Jack Yaz
Part of the Furniture
You're doing an excellent job with FlexQos. I use it myself and follow your commits on the develop branch to see what's coming nextHow about FlexQoS?![]()
For those who switched over to Chrony....have you made any changes to the config?
Some nice goodies on the develop branch, option uf may be needed to pull down the updated WebUI page
That suggests your config file was set to ntpd, i guess maybe where you manually pioneered chrony? I can't say I've seen any issues with the pid file in testingQuick question. Where does the pid file for chrony reside? I did the uf update (nice addons!) but ntpd was shown as the Timeserver. I clicked on chrony - but it didn't restart. It was running.
From what I have seen in the past, it thinks it is already running (it wasn't).
I started it manually.
Maybe on an S77chronyd restart, force remove the pid file?
no worries!That was it... Yes, I had compiled and installed chronyd before Entware made it available...
My original chrony.conf was in /opt/share/ntpmerlin.d.
In the past, the most likely startup failure was a pid file hanging around. I checked the logs after you mentioned config file and:
chronyd[14362]: Fatal error : Could not open configuration file /jffs/addons/ntpmerlin.d/chrony.conf : No such file or directory
So, moved my config file to /jffs/addons/ntpmerlin.d and a restart worked.
Thanks (I should have checked the log...)
If that is the case we need to excite someone in the entware dev team to add it.no worries!
in other news, have you dabbled with nts to upstream? https://fedoramagazine.org/secure-ntp-with-nts/
I think we'll need chrony v4 though![]()
they're usually quite happy to update packages on request via issues on github, but make sure v4 is actually released as stable first!If that is the case we need to excite someone in the entware dev team to add it.
Yes, I saw the 4.0 branch. I have compiled it on my AX88u. Running quite well. I can't seem to get NTS enabled. It requires the gnutls library. The configure script reports no gnutls - so NTS is disabled. I did install the two gnutls packages available on entware. Still won't compile with NTS enabled.no worries!
OK, since it isn't as simple as I'd hoped I won't hold up releasing v3 any longer. Incoming!Yes, I saw the 4.0 branch. I have compiled it on my AX88u. Running quite well. I can't seem to get NTS enabled. It requires the gnutls library. The configure script reports no gnutls - so NTS is disabled. I did install the two gnutls packages available on entware. Still won't compile with NTS enabled.
I did compile it with NTS support on Raspbian. Haven't tested NTS (Cloudflare claims to support NTS).
We will have to ask the Entware devs to make sure NTS is enabled when we ask for 4.0
NEW: ntpMerlin can be configured using the WebUI
NEW: Choice of chrony or ntpd as timeserver used by ntpMerlin
IMPROVED: WebUI now uses a dropdown to select a time period for charts
IMPROVED: Update modmon using the WebUI
For the time being, you could try to replace the "-u nobody" with "-u admin" in /opt/etc/init.d/S77chronyd...I'm stuck yet with the missing nobody user. Can't solve it.
I assume you have rebooted? What do you see in /etd/passwd?I'm stuck yet with the missing nobody user. Can't solve it.
Same problem...For the time being, you could try to replace the "-u nobody" with "-u admin" in /opt/etc/init.d/S77chronyd...
Thread starter | Title | Forum | Replies | Date |
ntpMerlin ntpMerlin compatibility with Merlin 3006.102.3 | Asuswrt-Merlin AddOns | 15 | |
W | ntpMerlin ntpMerlin and timeserverd ntp_ready tests | Asuswrt-Merlin AddOns | 1 |
Welcome To SNBForums
