mod: 380.58.2_HGG-FINAL released
Status.txt
380.59_HGG-FINAL
RT-N16 - READY. (UPLOADED)
7c555441da88d9dda6fd9be65704c100ac60a58cdcfb3ebe19f5cf6599124e51 RT-N16_380.59_HGG-FINAL.trx (30.433KB)
RT-N18U - READY. (UPLOADED)
1a9e8a9449021bc9ab8da14f69306f30460f45741c1b9719aab0c11167177cba RT-N18U_380.59_HGG-FINAL.trx (34.226KB)
RT-N66U - READY. (UPLOADED)
61fbc90fe692d28cf4ed66e5ba29331fa15962dcc961648008174c8e4e533e99 RT-N66U_380.59_HGG-FINAL.trx (32.276KB)
RT-AC66U - READY. (UPLOADED)
56c36ac59f53c4d14838b0df4ffefbc36ee5ca364a68aae00b643b2291df3cf0 RT-AC66U_380.59_HGG-FINAL.trx (32.378KB)
RT-AC56S - READY. (UPLOADED)
0fb1bca47b38c23de5d45442ef4531ff963c0206775e6fd3af32af0e3738b2b1 RT-AC56S_380.59_HGG-FINAL.trx (33.959KB)
RT-AC56U - READY. (UPLOADED)
011e9b59fc1f23790a9122ae644bf9bd1169ccbe70bcd253ba4af701e86df724 RT-AC56U_380.59_HGG-FINAL.trx (40.914KB)
RT-AC68U - READY. (UPLOADED)
ba5af5338d67dfc76d1b800f7767621f104b32e93cb9a7cf1bc9b2e1360ab083 RT-AC68U_380.59_HGG-FINAL.trx (40.951KB)
RT-AC87U - READY. (UPLOADED)
02f27b513e41135bf8b24d751dc0590693c587150b2b368ad5dfe7405c3bb8cc RT-AC87U_380.59_HGG-FINAL.trx (55.808KB)
RT-AC88U - READY. (UPLOADED)
d9e03b4754c3d8ccd8500a059855d148fc072aa5c994880a6c78f19e9d1632c2 RT-AC88U_380.59_HGG-FINAL.trx (53.362KB)
RT-AC3100 - READY. (UPLOADED)
91a1f6319a94ac7108367042878caa1ad525b25803d8fdd6397869df691772f9 RT-AC3100_380.59_HGG-FINAL.trx (52.396KB)
RT-AC3200 - READY. (UPLOADED)
6640dfdcdc707bcb8e097964f72cb39b5614ae3d140f4f53847252e69e175fdc RT-AC3200_380.59_HGG-FINAL.trx (51.347KB)
RT-AC5300 - READY. (UPLOADED)
7f46022f8b09064504e885582b317b3c9e745909e39fc20d0f70c51ad11fbafb RT-AC5300_380.59_HGG-FINAL.trx (53.415KB)
Just "wetransferred" the 59_final to someone here in The Netherlands. From a very disappointed user he became extremely happy with the coverage of his brand new AC87U.
Hello there!
I am also from the netherlands en just bought a AC87U. The coverage is not what i expected and after a day of searching the Inet, I ended up here, so I subscribed directly!
This final seems to be the solution to the problem, but I don't know where to find it.
Is there a possibility you 'wetransferring" the 59_final build to me?
If so, that would really be great!
Kind regards
Tamaar
See post #21 and read!
Hello there!
Kind regards
Tamaar
Hi Tamaar, just got mine as well and had the same question.
I sent a PM to hggomes and hope he will share the link with me.
Is yours also a red AC87U? :)
Yes, I got the same one!
Also sent hgghomes a PM.
Still searching how to install this firmware as the next step ;)
Nothing different as installation.
- Upload it on router
- Restore factory default
- Do the setting manually
PS: if you have newest firmware from ASUS then probably you have to use first of all the recovery procedure in order to downgrade the FW
Install is the same as Asus or any RMerlin based fork.
Download and extract .trx file. Verify SHA-256 file hash.
Unplug all USB devices from your router. Reboot and wait 5 minutes for it to settle before following the remaining steps below.
http://www.snbforums.com/threads/no...l-and-manual-configuration.27115/#post-205573
You may want to use john9527's excellent NVRAM Save/Restore utility too.
http://www.snbforums.com/threads/user-nvram-save-restore-utility-r24.19521/
Best part of the utility above? All your settings are saved in text (human readable) format. :)
And don't forget the most important points on the changelog.txt file;
* MANDATORY: FACTORY DEFAULT RESTORE (http://ROUTERIP/Advanced_SettingBackup_Content.asp) AND/OR HW RESET IS REQUIRED AFTER FW UPGRADE. *
* ********* DO NOT USE/IMPORT OLD CONFIGURATION FILE FROM A DIFFERENT FW AFTER FLASHING, JUST CONFIGURE IT MANUALLY FROM SCRATCH. *
* ALL WIRELESS CHANNELS ARE UNLOCKED AND AVAILABLE ON THIS FW, SO YOUR CLIENTS COULD NOT USE SOME OF THEM BECAUSE OF REGION LOCK ON THE *
* CLIENT SIDE. DO NOT USE AUTO CONTROL CHANNEL OPTION OR THE ROUTER CAN ACT LIKE IT'S NOT BROADCASTING TO THOSE CLIENTS. *
* ALWAYS CHOOSE A MANUAL CONTROL CHANNEL ON BOTH 2.4 AND 5GHZ BANDS (http://ROUTERIP/Advanced_Wireless_Content.asp) *
Thx for all the help! I will look into it tomorrow when I have more time.
Have a nice evening everyone!
Best regards
Tamaar
I got the 59-final, followed the steps L&LD posted but it does not work... I can't downgrade de new FW and when I try to upload the 59-final, there's a pop-up that tells me this is not the official FW and it does nothing.
Am i doing something completely wrong or is it bad luck and can't I get it to work?
Grts
Hi..
Can anyone please let me know where to download v380.59 for RT-N16?
Send me a PM (Personal Message) with your e-mail address: then I will wetranfer the file to you.
Grts
Which router do you have?
What was the firmware version before you did the upgrade with HGG firmware?
Grts
I had this on my 68u, thought it was buggered, I had to restore using recovery interface with an older firmware, then incrementally upgrade to that version.
Did you done the recovery/rescue procedure in order to downgrade the FW?
I tried to set it back to factory settings, but that is not the same, i guess?
Don't want to look stupid, but how do I do the recovery procedure?
(Probably has to wait till monday... A lot of Inet-addicts in the house right now ;))
It is a totally different thing. It is a procedure documented and with a tool from ASUS and has to be done with some higher attention.
I think that you have the procedure in user manual.
Resetting the settings will not replace the FW version.
You need an older FW pushed in your router in order to allow you any FW. The new FW from ASUS doesn't allow you to use older FW or 3rd party FW.
You are probably on a FW version 380.3xxx and you cant downgrade if your not doing this, you need to enter in RESCUE MODE
Follow these steps its for Ac66, but work for all models, you need to do all the steps from the link
Power off the router: Hold RESET button and power on router,keep holding reset til led begin flashing slowy, release RESET button and you are now in rescue mode
https://www.asus.com/support/faq/1000814/
Thank you all for the help!
I am going to try this as soon as possible.
I really appreciate what you are all doing.
Thanks again!
grts Tamaar
