Release Asuswrt-Merlin 3006.102.3 is now available for WIfi 7 devices
After updating the firmware on my BE 98 Pro, it started recognizing the HomePod as if it were physically connected.
And the last digit of the HomePod’s MAC address is also different.
Try using MerlinAU to upgrade (install using amtm) — I have been able to upgrade other routers that otherwise refused to update. @ExtremeFiretop and @Martinski have created a masterpiece!
Sadly no luck I even tried forcing the update using recovery mode but that just puts the pro into a bootloop tried even changing to default firmware and it does the same so just stuck on 3006.102.2_2
If even Recovery Mode is causing issues such as a boot loop then I would double check that you really have a GT-BE98_PRO and not a GT-BE98.
It’s definitely a GT-BE98_PRO
Have you tried restoring the BE 98 Pro to factory settings by holding down the reset button on the device?
You can try:
1、Update the router's official firmware to the latest version.
2、Before installing the Merlin firmware, perform a factory reset to ensure the router is in a clean state. This can be done by holding down the reset button on the back of the router for about 10 seconds.
3、Try using different browsers (such as Chrome or Firefox) to upload the firmware. You can also clear the current browser's cache and cookies before attempting the upgrade again.
You can try:
I’ve tried this as well last night but still no luck, gonna wait a while and try again
My GT-BE98 Pro is refusing to upgrade for some reason I’ve factory reset and tried but it keeps coming up as 3006.102.2_2 and I’ve also set the ram setting to bypass downgrade blocking
Did you commit the change after entering your downgrade exception?
nvram set DOWNGRADE_CHECK_PASS=1
nvram commit
Just wanted to quickly stop by and kindly ask if you could potentially send logs from a regular update (not recovery)?
System logs showing the update process would be incredibly valuable in situations like this, and may give a hint as to what the cause of friction is.
Waiting for 3006 AsusWRT Merlin for AX86U Pro 🤣
It don't look like it's going to be supported with 3.0.0.6 from Merlin. He has shown zero interest in supporting the AX models with the newer code branch. He just keeps doing more of the same 3.0.0.4.
He has stated many times that there is nothing he can do about Merlin 3006 for AX Pro until ASUS gives him binaries for those devices (which to my knowledge has yet to happen).
He can only work with what GPL's Asus provides him. (Link)
This has always been the case, each model always had its own separate GPL. It's impossible to share a GPL for more than one model, as each GPL contains precompiled pieces that only work for one specific device.
You can try this:
Use:
nvram commit
I've updated a RT-BE88U to this firmware and I'm having a problem if I use a Wireguard client.
I'm not sure if here is the place to post this.
The problem is I lose internet access from any LAN device if I reboot the router with the Wireguard client connected. The access through VPN works without problem. The Internet access from router works also.
I'm able to recover Internet access if I enable o disable the Enable DoS protection, for example. But if I reboot the router I lose again Internet access from LAN devices.
Details:
Firstly, I've updated with no restore to factory defaults, keeping the settings and the problem has shown up.
Secondly, due to this problem, I've reflashed the firmware (last version again), restored to factory defaults and reconfigure the router manually, avoiding restore with backup file, but the problem remains.
Wireguard client:
interface: wgc1
  public key: ESuRxg7qrQ33O+f8ZNvUq6lEhu25Yrx4/La/x+2cJWQ=
  private key: (hidden)
  listening port: 41800
peer: rRCPBi8gzsnIVMpMIytNShJGdMFJbzX/X9yyMJRaF2U=
  preshared key: (hidden)
  endpoint: SERVERIP:PORT
  allowed ips: 0.0.0.0/0
  latest handshake: 7 seconds ago. (sec:7)
  transfer: 184 B received, 520 B sent
  persistent keepalive: every 25 seconds
VPN Director:
According to this, only traffic to these network o that IP would be sent through VPN. Otherwise it would use WAN.
If I reboot the router:
  • From a desktop I can reach other LAN through VPN:
$ traceroute -n 192.168.60.11
traceroute to 192.168.60.11 (192.168.60.11), 30 hops max, 60 byte packets
 1  192.168.50.1  0.511 ms  0.527 ms  0.402 ms
 2  10.60.0.1  131.227 ms  131.583 ms  131.725 ms
 3  192.168.60.11  131.645 ms  131.583 ms  131.519 ms
  • From a desktop I can't reach any other network:
$ traceroute -n 1.1.1.1
traceroute to 1.1.1.1 (1.1.1.1), 30 hops max, 60 byte packets
 1  192.168.50.1  0.669 ms  0.564 ms  0.514 ms
 2  * * *
 3  * * *
29  * * *
30  * * *
  • From the router I can reach any other network:
# traceroute -n 1.1.1.1
traceroute to 1.1.1.1 (1.1.1.1), 30 hops max, 38 byte packets
 1  MYGATEWAY  0.652 ms  0.856 ms  0.972 ms
 2  10.63.34.213  1.470 ms  1.969 ms  1.479 ms
 3  10.63.0.246  1.975 ms  1.476 ms  10.63.0.73  2.478 ms
 4  10.63.128.146  1.973 ms  10.63.33.185  2.475 ms  1.976 ms
 5  10.63.128.169  2.473 ms  10.63.0.70  2.473 ms  10.63.128.169  2.978 ms
 6  10.63.152.38  2.972 ms  10.63.36.212  3.971 ms  10.63.152.38  2.476 ms
 7  170.250.254.118  3.975 ms  3.477 ms  170.250.254.37  3.478 ms
 8  170.250.254.1  3.969 ms  170.250.254.9  3.976 ms  170.250.254.5  4.977 ms
 9  170.250.254.5  3.975 ms  108.162.211.66  4.474 ms  170.250.254.5  4.475 ms
10  108.162.211.236  2.472 ms  108.162.211.232  3.977 ms  108.162.211.228  3.976 ms
11  1.1.1.1  2.968 ms  3.477 ms  108.162.211.228  3.479 ms
Routes:
# ip rule
0:    from all lookup local
20:    from all lookup 8437
11210:    from all to 192.168.60.0/24 lookup wgc1
11211:    from all to 54.242.237.204 lookup wgc1
32766:    from all lookup main
32767:    from all lookup default
# ip route show table wgc1
0.0.0.0/1 dev wgc1 scope link
10.60.0.1 dev wgc1 scope link
SERVERIP via MYGATEWAY dev eth0
128.0.0.0/1 dev wgc1 scope link
# ip route show table main
default via MYGATEWAY dev eth0
76.76.2.0 via MYGATEWAY dev eth0 metric 1
127.0.0.0/8 dev lo scope link
MYSUBNET/MASK dev eth0 proto kernel scope link src MYIP
MYGATEWAY dev eth0 proto kernel scope link
192.168.50.0/24 dev br0 proto kernel scope link src 192.168.50.1
192.168.52.0/24 dev br55 proto kernel scope link src 192.168.52.1
194.242.2.2 via MYGATEWAY dev eth0 metric 1
239.0.0.0/8 dev br0 scope link
# ip route get 1.1.1.1 from 192.168.50.3 iif br0
1.1.1.1 from 192.168.50.3 via MYGATEWAY dev eth0
    cache iif br0
If for example I enable (or disable) DoS protection (no reboot) I can reach any Internet network from any LAN device. But the routes remain the same:
# ip rule
    cache iif br0
What could be happening? Why do I lose Internet access from LAN devices when I reboot the router, but when I modify DoS protection or even disable/enable Firewall the problem disappears until the next reboot?
This behavior worries me in case the router reboots and I don't notice.
Regards
What Merlin said was, He has never asked Asus for 3.0.0.6 GPL for supported AX devices. That sums it up pretty well.
With the 3006.102.3 Merlin firmware on my RT-BE88U, I am still having the same issue that I had with the initial 3006.102.2 beta which I didn't have with the stock ASUS software ( migrated from stock 3.0.0.6.102_37103 with a full system reset after install).
I cannot get IPv6 working with Connection Type set to 'Native' and Interface set to 'PPP':
Everything else is working fine using IPv4.
I am using BT FTTP in the UK and my WAN Connection Type is set to PPPoE.
BT issue a dynamic /56 prefix.
The IPv6 functionality worked fine with the latest stock firmware.
If it is relevant, I am using the 2.5 Gbps WAN/LAN1 port as my WAN port:
I created a system log (attached) by disabling IPv6, clearing the system log and then re-enabling IPv6 with the settings seen above.
I haven't asked them because when we discussed a general roadmap last year, the plan was wait before moving existing devices to 3006 as the code was not mature enough yet. Hence the reason why I haven't asked for it yet, not because I didn't want to.
There seems to be a bug in the DDNS config. Even although I have been able to succesfully establish an IPv6 WAN Address, I get the followinmg in the Logs
I'm using no-ip.com for DDNS.
watchdog: start ddns.
Jan 15 15:19:11 hostapd: wl1.1: STA a8:ca:77:c6:62:48 IEEE 802.11: disassociated
Jan 15 15:19:11 wlceventd: wlceventd_proc_event(645): wl1.1: Deauth_ind A8:CA:77:C6:62:48, status: 0, reason: Unspecified reason (1), rssi:-49
Jan 15 15:19:11 wlceventd: wlceventd_proc_event(685): wl1.1: Auth A8:CA:77:C6:62:48, status: Successful (0), rssi:-49
Jan 15 15:19:11 ddns: ppp0 has not yet obtained an WAN IPv6 address.(2)
Jan 15 15:19:11 ddns: current ipv6_service: dhcp6 | old ipv6_service: dhcp6
Jan 15 15:19:11 ddns: IP address, server and hostname have not changed since the last update.
RT-BE86U on Release 3006.102.3 I am connecting to my Provider (BT UK) via PPOE. Never had this issue on my RT-AX86U
