EmeraldDeer
Switched to develop branch and running 2.5.0 with no issues.Any willing testers? https://github.com/jackyaz/ntpMerlin/pull/34
Using 12 hour mode.
Perhaps I will try toggling from jffs to usb.
05/06/2020-19:55:28.567786 [**] [1:2017919:2] ET DOS Possible NTP DDoS Inbound Frequent Un-Authed MON_LIST Requests IMPL 0x03 [**] [Classification: Attempted Denial of Service] [Priority: 2] {UDP} 185.94.111.1:45551 -> 321.033.88.231:123
Hi, happy to hav a go, but please give me some hints for dummies. I have a previous version that has been running just fine that I would have to update. Presumably I need to runAny willing testers? https://github.com/jackyaz/ntpMerlin/pull/34
If you runHi, happy to hav a go, but please give me some hints for dummies. I have a previous version that has been running just fine that I would have to update. Presumably I need to run
/usr/sbin/curl --retry 3 "https://raw.githubusercontent.com/jackyaz/ntpMerlin/develop/ntpmerlin.sh" -o "/jffs/scripts/ntpmerlin" && chmod 0755 /jffs/scripts/ntpmerlin && /jffs/scripts/ntpmerlin install
Do I need to change install to update perhaps too?
ntpmerlin develop
That's why I added them! While it's a quick change in nano, I was lazy and bored of doing it. There must be a better a way! I thought
Wait it's that easy I didn't need to nano in and change the branch to develop from master?If you runthe script will download from the develop branchCode:ntpmerlin develop
On my scripts (I think it's in all of them now, anyway), yes!Wait it's that easy I didn't need to nano in and change the branch to develop from master?
I think it is better this way jack, because you get to streamline it to testers faster. brilliant.On my scripts (I think it's in all of them now, anyway), yes!
NEW: Option to store stats and config on USB
NEW: Check and perform script updates in the WebUI (big thanks to @dave14305 for the idea and code basis to work from
NEW: Add option to change time format between 24H and 12H
CHANGED: Tooltip behaviour, show on nearest point when intersect on X axis
yes.Obvious question, have you tried a reboot?
'ntpmerlin startup' brought it backSorry about that. I had to ask. When I 'loose' a menu, a reboot usually sorts it.
Thread starter | Title | Forum | Replies | Date |
ntpMerlin ntpMerlin compatibility with Merlin 3006.102.3 | Asuswrt-Merlin AddOns | 15 | |
W | ntpMerlin ntpMerlin and timeserverd ntp_ready tests | Asuswrt-Merlin AddOns | 1 |
Welcome To SNBForums
