Jumpstarter
so what is the future of chrony, i think i have time to finally test it. how do i switch ntpmerlin to use it?
i guess opkg doesn't bother killing the running process.I still see this:
is it expected after removing chrony ntpmerlin develop?
thx
killall chronyd
IMHO most time critical servers/services are moving to chrony. It is now the default ntp server/client on Red Hat Ubuntu and Debian (and others I would imagine). Its also used now by AWS and Facebook.so what is the future of chrony, i think i have time to finally test it. how do i switch ntpmerlin to use it?
/usr/sbin/curl --retry 3 "https://raw.githubusercontent.com/jackyaz/ntpMerlin/mas
ter/ntpmerlin.sh" -o "/jffs/scripts/ntpmerlin" && chmod 0755 /jffs/scripts/ntpmerlin && /jffs/scripts/ntpmerlin install
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 45116 100 45116 0 0 231k 0 --:--:-- --:--:-- --:--:-- 263k
ntpMerlin: Welcome to ntpMerlin v2.5.1, a script by JackYaz
ntpMerlin: Checking your router meets the requirements for ntpMerlin
ntpMerlin: Installing required packages from Entware
Downloading http://bin.entware.net/aarch64-k3.10/Packages.gz
Updated list of available packages in /opt/var/opkg-lists/entware
Upgrading sqlite3-cli on root from 3320100-1 to 3330000-1...
Downloading http://bin.entware.net/aarch64-k3.10/sqlite3-cli_3330000-1_aarch64-3.10.ipk
Configuring sqlite3-cli.
Package p7zip (16.02-3) installed in root is up to date.
Installing ntp-utils (4.2.8p15-2) to root...
Downloading http://bin.entware.net/aarch64-k3.10/ntp-utils_4.2.8p15-2_aarch64-3.10.ipk
Installing libevent2-core (2.1.11-2) to root...
Downloading http://bin.entware.net/aarch64-k3.10/libevent2-core_2.1.11-2_aarch64-3.10.ipk
Installing libevent2-pthreads (2.1.11-2) to root...
Downloading http://bin.entware.net/aarch64-k3.10/libevent2-pthreads_2.1.11-2_aarch64-3.10.ipk
Configuring libevent2-core.
Configuring libevent2-pthreads.
Configuring ntp-utils.
Installing ntpd (4.2.8p15-2) to root...
Downloading http://bin.entware.net/aarch64-k3.10/ntpd_4.2.8p15-2_aarch64-3.10.ipk
Configuring ntpd.
/jffs/scripts/ntpmerlin: line 1445: can't open /jffs/addons/ntpmerlin.d/ntpdstats_www.asp: no such file
ntpMerlin: New version of ntpdstats_www.asp downloaded
ntpMerlin: Mounting ntpMerlin WebUI page as user3.asp
Checking ntpd... dead.
S77ntpd: Waiting for NTP to sync before starting...
Starting ntpd... done.
SQLite header and source version mismatch
2020-05-25 16:19:56 0c1fcf4711a2e66c813aed38cf41cd3e2123ee8eb6db98118086764c4ba83350
2020-08-14 13:23:32 fca8dc8b578f215a969cd899336378966156154710873e68b3d9ac5881b0ff3f
dos2unix: can't open '/jffs/addons/ntpmerlin.d/csv/*.htm': No such file or directory
cp: can't stat '/jffs/addons/ntpmerlin.d/csv/*.htm': No such file or directory
Oct 19 09:51:42 S77chronyd: Waiting for NTP to sync before starting...
Oct 19 08:51:42 chronyd[4403]: chronyd version 3.5 starting (+CMDMON +NTP +REFCLOCK -RTC +PRIVDROP -SCFILTER -SIGND +ASYNCDNS -SECHASH +IPV6 -DEBUG)
Oct 19 08:51:42 chronyd[4403]: Fatal error : Could not get user/group ID of nobody
Oct 19 09:51:53 admin: Failed to start chronyd from .
Sounds like your nobody user has gone missing on the system, which is strange.Hey Jack, i just noticed that from a couple of days now I can't use chrony with your dev branch.
I reinstalled ntpmerlin, manually removed chrony from entware, etc etc and the same result.Code:Oct 19 09:51:42 S77chronyd: Waiting for NTP to sync before starting... Oct 19 08:51:42 chronyd[4403]: chronyd version 3.5 starting (+CMDMON +NTP +REFCLOCK -RTC +PRIVDROP -SCFILTER -SIGND +ASYNCDNS -SECHASH +IPV6 -DEBUG) Oct 19 08:51:42 chronyd[4403]: Fatal error : Could not get user/group ID of nobody Oct 19 09:51:53 admin: Failed to start chronyd from .
Odd.Sounds like your nobody user has gone missing on the system, which is strange.
please tryMy "add ons" tab in the web gui has disappeared, and the /user4.asp page returns a 404. I've completed a uf of NTPMerlin and rebooted my router (AC68U) with no luck. Any ideas on how to get it back?
ntpmerlin startup
@Jack Yaz , You have done a great job on incorporation of Chronyc into your script schematics. It has been running now for a while with no complaints.
ntpmerlin develop will be made stable soon. I am working through tidying up my entire script set, connmon is done with modmon being worked on next. after that? ntpmerlin
Thanks, that is a big workflow you got going on there. Lemme know if you need testing.ntpmerlin develop will be made stable soon. I am working through tidying up my entire script set, connmon is done with modmon being worked on next. after that? ntpmerlin
Thanks a big workflow you got going on there. Lemme know if you need testing.
How about FlexQoS?after that? ntpmerlin
please try
Code:ntpmerlin startup
Welcome To SNBForums
