FlexQoS FlexQoS issues with 388.4 HND5.04 models
@dave14305 This is on RT-AX88U-PRO running the latest release using only the "ASUS" option.
FlexQoS v1.3.3 released 2023-08-09
Debug date      : 2023-08-26 02:01:46-0400
Router Model    : RT-AX88U_Pro
Firmware Ver    : 388.4_0
DPI/Sig Ver     : 2.0.3 / 2.368
WAN iface       : eth0
tc WAN iface    : eth0
IPv6            : dhcp6
Undf Prio       : 2
Down Band       : 1105920
Up Band         : 36864
Net Control     : 1:10
Work-From-Home  : 1:13
Gaming          : 1:16
Others          : 1:11
Web Surfing     : 1:15
Streaming       : 1:12
File Transfers  : 1:17
Learn-From-Home : 1:14
Downrates       :   55296,  110592,  331776,  221184,   55296,  110592,  165888,   55296
Downceils       : 1105920, 1105920, 1105920, 1105920, 1105920, 1105920, 1105920, 1105920
Uprates         :    1843,   11059,    3686,    7372,    1843,    3686,    5529,    1843
Upceils         :   36864,   36864,   36864,   36864,   36864,   36864,   36864,   36864
iptables settings: <>>udp>>500,4500>>3<>>udp>16384:16415>>>3<>>udp>>19302:19309>>3<>>udp>>3478:3481>000000>3<>>udp>>8801:8810>000000>3<>>tcp>>119,563>>5<>>tcp>>80,443>08****>5
-A FlexQoS_down -p udp -m multiport --sports 500,4500 -j MARK --set-mark 0x8006ffff/0xc03fffff
-A FlexQoS_up -p udp -m multiport --dports 500,4500 -j MARK --set-mark 0x4006ffff/0xc03fffff
-A FlexQoS_down -p udp -m multiport --dports 16384:16415 -j MARK --set-mark 0x8006ffff/0xc03fffff
-A FlexQoS_up -p udp -m multiport --sports 16384:16415 -j MARK --set-mark 0x4006ffff/0xc03fffff
-A FlexQoS_down -p udp -m multiport --sports 19302:19309 -j MARK --set-mark 0x8006ffff/0xc03fffff
-A FlexQoS_up -p udp -m multiport --dports 19302:19309 -j MARK --set-mark 0x4006ffff/0xc03fffff
-A FlexQoS_down -p udp -m multiport --sports 3478:3481 -m mark --mark 0x80000000/0xc03fffff -j MARK --set-mark 0x8006ffff/0xc03fffff
-A FlexQoS_up -p udp -m multiport --dports 3478:3481 -m mark --mark 0x40000000/0xc03fffff -j MARK --set-mark 0x4006ffff/0xc03fffff
-A FlexQoS_down -p udp -m multiport --sports 8801:8810 -m mark --mark 0x80000000/0xc03fffff -j MARK --set-mark 0x8006ffff/0xc03fffff
-A FlexQoS_up -p udp -m multiport --dports 8801:8810 -m mark --mark 0x40000000/0xc03fffff -j MARK --set-mark 0x4006ffff/0xc03fffff
-A FlexQoS_down -p tcp -m multiport --sports 119,563 -j MARK --set-mark 0x8003ffff/0xc03fffff
-A FlexQoS_up -p tcp -m multiport --dports 119,563 -j MARK --set-mark 0x4003ffff/0xc03fffff
-A FlexQoS_down -p tcp -m multiport --sports 80,443 -m mark --mark 0x80080000/0xc03f0000 -j MARK --set-mark 0x8003ffff/0xc03fffff
-A FlexQoS_up -p tcp -m multiport --dports 80,443 -m mark --mark 0x40080000/0xc03f0000 -j MARK --set-mark 0x4003ffff/0xc03fffff
appdb rules: Defaults
filter change dev br0 prio 2 protocol all handle 828::800 u32 flowid 1:11
filter change dev eth0 prio 2 protocol all handle 828::800 u32 flowid 1:11
filter add dev br0 protocol all prio 2 u32 match mark 0x8000006B 0xc03fffff flowid 1:11
filter add dev eth0 protocol all prio 2 u32 match mark 0x4000006B 0xc03fffff flowid 1:11
filter add dev br0 protocol all prio 15 u32 match mark 0x800D0007 0xc03fffff flowid 1:17
filter add dev eth0 protocol all prio 15 u32 match mark 0x400D0007 0xc03fffff flowid 1:17
filter add dev br0 protocol all prio 15 u32 match mark 0x800D0086 0xc03fffff flowid 1:17
filter add dev eth0 protocol all prio 15 u32 match mark 0x400D0086 0xc03fffff flowid 1:17
filter add dev br0 protocol all prio 15 u32 match mark 0x800D00A0 0xc03fffff flowid 1:17
filter add dev eth0 protocol all prio 15 u32 match mark 0x400D00A0 0xc03fffff flowid 1:17
filter add dev br0 protocol all prio 20 u32 match mark 0x8012003F 0xc03fffff flowid 1:15
filter add dev eth0 protocol all prio 20 u32 match mark 0x4012003F 0xc03fffff flowid 1:15
filter change dev br0 prio 22 protocol all handle 802::800 u32 flowid 1:15
filter change dev eth0 prio 22 protocol all handle 802::800 u32 flowid 1:15
filter change dev br0 prio 23 protocol all handle 804::800 u32 flowid 1:15
filter change dev eth0 prio 23 protocol all handle 804::800 u32 flowid 1:15
class change dev br0 parent 1:1 classid 1:10 htb overhead 42 linklayer ethernet prio 0 rate 55296Kbit ceil 1105920Kbit burst 138240b cburst 1382400b quantum 691200
class change dev eth0 parent 1:1 classid 1:10 htb overhead 42 linklayer ethernet prio 0 rate 1843Kbit ceil 36864Kbit burst 4608b cburst 44800b quantum 23037
class change dev br0 parent 1:1 classid 1:11 htb overhead 42 linklayer ethernet prio 1 rate 110592Kbit ceil 1105920Kbit burst 138240b cburst 1382400b quantum 1382400
class change dev eth0 parent 1:1 classid 1:11 htb overhead 42 linklayer ethernet prio 1 rate 11059Kbit ceil 36864Kbit burst 4608b cburst 44800b quantum 138237
class change dev br0 parent 1:1 classid 1:12 htb overhead 42 linklayer ethernet prio 2 rate 331776Kbit ceil 1105920Kbit burst 138240b cburst 1382400b quantum 4147200
class change dev eth0 parent 1:1 classid 1:12 htb overhead 42 linklayer ethernet prio 2 rate 3686Kbit ceil 36864Kbit burst 4608b cburst 44800b quantum 46075
class change dev br0 parent 1:1 classid 1:13 htb overhead 42 linklayer ethernet prio 3 rate 221184Kbit ceil 1105920Kbit burst 138240b cburst 1382400b quantum 2764800
class change dev eth0 parent 1:1 classid 1:13 htb overhead 42 linklayer ethernet prio 3 rate 7372Kbit ceil 36864Kbit burst 4608b cburst 44800b quantum 92150
class change dev br0 parent 1:1 classid 1:14 htb overhead 42 linklayer ethernet prio 4 rate 55296Kbit ceil 1105920Kbit burst 138240b cburst 1382400b quantum 691200
class change dev eth0 parent 1:1 classid 1:14 htb overhead 42 linklayer ethernet prio 4 rate 1843Kbit ceil 36864Kbit burst 4608b cburst 44800b quantum 23037
class change dev br0 parent 1:1 classid 1:15 htb overhead 42 linklayer ethernet prio 5 rate 110592Kbit ceil 1105920Kbit burst 138240b cburst 1382400b quantum 1382400
class change dev eth0 parent 1:1 classid 1:15 htb overhead 42 linklayer ethernet prio 5 rate 3686Kbit ceil 36864Kbit burst 4608b cburst 44800b quantum 46075
class change dev br0 parent 1:1 classid 1:16 htb overhead 42 linklayer ethernet prio 6 rate 165888Kbit ceil 1105920Kbit burst 138240b cburst 1382400b quantum 2073600
class change dev eth0 parent 1:1 classid 1:16 htb overhead 42 linklayer ethernet prio 6 rate 5529Kbit ceil 36864Kbit burst 4608b cburst 44800b quantum 69112
class change dev br0 parent 1:1 classid 1:17 htb overhead 42 linklayer ethernet prio 7 rate 55296Kbit ceil 1105920Kbit burst 138240b cburst 1382400b quantum 691200
class change dev eth0 parent 1:1 classid 1:17 htb overhead 42 linklayer ethernet prio 7 rate 1843Kbit ceil 36864Kbit burst 4608b cburst 44800b quantum 23037
From the debug provided....i wonder why the Learn-from-Home category is not showing at bottom (1:17). It's currently showing File Transfer unless you made an update to the categories.
I changed the categories to fit my house hold needs.
I switched back to using "fq_codel". Haven't experienced a random reboot like I did when it said "ASUS".
Bufferbloat is still an A.
Here is the Debug:
Debug date      : 2023-08-26 13:13:02-0400
WAN iface       : eth0
tc WAN iface    : eth0
IPv6            : dhcp6
Undf Prio       : 2
Down Band       : 1105920
Up Band         : 36864
Net Control     : 1:10
Gaming          : 1:16
Others          : 1:11
Web Surfing     : 1:15
Streaming       : 1:12
Downrates       :   55296,  110592,   55296,  221184,   55296,  110592,  165888,   55296
Uprates         :    1843,   11059,    1843,    7372,    1843,    3686,    5529,    1843
class change dev br0 parent 1:1 classid 1:12 htb overhead 42 linklayer ethernet prio 2 rate 55296Kbit ceil 1105920Kbit burst 138240b cburst 1382400b quantum 691200
class change dev eth0 parent 1:1 classid 1:12 htb overhead 42 linklayer ethernet prio 2 rate 1843Kbit ceil 36864Kbit burst 4608b cburst 44800b quantum 23037
Here is the Debug:
WAN iface       : eth0
tc WAN iface    : eth0
IPv6            : dhcp6
Undf Prio       : 2
Down Band       : 1105920
Up Band         : 36864
Net Control     : 1:10
Gaming          : 1:16
Others          : 1:11
Web Surfing     : 1:15
Streaming       : 1:12
Cool ...just some background info in regards to L-f-H category:
Post in thread 'FlexQoS 1.2.5 - Flexible QoS Enhancement Script for Adaptive QoS' https://www.snbforums.com/threads/f...ent-script-for-adaptive-qos.73097/post-718537
Unlike the post you referred to, mine is not unused, thus why the higher priority.
Anything that can be buffered can be put at the bottom of the list. PCs or devices that can buffer the playback like youtube videos, netflix, etc go to the bottom. This includes anything like Udemy. Realtime apps should go at the top: zoom, webex, voip, video conference. There is no buffer for these as they have realtime streams. Some TVs are a pain since the buffer isn't large enough so they may need priority if it's important. That's why normally you should have web surfing, streaming, file transfers and learning from home at the bottom. 'Others' can go at the top without issue. There is also no harm in having gaming at the top even if you don't use it. DNS should include 853 and 443 redirections so normally it is good to have a rule with regards to anything going to your dns server should be 'net control'
The web is best effort for the ISP so even though you tag it, the telco doesn't listen to it unless it's a privately owned circuit. They already prioritize the way they want.
With a 30meg uplink, QoS is still useful, as you don't want dropbox or similar chewing up all the uplink bandwidth and the router can send out rtp and voip traffic in better proportions.
The first step should be to change QoS Mode in FlexQoS from fq_codel to ASUS and see if the problems remain. I have no way to troubleshoot this myself.
Any idea for next step on troubleshooting? I did the above advice and the reboots were still present. I removed the addon and I returned stable state with no reboots for >2 days.
With Adaptive QoS enabled (but not FlexQoS), let’s look for anything different in the default setup.
tc qdisc
tc class show dev br0
tc class show dev $(nvram get wan_ifname)
tc filter show dev br0
tc filter show dev $(nvram get wan_ifname)
cat /tmp/bwdpi/qosd.conf
No idea what we’re looking for, since I suspect the issue is in some closed-source kernel module.
tc qdisc
If I understood right, I have adaptive QoS enabled, I didn't install FLexQoS and run the above commands one by one and captured the outcome. Here is the attached txt. Many thanks in advance. In my case, I typically don't do anything special with QoS, just enable Adaptive QoS, select customized priorities of the categories, and then install FlexQoS that's all pretty much. I don't use special rules etc.
Not much to see in the output, which isn‘t surprising, really. Can you post the output of lsmod? I see Asus made some netfilter customizations for a new “router boost / deDupeTx” feature on some models, as well as new code in netfilter xt_mark.c. Starting to feel the black box closing in…
Here is the output.
yiannis@RT-AX86U_Pro-4D00:/tmp/home/root# lsmod
Module                  Size  Used by    Tainted: P
tdts_udbfw             45056  1
tdts_udb              270336  1 tdts_udbfw
tdts                  536576  2 tdts_udbfw,tdts_udb
tun                    40960  6
wireguard             131072  0
sr_mod                 24576  0
cdrom                  40960  1 sr_mod
nf_nat_sip             20480  0
nf_conntrack_sip       32768  1 nf_nat_sip
nf_nat_h323            20480  0
nf_conntrack_h323      49152  1 nf_nat_h323
nf_nat_rtsp            16384  0
nf_conntrack_rtsp      20480  1 nf_nat_rtsp
nf_nat_ftp             16384  0
nf_conntrack_ftp       16384  1 nf_nat_ftp
thfsplus              114688  0
tntfs                 503808  0
tfat                  360448  0
uas                    24576  1
usb_storage            65536  1 uas
sg                     36864  0
sd_mod                 40960  2
scsi_mod              167936  5 sr_mod,uas,usb_storage,sg,sd_mod
ipheth                 16384  0
qmi_wwan               32768  0
cdc_wdm                20480  1 qmi_wwan
cdc_ncm                28672  0
rndis_host             16384  0
cdc_ether              16384  1 rndis_host
ax88179_178a           28672  0
asix                   36864  0
cdc_acm                28672  0
usbnet                 32768  6 qmi_wwan,cdc_ncm,rndis_host,cdc_ether,ax88179_17                                                       8a,asix
mii                    16384  3 ax88179_178a,asix,usbnet
ohci_pci               16384  0
ohci_platform          16384  0
ohci_hcd               40960  2 ohci_pci,ohci_platform
ehci_pci               16384  0
ehci_platform          16384  0
ehci_hcd               49152  2 ehci_pci,ehci_platform
xhci_pci               16384  0
xhci_plat_hcd          16384  0
xhci_hcd              135168  2 xhci_pci,xhci_plat_hcd
bcm_bca_usb            24576  0 [permanent]
usbcore               188416 21 uas,usb_storage,ipheth,qmi_wwan,cdc_wdm,cdc_ncm,                                                       rndis_host,cdc_ether,ax88179_178a,asix,cdc_acm,usbnet,ohci_pci,ohci_platform,ohc                                                       i_hcd,ehci_pci,ehci_platform,ehci_hcd,xhci_pci,xhci_plat_hcd,xhci_hcd
usb_common             16384  2 ehci_platform,usbcore
dhd                   974848  0
wl                   8650752  0
igs                    32768  2 dhd,wl
emf                    28672  3 dhd,wl,igs
hnd                   380928  4 dhd,wl,igs,emf
cfg80211              286720  2 dhd,wl
firmware_class         16384  1 cfg80211
wlshared               16384  2 dhd,wl
otp                    16384  0
bcm_thermal            16384  0
bcmspu                126976  0
bcmflex                20480  1 bcmspu
pwrmngtd               16384  0
wfd                    32768  2 dhd,wl
bcm_pcie_hcd           65536  0
bcmmcast              110592  5 dhd,igs,emf,wfd
pktrunner              69632  0
bcm_enet              135168  1 tdts_udbfw
cmdlist                94208  1 pktrunner
pktflow               311296  2 tdts_udbfw,pktrunner
rdpa_cmd              102400  0
bcm_ingqos            225280  1 rdpa_cmd
chipinfo               16384  0
bcm_license            53248  0
rdpa_mw                40960  2 pktrunner,rdpa_cmd
rdpa_usr               45056  0
rdpa                 4231168  1 rdpa_mw
rdpa_gpl               32768  8 dhd,wfd,pktrunner,bcm_enet,rdpa_cmd,rdpa_mw,rdpa                                                       _usr,rdpa
bcmvlan               110592  0
bcm_bpm                32768  0 [permanent]
bcm_mpm               139264  1 rdpa
bdmf                 1273856  9 dhd,wfd,pktrunner,bcm_enet,rdpa_cmd,rdpa_mw,rdpa                                                       _usr,rdpa,rdpa_gpl
bcmlibs                36864  7 dhd,wl,wfd,pktrunner,bcm_enet,pktflow,rdpa
mtdoops                16384  0
wlcsm                  24576 70 dhd,hnd,bcm_pcie_hcd
If we reached to a dead end, shall we try to find common denominators on our WAN types? Maybe this issue does not affect all WAN types? I see a lot of people reporting happy results with 388.4. Are they all not using FlexQoS on newer models?
My Asus router is connected to ISP's 4G router, and gets a private IP (DMZ) from the 4G router.
Here is the output.
tdts_udbfw             45056  1
tun                    40960  6
wireguard             131072  0
sr_mod                 24576  0
nf_nat_sip             20480  0
nf_nat_h323            20480  0
nf_nat_rtsp            16384  0
nf_nat_ftp             16384  0
thfsplus              114688  0
tntfs                 503808  0
tfat                  360448  0
uas                    24576  1
sg                     36864  0
sd_mod                 40960  2
ipheth                 16384  0
qmi_wwan               32768  0
cdc_ncm                28672  0
rndis_host             16384  0
asix                   36864  0
cdc_acm                28672  0
ohci_pci               16384  0
ehci_pci               16384  0
xhci_pci               16384  0
dhd                   974848  0
wl                   8650752  0
igs                    32768  2 dhd,wl
otp                    16384  0
bcm_thermal            16384  0
bcmspu                126976  0
pwrmngtd               16384  0
wfd                    32768  2 dhd,wl
pktrunner              69632  0
rdpa_cmd              102400  0
chipinfo               16384  0
bcm_license            53248  0
rdpa_usr               45056  0
bcmvlan               110592  0
mtdoops                16384  0
I am getting pretty stable results on the RTAX88U-PRO with cable internet (cable modem connected directly to asus router wan port with no special DMZ configurations). Router gets its public IP from isp dhcp service.
so WAN type is automatic and Asus router gets Public IP?
I just tried to upgrade my second RT-AX86U Pro, which has a diffrent WAN type. This one is PPPoE and gets directly the Public IP, but the issue appeared. Therefore, while it was in 388.4 beta 2 there was no reboot issues, right after I upgraded to 388.4 the reboot problem appeared within 30 minutes. I just uninstalled FlexQoS and leaved Adaptive QoS active. Will monitor and see.
I have only had one wild reboot when running flexqos on 388.4. I had all my flexqos rules maxed out with iptables. I haven't had a random reboot since I switched to only using default flexqos rules. That has been several days no reboot already.
Thansk for the info...I know you dont game but If you create a rule i.e. Gaming rule (default) with a static IP, do you think it would cause any reboot issues? Just curious. Any input is greatly appreciated!
Another longshot would be to revert to the version of the script prior to v1.3.3 which came out between beta2 and final. It would be 1.3.2 plus a hotfix from December 2022.
Bash:
/usr/sbin/curl "https://raw.githubusercontent.com/dave14305/FlexQoS/f4008f40e78bd05de7abf01f8868243ae0adeafc/flexqos.sh" -o /jffs/addons/flexqos/flexqos.sh --create-dirs
chmod +x /jffs/addons/flexqos/flexqos.sh
sh /jffs/addons/flexqos/flexqos.sh -install
Bash:
nope. tried the script above and no love. reboots on 88pro running 388.4.
debug info not so helpful:
Make a selection: 3
FlexQoS v1.3.2 released 2022-09-16
Debug date      : 2023-08-30 00:11:26-0400
WAN iface       : eth0
tc WAN iface    : eth0
IPv6            : disabled
Undf Prio       : 2
Down Band       : 645120
Up Band         : 35840
Net Control     : 1:11
Work-From-Home  : 1:12
Gaming          : 1:10
Others          : 1:13
Web Surfing     : 1:15
Streaming       : 1:14
File Transfers  : 1:16
Learn-From-Home : 1:17
Downrates       :   96768,   32256,  129024,   64512,  193536,   64512,   32256,   32256
Downceils       :  645120,  645120,  645120,  645120,  645120,  645120,  645120,  645120
Uprates         :    5376,    1792,    7168,   10752,    3584,    3584,    1792,    1792
Upceils         :   35840,   35840,   35840,   35840,   35840,   35840,   35840,   35840
iptables settings: <>>udp>>500,4500>>3<>>udp>16384:16415>>>3<>>tcp>>119,563>>5<>>tcp>>80,443>08****>5<>8.8.0.0/16>both>>>>0<192.168.1.122>>both>>>>3
-A FlexQoS_down -s 8.8.0.0/16 -p all -j MARK --set-mark 0x8009ffff/0xc03fffff
-A FlexQoS_up -d 8.8.0.0/16 -p all -j MARK --set-mark 0x4009ffff/0xc03fffff
-A FlexQoS_down -d 192.168.1.122 -p all -j MARK --set-mark 0x8006ffff/0xc03fffff
-A FlexQoS_up -s 192.168.1.122 -p all -j MARK --set-mark 0x4006ffff/0xc03fffff
filter change dev br0 prio 2 protocol all handle 828::800 u32 flowid 1:13
filter change dev eth0 prio 2 protocol all handle 828::800 u32 flowid 1:13
filter add dev br0 protocol all prio 2 u32 match mark 0x8000006B 0xc03fffff flowid 1:13
filter add dev eth0 protocol all prio 2 u32 match mark 0x4000006B 0xc03fffff flowid 1:13
filter add dev br0 protocol all prio 15 u32 match mark 0x800D0007 0xc03fffff flowid 1:16
filter add dev eth0 protocol all prio 15 u32 match mark 0x400D0007 0xc03fffff flowid 1:16
filter add dev br0 protocol all prio 15 u32 match mark 0x800D0086 0xc03fffff flowid 1:16
filter add dev eth0 protocol all prio 15 u32 match mark 0x400D0086 0xc03fffff flowid 1:16
filter add dev br0 protocol all prio 15 u32 match mark 0x800D00A0 0xc03fffff flowid 1:16
filter add dev eth0 protocol all prio 15 u32 match mark 0x400D00A0 0xc03fffff flowid 1:16
filter change dev br0 prio 23 protocol all handle 805::800 u32 flowid 1:15
filter change dev eth0 prio 23 protocol all handle 805::800 u32 flowid 1:15
class change dev br0 parent 1:1 classid 1:10 htb  prio 0 rate 96768Kbit ceil 645120Kbit burst 80640b cburst 806400b quantum 1209600
class change dev eth0 parent 1:1 classid 1:10 htb  prio 0 rate 5376Kbit ceil 35840Kbit burst 4480b cburst 44800b quantum 67200
class change dev br0 parent 1:1 classid 1:11 htb  prio 1 rate 32256Kbit ceil 645120Kbit burst 80640b cburst 806400b quantum 403200
class change dev eth0 parent 1:1 classid 1:11 htb  prio 1 rate 1792Kbit ceil 35840Kbit burst 4480b cburst 44800b quantum 22400
class change dev br0 parent 1:1 classid 1:12 htb  prio 2 rate 129024Kbit ceil 645120Kbit burst 80640b cburst 806400b quantum 1612800
class change dev eth0 parent 1:1 classid 1:12 htb  prio 2 rate 7168Kbit ceil 35840Kbit burst 4480b cburst 44800b quantum 89600
class change dev br0 parent 1:1 classid 1:13 htb  prio 3 rate 64512Kbit ceil 645120Kbit burst 80640b cburst 806400b quantum 806400
class change dev eth0 parent 1:1 classid 1:13 htb  prio 3 rate 10752Kbit ceil 35840Kbit burst 4480b cburst 44800b quantum 134400
class change dev br0 parent 1:1 classid 1:14 htb  prio 4 rate 193536Kbit ceil 645120Kbit burst 80640b cburst 806400b quantum 2419200
class change dev eth0 parent 1:1 classid 1:14 htb  prio 4 rate 3584Kbit ceil 35840Kbit burst 4480b cburst 44800b quantum 44800
class change dev br0 parent 1:1 classid 1:15 htb  prio 5 rate 64512Kbit ceil 645120Kbit burst 80640b cburst 806400b quantum 806400
class change dev eth0 parent 1:1 classid 1:15 htb  prio 5 rate 3584Kbit ceil 35840Kbit burst 4480b cburst 44800b quantum 44800
class change dev br0 parent 1:1 classid 1:16 htb  prio 6 rate 32256Kbit ceil 645120Kbit burst 80640b cburst 806400b quantum 403200
class change dev eth0 parent 1:1 classid 1:16 htb  prio 6 rate 1792Kbit ceil 35840Kbit burst 4480b cburst 44800b quantum 22400
class change dev br0 parent 1:1 classid 1:17 htb  prio 7 rate 32256Kbit ceil 645120Kbit burst 80640b cburst 806400b quantum 403200
class change dev eth0 parent 1:1 classid 1:17 htb  prio 7 rate 1792Kbit ceil 35840Kbit burst 4480b cburst 44800b quantum 22400
