my AX86U to 388.1 upgrade last week. Was running fine until yesterday. Streaming was laging, wifi unstable. After a reboot issues were gone, for some time, but now th are back.
Some errors in the log:
FCACHEfc_vblog_list_add ERROR: Duplicate blog: list blog<0xffffffc02f866e40> JOIN blog<0xffffffc02f857300>
CFG80211-ERROR) wl_cfg80211_hostapd_sec : update bss - wpa_ie and wpa2_ie is not null
When wifi was unstable (it looks like only 5ghz channel), I had a lot of these entries:
rc_service: waitting "restart_wireless" via cfg_server ...
@RMerlin any suggestions to pinpoint the source of the issues?
I've tried checking and I've not spotted this little bug being reported elsewhere:
I've found for a while that clearing the 2.4GHz checkbox for "use channels 12 & 13" (along with leaving disable 11b clear) seems to help devices roam from my GT-AX6000 to the RP-AX56 - when it's sensible to do so.
This morning I found the router is using 2.4GHz channel 13 anyhow - and devices are still roaming onto the RP-AX56 just fine. Odd, and it's not a complaint, just a bit weird.
So far as I'm aware it's the first time this has happened since the upgrade. Everything I have will use channels 12 & 13 (UK), but the observation is that roaming has previously suffered. If I had anything that didn't use those channels though, I guess this could be a major issue!
According to RMerlin and a lot of other people, dirty upgrade shouldn't be an issue
I disagree: most problems can be avoided with a clean update.
Revert to 386.5_2 everything is now stable again.The 388.1 was not stable. Sometimes the router had a restart , out of the blue. For the info, this was on a RT-AX86s
clean update means manual re-config as you should not use the old config / backup.
It's few hours work to check all pages with settings, compare what was how...
Or do you have any faster way?
I was thinking about buying an AX55 for an AiMesh node, would I need to flash it with Merlin if it's supported?
Screen shots work fine. Backing up specific nvram values speeds things up too. I don't get what is so hard. :rolleyes:
