Thanks for the quick fix.For my scripts, yes
Little off topic, but the "Tools" location was fine in my opinion. "Tools" are quite empty (only two official tabs there), so it could easily host addons as well.
For my scripts, yes
That's planned for a future update. The redirect was just to get something in place so I could roll out the updates for 4 scriptsI like that the help and support page takes you to the forum. I think what would be nice in the future is hyperlinks on that page to take you directly to the threads for the addons while still keeping a link for the general forum.
"Help and Support" takes me to this page:That's planned for a future update. The redirect was just to get something in place so I could roll out the updates for 4 scripts![]()
That may happen if clicking on it at the time the symlink is being refreshed. Try refreshing now"Help and Support" takes me to this page:
Doesn't work, but don't worry about it, ntp works, that is what mattersThat may happen if clicking on it at the time the symlink is being refreshed. Try refreshing now
edit: its on my list to improve
Try runningDoesn't work, but don't worry about it, ntp works, that is what matters![]()
ntpmerlin startup
Just nopeTry running
Code:ntpmerlin startup
gah found the bug. run u (twice) then open ntpmerlin - tab should workJust nopeDeleted, reinstalled, force_updated, rebooted, etc... pretty much tried everything. Going to the root of SHARED_WEB_DIR brings up the gui without css tho (don't know if that's related)
Thanks and sorry but no change. Gives me 404. I'm happy to help if you want to get to the bottom of this, but I consider this a very low priority bug, so it's up to yougah found the bug. run u (twice) then open ntpmerlin - tab should work
Did running u a second time show it downloading redirect.htm?Thanks and sorry but no change. Gives me 404. I'm happy to help if you want to get to the bottom of this, but I consider this a very low priority bug, so it's up to you![]()
ls -la /www/user/shared-jy/
ls -la /jffs/addons/shared-jy/
Not easily as the menu changes based on model, bottom is saferA small request if possible for a future update?
Could the Addons Tab be at the top?![]()
Plus I like it tucked away in the Advanced section. By nature the scripts require some sort of technical aptitude towards using SSH/Unix command line, which I feel classifies them as AdvancedNot easily as the menu changes based on model, bottom is safer
v2.2.3 is now available
Please run option u a second time after updating, and then reboot if you are seeing multiple/missing tabs
Changelog:
Code:WebUI improvements Fixes tab duplication when updating in future
Thread starter | Title | Forum | Replies | Date |
ntpMerlin ntpMerlin compatibility with Merlin 3006.102.3 | Asuswrt-Merlin AddOns | 15 | |
W | ntpMerlin ntpMerlin and timeserverd ntp_ready tests | Asuswrt-Merlin AddOns | 1 |
Welcome To SNBForums
