Having worked with multi cultural and international teams, I had to adjust and adapt. This brief summary highlights the differences in communication norms by country.Dont worry, i am in the same boat
Main account deleted (not this one ) 2014, ban for nothing with no reasons.
Only answers was... Sorry this was a mistake!
How you resolve the issue? I have not test it.. I ask just in case I have similar problem...I came back to 382..2 beta3 on my asus ac68u....now enable/disable guest network are ok....I think that 384.3 alpha version for ac68u needs more debugging to fix errors so that it can go to the next beta stage.
Lol.. ok... so confuse with all the numbering..I have tested it and can confirm that it doesn’t work on my RT-AC68U. I suspect that it is because the wifi is not restarted after saving the new guest network settings. Wifi clients remain connected and that was not the case with the older firmware versions.
He did a downgrade from the new alpha to the old beta. the guest network works well there.
It's an Alpha release - what do you expect?I did a downgrade from this alpha to 382.2 beta 3. The alpha has to many bugs!
Creating a new guest network doesn’t work properly. Changing DNS servers only works after reboot.
Alpha releases are issued to aid the development process by collecting issues quicker than the developer can in isolation. You should expect a high number of bugs if you install Alpha code.
That might be because it's the first alpha from the 384 branch. If you don't want bugs, wait for a stable release.That's right! But normally he was not as full of bugs as now
Has anyone else had issues with USB flash drives. Was working fine with Beta3 but seems to be having issues with the Alpha.
Go to wireless tab and click on professional and then select 2.4 and check the usb3 interference option make sure it is enabled.Has anyone else had issues with USB flash drives. Was working fine with Beta3 but seems to be having issues with the Alpha.
Jan 20 21:24:30 kernel: usb 2-2: device descriptor read/64, error -110
Jan 20 21:24:45 kernel: usb 2-2: device descriptor read/64, error -110
Jan 20 21:24:46 kernel: usb 2-2: new high speed USB device using ehci_hcd and address 4
Jan 20 21:24:56 kernel: usb 2-2: device not accepting address 4, error -110
Jan 20 21:24:56 kernel: usb 2-2: new high speed USB device using ehci_hcd and address 5
Jan 20 21:25:07 kernel: usb 2-2: device not accepting address 5, error -110
Jan 20 21:25:07 kernel: hub 2-0:1.0: unable to enumerate USB device on port 2
Jan 20 21:25:07 kernel: usb 3-2: new full speed USB device using ohci_hcd and address 2
Jan 20 21:25:22 kernel: usb 3-2: device descriptor read/64, error -110
Jan 20 21:25:38 kernel: usb 3-2: device descriptor read/64, error -110
Jan 20 21:25:38 kernel: usb 3-2: new full speed USB device using ohci_hcd and address 3
Jan 20 21:25:53 kernel: usb 3-2: device descriptor read/64, error -110
Jan 20 21:26:08 kernel: usb 3-2: device descriptor read/64, error -110
Jan 20 21:26:08 kernel: usb 3-2: new full speed USB device using ohci_hcd and address 4
Jan 20 21:26:19 kernel: usb 3-2: device not accepting address 4, error -110
Jan 20 21:26:19 kernel: usb 3-2: new full speed USB device using ohci_hcd and address 5
Jan 20 21:26:29 kernel: usb 3-2: device not accepting address 5, error -110
Jan 20 21:26:29 kernel: hub 3-0:1.0: unable to enumerate USB device on port 2
As Eric mentioned before, it is a new codebase... first alpha... don’t expect too much...That's right! But normally he was not as full of bugs as now![]()
You do understand the meaning of test build right? And this is alpha, it's not even beta yet, of course there's bugs. It's the whole idea of TEST BUILD. Even the title called [Preview]. If you wants to help, provide logs of the issue, but before that, search this discussion whether there's other who reported it.I did a downgrade from this alpha to 382.2 beta 3. The alpha has to many bugs!
Welcome To SNBForums
