:/tmp/home/root# ntpq -4 -c rv | grep jitter
mintc=3, offset=0.000000, frequency=0.000, sys_jitter=0.000000,
clk_jitter=0.000, clk_wander=0.000
/tmp/home/root# ntpq -pn
No association ID's returned
well for now I am uninstalling ntpmerlin as ntpq appears to no longer properly work.
RT-AX88U-C7C0:/tmp/home/root# ntpq -4 -c rv | grep jitter
RT-AX88U-C7C0:/tmp/home/root# ntpq -pn
I still keep getting
it was great while it worked.Code:RT-AX88U-C7C0:/tmp/home/root# ntpq -4 -c rv | grep jitter mintc=3, offset=0.000000, frequency=0.000, sys_jitter=0.000000, clk_jitter=0.000, clk_wander=0.000 RT-AX88U-C7C0:/tmp/home/root# ntpq -pn No association ID's returned RT-AX88U-C7C0:/tmp/home/root#
May 9 23:53:37 RT-AX88U-C7C0 S77ntpd: Waiting for NTP to sync before starting...
May 9 23:53:37 RT-AX88U-C7C0 ntpd[7626]: ntpd exiting on signal 15 (Terminated)
May 9 23:53:37 RT-AX88U-C7C0 ntpd[9032]: ntpd 4.2.8p13@1.3847-o Mon Mar 23 13:21:49 UTC 2020 (1): Starting
May 9 23:53:37 RT-AX88U-C7C0 ntpd[9032]: Command line: ntpd -c /jffs/addons/ntpmerlin.d/ntp.conf -g
May 9 23:53:37 RT-AX88U-C7C0 ntpd[9035]: proto: precision = 0.200 usec (-22)
May 9 23:53:37 RT-AX88U-C7C0 ntpd[9035]: getconfig: Couldn't open </jffs/addons/ntpmerlin.d/ntp.conf>: No such file or directory
May 9 23:53:37 RT-AX88U-C7C0 ntpd[9035]: Listen and drop on 0 v6wildcard [::]:123
May 9 23:53:37 RT-AX88U-C7C0 ntpd[9035]: Listen and drop on 1 v4wildcard 0.0.0.0:123
May 9 23:53:37 RT-AX88U-C7C0 ntpd[9035]: Listen normally on 2 lo 127.0.0.1:123
May 9 23:53:37 RT-AX88U-C7C0 ntpd[9035]: Listen normally on 3 lo:0 127.0.1.1:123
May 9 23:53:37 RT-AX88U-C7C0 ntpd[9035]: Listen normally on 4 eth0 73.104.35.91:123
May 9 23:53:37 RT-AX88U-C7C0 ntpd[9035]: Listen normally on 5 br0 192.168.1.1:123
May 9 23:53:37 RT-AX88U-C7C0 ntpd[9035]: Listen normally on 6 tun21 10.7.0.1:123
May 9 23:53:37 RT-AX88U-C7C0 ntpd[9035]: Listen normally on 7 tun22 10.16.0.1:123
May 9 23:53:37 RT-AX88U-C7C0 ntpd[9035]: Listen normally on 8 lo [::1]:123
May 9 23:53:37 RT-AX88U-C7C0 ntpd[9035]: Listen normally on 9 eth0 [2001:558:6043:2a:dca7:2870:710e:474]:123
May 9 23:53:37 RT-AX88U-C7C0 ntpd[9035]: Listen normally on 10 eth0 [fe80::aa5e:45ff:fead:c7c0%10]:123
May 9 23:53:37 RT-AX88U-C7C0 ntpd[9035]: Listen normally on 11 eth2 [fe80::aa5e:45ff:fead:c7c0%12]:123
May 9 23:53:37 RT-AX88U-C7C0 ntpd[9035]: Listen normally on 12 eth3 [fe80::aa5e:45ff:fead:c7c0%13]:123
May 9 23:53:37 RT-AX88U-C7C0 ntpd[9035]: Listen normally on 13 eth4 [fe80::aa5e:45ff:fead:c7c0%14]:123
May 9 23:53:37 RT-AX88U-C7C0 ntpd[9035]: Listen normally on 14 eth5 [fe80::aa5e:45ff:fead:c7c0%15]:123
May 9 23:53:37 RT-AX88U-C7C0 ntpd[9035]: Listen normally on 15 spu_us_dummy [fe80::200:ff:fe00:0%17]:123
May 9 23:53:37 RT-AX88U-C7C0 ntpd[9035]: Listen normally on 16 spu_ds_dummy [fe80::200:ff:fe00:0%18]:123
May 9 23:53:37 RT-AX88U-C7C0 ntpd[9035]: Listen normally on 17 eth6 [fe80::aa5e:45ff:fead:c7c0%20]:123
May 9 23:53:37 RT-AX88U-C7C0 ntpd[9035]: Listen normally on 18 eth7 [fe80::aa5e:45ff:fead:c7c4%21]:123
May 9 23:53:37 RT-AX88U-C7C0 ntpd[9035]: Listen normally on 19 br0 [2601:348:300:6::1]:123
May 9 23:53:37 RT-AX88U-C7C0 ntpd[9035]: Listen normally on 20 br0 [fe80::aa5e:45ff:fead:c7c0%22]:123
May 9 23:53:37 RT-AX88U-C7C0 ntpd[9035]: Listening on routing socket on fd #37 for interface updates
May 9 23:53:37 RT-AX88U-C7C0 ntpd[9035]: kernel reports TIME_ERROR: 0x2041: Clock Unsynchronized
May 9 23:54:48 RT-AX88U-C7C0 S77ntpd: Waiting for NTP to sync before starting...
May 9 23:54:48 RT-AX88U-C7C0 ntpd[9035]: ntpd exiting on signal 15 (Terminated)
May 9 23:54:48 RT-AX88U-C7C0 ntpd[10215]: ntpd 4.2.8p13@1.3847-o Mon Mar 23 13:21:49 UTC 2020 (1): Starting
May 9 23:54:48 RT-AX88U-C7C0 ntpd[10215]: Command line: ntpd -c /jffs/addons/ntpmerlin.d/ntp.conf -g
May 9 23:54:48 RT-AX88U-C7C0 ntpd[10218]: proto: precision = 0.200 usec (-22)
May 9 23:54:48 RT-AX88U-C7C0 ntpd[10218]: getconfig: Couldn't open </jffs/addons/ntpmerlin.d/ntp.conf>: No such file or directory
May 9 23:54:48 RT-AX88U-C7C0 ntpd[10218]: Listen and drop on 0 v6wildcard [::]:123
May 9 23:54:48 RT-AX88U-C7C0 ntpd[10218]: Listen and drop on 1 v4wildcard 0.0.0.0:123
May 9 23:54:48 RT-AX88U-C7C0 ntpd[10218]: Listen normally on 2 lo 127.0.0.1:123
May 9 23:54:48 RT-AX88U-C7C0 ntpd[10218]: Listen normally on 3 lo:0 127.0.1.1:123
May 9 23:54:48 RT-AX88U-C7C0 ntpd[10218]: Listen normally on 4 eth0 73.104.35.91:123
May 9 23:54:48 RT-AX88U-C7C0 ntpd[10218]: Listen normally on 5 br0 192.168.1.1:123
May 9 23:54:48 RT-AX88U-C7C0 ntpd[10218]: Listen normally on 6 tun21 10.7.0.1:123
May 9 23:54:48 RT-AX88U-C7C0 ntpd[10218]: Listen normally on 7 tun22 10.16.0.1:123
May 9 23:54:48 RT-AX88U-C7C0 ntpd[10218]: Listen normally on 8 lo [::1]:123
May 9 23:54:48 RT-AX88U-C7C0 ntpd[10218]: Listen normally on 9 eth0 [2001:558:6043:2a:dca7:2870:710e:474]:123
May 9 23:54:48 RT-AX88U-C7C0 ntpd[10218]: Listen normally on 10 eth0 [fe80::aa5e:45ff:fead:c7c0%10]:123
May 9 23:54:48 RT-AX88U-C7C0 ntpd[10218]: Listen normally on 11 eth2 [fe80::aa5e:45ff:fead:c7c0%12]:123
May 9 23:54:48 RT-AX88U-C7C0 ntpd[10218]: Listen normally on 12 eth3 [fe80::aa5e:45ff:fead:c7c0%13]:123
May 9 23:54:48 RT-AX88U-C7C0 ntpd[10218]: Listen normally on 13 eth4 [fe80::aa5e:45ff:fead:c7c0%14]:123
May 9 23:54:48 RT-AX88U-C7C0 ntpd[10218]: Listen normally on 14 eth5 [fe80::aa5e:45ff:fead:c7c0%15]:123
May 9 23:54:48 RT-AX88U-C7C0 ntpd[10218]: Listen normally on 15 spu_us_dummy [fe80::200:ff:fe00:0%17]:123
May 9 23:54:48 RT-AX88U-C7C0 ntpd[10218]: Listen normally on 16 spu_ds_dummy [fe80::200:ff:fe00:0%18]:123
May 9 23:54:48 RT-AX88U-C7C0 ntpd[10218]: Listen normally on 17 eth6 [fe80::aa5e:45ff:fead:c7c0%20]:123
May 9 23:54:48 RT-AX88U-C7C0 ntpd[10218]: Listen normally on 18 eth7 [fe80::aa5e:45ff:fead:c7c4%21]:123
May 9 23:54:48 RT-AX88U-C7C0 ntpd[10218]: Listen normally on 19 br0 [2601:348:300:6::1]:123
May 9 23:54:48 RT-AX88U-C7C0 ntpd[10218]: Listen normally on 20 br0 [fe80::aa5e:45ff:fead:c7c0%22]:123
May 9 23:54:48 RT-AX88U-C7C0 ntpd[10218]: Listening on routing socket on fd #37 for interface updates
May 9 23:54:48 RT-AX88U-C7C0 ntpd[10218]: kernel reports TIME_ERROR: 0x2041: Clock Unsynchronized
May 9 23:57:18 RT-AX88U-C7C0 ntpd[10218]: ntpd exiting on signal 15 (Terminated)
May 10 00:37:02 RT-AX88U-C7C0 ntpd[8690]: Listen normally on 0 lo 127.0.0.1:123
May 10 00:37:02 RT-AX88U-C7C0 ntpd[8690]: Listen normally on 1 lo:0 127.0.1.1:123
May 10 00:37:02 RT-AX88U-C7C0 ntpd[8690]: Listen normally on 2 br0 192.168.1.1:123
May 10 00:37:02 RT-AX88U-C7C0 ntpd[8690]: Listen normally on 3 lo [::1]:123
May 10 00:37:02 RT-AX88U-C7C0 ntpd[8690]: Listen normally on 4 br0 [2601:348:300:6::1]:123
May 10 00:37:02 RT-AX88U-C7C0 ntpd[8690]: Listen normally on 5 br0 [fe80::aa5e:45ff:fead:c7c0%22]:123
May 10 00:37:02 RT-AX88U-C7C0 ntpd[8690]: Listening on routing socket on fd #22 for interface updates
May 10 00:37:02 RT-AX88U-C7C0 ntpd[8690]: kernel reports TIME_ERROR: 0x2041: Clock Unsynchronized
Looks like ntpd was dying. What other scripts are you running?It is finally working again. yet I have no clue what caused it so many problems.
Are there any messages from ntpMerlin in syslog after a reboot?I think it is running, but the tab is still gone after another reboot. I ran the "genereate new graphs" from the amtm interface, but didn't see any results.
I will research the code you ran for your output tomorrow, but my eyes are heavy tonight.
My syslog shows:
May 9 23:03:08 RT-AC86U-8F38 ntpd[2796]: Listen normally on 7 tun11 10.8.8.3:123
May 9 23:03:08 RT-AC86U-8F38 ntpd[2796]: new interface(s) found: waking up resolver
I think it is running? There aren't any of the time errors like before. Yet. I will look further in the morning.
good night.
this is services-startAre there any messages from ntpMerlin in syslog after a reboot?
What does your /jffs/scripts/services-start look like?
#!/bin/sh
/jffs/scripts/connmon startup & # connmon
/jffs/scripts/ntpmerlin startup & # ntpMerlin
/jffs/scripts/spdmerlin startup & # spdMerlin
/jffs/scripts/uiScribe startup # uiScribe
Hm, the cron job makes the same call so I'm not sure why that was needed.this is services-start
Code:#!/bin/sh /jffs/scripts/connmon startup & # connmon /jffs/scripts/ntpmerlin startup & # ntpMerlin /jffs/scripts/spdmerlin startup & # spdMerlin /jffs/scripts/uiScribe startup # uiScribe
I had nothing specific in the logs that said ntpmerlin didnt run on time each time. I had to uninstall and reinstall three times to finally get it working. what got the stats and ntpq to finally detect ntpd was working was me running generate from the stat-page.
i am wondering if the cronjob is not properly taking because after install i was locked out. I had to wait the 600 seconds to do anything.Hm, the cron job makes the same call so I'm not sure why that was needed.
I'll go over the install process. It sounds like I've missed a clear lock calli am wondering if the cronjob is not properly taking because after install i was locked out. I had to wait the 600 seconds to do anything.
Yup, I've missed a call on install. It should be fine after the 10mins though. I'll get a fix out shortlyI'll go over the install process. It sounds like I've missed a clear lock call
yea at first i thought entware messed it up with their binariesYup, I've missed a call on install. It should be fine after the 10mins though. I'll get a fix out shortly
Thread starter | Title | Forum | Replies | Date |
ntpMerlin ntpMerlin compatibility with Merlin 3006.102.3 | Asuswrt-Merlin AddOns | 15 | |
W | ntpMerlin ntpMerlin and timeserverd ntp_ready tests | Asuswrt-Merlin AddOns | 1 | |
D | NTPmerlin config log not found | Asuswrt-Merlin AddOns | 2 |
Welcome To SNBForums
