Long Term Support - Asuswrt-Merlin Router List
WhereAmI
Hello,
I love the ASUS/merlin interface (thank you for your work!) and need the simplicity + security for as long as possible. I saw the requirements for adding new routers, like higher ram capacity and broadcom chips...
- Would love to know which routers on these lists would likely be supported for a longer period of time?
- What are the stipulations on currently supported devices that make them more likely for continued support?
Ex: Are there specific builds that are likely to continue longer?
Thank you!
https://www.asuswrt-merlin.net/about
https://github.com/RMerl/asuswrt-merlin.ng/wiki/Supported-Devices
As of August 12th, 2024 (about page)
ModelStableBeta
RT-AC68U386.14
RT-AC88U386.14
RT-AC3100386.14
RT-AC5300386.14
RT-AC86U386.14
GT-AC2900386.14
RT-AX58U3004.388.8_2
RT-AX86U3004.388.8_2
RT-AX88U3004.388.8_2
GT-AX110003004.388.8_2
RT-AX68U3004.388.8_2
GT-AXE110003004.388.8_2
ZenWiFi Pro XT123004.388.8_2
GT-AX60003004.388.8_2
GT-AXE160003004.388.8_2
GT-AX11000_PRO3004.388.8_2
RT-AX86U_PRO3004.388.8_2
RT-AX88U_PRO3004.388.8_2
RT-BE96U3006.102.1
GT-BE98_PRO3006.102.1
No longer supported:
RT-N66U380.70
RT-AC66U380.70
RT-AC56U384.6
RT-AC87U384.13_10
RT-AC3200384.13_10
RT-AX56U3004.388.8_2
Impossible to predict, because I am reliant on Asus' own support.
Wow, appreciate the response!
So all the supported routers on your list are currently supported by ASUS as well, or have somewhat recent firmware upgrades by ASUS?
RT-AC68U386.14
RT-AC88U386.14
RT-AC3100386.14
RT-AC5300386.14
RT-AC86U386.14
GT-AC2900
All of the AC models and the AX56U are already listed as End of Life by Asus. I believe Merlin will also drop support for these models at the end of this year.
As far as I’m aware, Asus supports all of its router that are not end of life with updated firmware. Of these router Asus works with RMerlin to supply him with GPL firmware in which he’s allowed to modify and build custom firmware with. If Asus decides a router is EoL or doesn’t want to supply RMerlin with a GPL for that specific router then it’s out of his control.
Certain parts for the firmware isn’t modifiable by RMerlin meaning he can’t just keep updating a old GPL himself because certain security vulnerabilities would make its way into the firmware if Asus/Broadcoms components are not updated.
