Tutorial pyLoad Download Manager through Optware
Try with just one usb drive inserted with a single partition, ext2 or ext3
There is a public beta available http://forum.pyload.org/viewtopic.php?f=7&t=2795
OK I'll try your suggestions one by one (starting with a single ext2 partition). BTW I got an answer in pyload's forum from the site admin stating "This is not due to pyload, but on very strict os like routers it may simply kill the process.". It seems to "simply kill the process" but I guess I would also have problems with transmission if that was the case
I think I can't use entware on the ac68u because it's ARM based
Didn't know you are using rt-ac68u, you could try to setup debian and install from there.
Sent from my HTC One using Tapatalk
I already have pyload running on an ubuntu pc but that's not a solution...
I noticed that when pyload downloads are running free memory is around 20MB, so I guess that's why my router kills pyload. Will it help if I add a swap partition on my usb flash drive?
I mean debian on your router :). Yes you can try creating a swap partition.
Debian on my router? That sounds nice! I'll try swap for now but I'll definitely think about your suggestion. :)
I can't access to the web interface
after install the download master and uninstall the download master
then follow the step to install
finally, I can't access to the pyload web interface
i don't know why i cant access to 192.168.1.1:8000
is it something wrong at the installation?
please help me to check it what problem has happen~thank you
My router is RT-AC56U
Firmware:3.0.0.4.374.39 (Merlin build)
The log file is here Please Help me thank you;)
https://db.tt/mKhpBvqj
thank you
i will check it
ask you one more question
how can i host a website in the server
is this router can use the lighttpd?
thank you
Thanks for this. I followed your instructions and it installed as described on my rt-ac68u and works!
I have one question although this may be outside the scope of this forum: I have the astrill openvpn applet installed on the router as well. How would I go about routing pyload through the openvpn tunnel? The download stops if I connect to the openvpn server. I have upnp disabled if that is relevant.
Thanks again.
I installed pyload in entware.But not working.Please help optware and entware start stop scripts is different.I installed pyload from opkg with opkg install pyload command.But pyload process is not visible with top command.And 8000 port not working very please help.
I can istall all packages from the tutorial on the first page except tesseract-ocr, or more precise libjpeg, a dependent package I suppose
admin@RT-AC68U-CD40:/tmp/home/root# ipkg install tesseract-ocr
Installing tesseract-ocr (2.03-3) to /opt/...
Downloading http://ipkg.nslu2-linux.org/feeds/optware/mbwe-bluering/cross/stable/tesseract-ocr_2.03-3_arm.ipk
Installing libjpeg (6b-3) to /opt/...
Downloading http://nw-dlcdnet.asus.com/asusware/arm/stable/libjpeg_6b-3_arm.ipk
wget: server returned error: HTTP/1.1 404 Not Found
Nothing to be done
An error ocurred, return value: 22.
Collected errors:
ipkg_download: ERROR: Command failed with return value 1: `wget    -q -P /opt/ipkg-4QaHxa http://nw-dlcdnet.asus.com/asusware/arm/stable/libjpeg_6b-3_arm.ipk'
Failed to download libjpeg. Perhaps you need to run 'ipkg update'?
What's wrong wit this package? Does somebody know?
Regards
It's not there, to install
ipkg install libjpeg
or
ipkg install http://ipkg.nslu2-linux.org/feeds/optware/mbwe-bluering/cross/stable/libjpeg_6b-3_arm.ipk
TeHashX, thank you for reply!
I already found and installed this package manually. So pyLoad itself is working. /opt/etc/init.d/S95Pyload seems to be not executed at the startup, I have to execute this script manually. Do I need some start scripts in /jffs/scripts, or anywhere else? I hoped the installation of the Asus Download Master creates all necessary scripts automatically...
Regards
Regards
Read again first page, did you created post-mount script?
