TeHashX
Did you followed the guide exactly?
http://ascii.io/a/2989
Has anyone tried using NTFS instead of ext
Hi TeHashX
Thanks for your help on installing Entware. Got both entware and transmission working normallyDo i setup Pyload with the same commands found in this post which i previously had installed in optware ? Or is there another guide for entware.Thanks again for all your help
opkg install pyload
cd /opt/share/python/pyload
python pyLoadCore.py --changedir --configdir=/opt/etc/pyload/.pyload
[I]enter
enter[/I]
cd /opt/etc/pyload/.pyload
/usr/sbin/openssl genrsa -out ssl.key
/usr/sbin/openssl req -new -key ssl.key -out ssl.csr
/usr/sbin/openssl req -days 36500 -x509 -key ssl.key -in ssl.csr > ssl.crt
python pyLoadCore.py -s
Ok pyload seems to have installed ok but the server won't start with /opt/etc/init.d/S95Pyload start![]()
So to startup the server i have to put -l /opt/etc/init.d instead of /opt/etc/init.d/S95Pyload start ?Look in init.d folder, has another name on entware
ls -l /opt/etc/init.d
Sent from my HTC One S
admin@RT-AC66U:/tmp/home/root# ls -l /opt/etc/init.d
-rwxr-xr-x 1 admin root 438 Oct 14 17:42 S51pyload
-rwxr-xr-x 1 admin root 192 Aug 17 18:28 S70mysqld
-rwxr-xr-x 1 admin root 228 May 8 15:26 S80lighttpd
-rwxr-xr-x 1 admin root 229 Aug 17 20:06 S88transmission
-rwxrwxrwx 1 admin root 1673 May 20 17:39 S99debian
-rw-r--r-- 1 admin root 2788 May 8 12:47 rc.func
-rwxr-xr-x 1 admin root 841 May 8 12:47 rc.unslung
/opt/etc/init.d/S51pyload start
Aaaaa ok that makes more sense nowNols -l /opt/etc/init.d is the command to list files in init.d folder
Now pyload is named S51pyloadCode:admin@RT-AC66U:/tmp/home/root# ls -l /opt/etc/init.d -rwxr-xr-x 1 admin root 438 Oct 14 17:42 S51pyload -rwxr-xr-x 1 admin root 192 Aug 17 18:28 S70mysqld -rwxr-xr-x 1 admin root 228 May 8 15:26 S80lighttpd -rwxr-xr-x 1 admin root 229 Aug 17 20:06 S88transmission -rwxrwxrwx 1 admin root 1673 May 20 17:39 S99debian -rw-r--r-- 1 admin root 2788 May 8 12:47 rc.func -rwxr-xr-x 1 admin root 841 May 8 12:47 rc.unslung
On entware, pyload will start automatically on every router reboot and don't need to create another startup script, if you want to start manually, type:
Code:/opt/etc/init.d/S51pyload start
Hi TeHashX
Just installed Pyload and everything is working as before on optware. The Pyload installation and entware was installed on sda5 one of the the partitions i have on my disk.On optware i had my transmission installation and optware on sda6 on my drive.I had issues in the past with putting those 2 on one disk so i separated them.Do i have to do the same with entware ?![]()
Installed both on the same partition.Transmission starts on restarting the router but Pyload doesn't so the start script must be inserted manually in putty.Try and see after, may work ok on both ways.
It's almost the same, only few things changed
Hello, I've installed pyLoad 0.4.9 on my ASUS RT-AC68U (optware). It seems to be working ok but it crashes at random points when downloading. I just have to start it and it resumes the downloads until it crashes again. It doesn't state anything in the Logs tab. Can you please help me with this? I can't use it if it crashes all the time.
Thank you in advance...
Hello, thanks for your response.I don't have a rt-ac68u to test, give me more details about you configuration: usb hdd file system, other packages installed...
/dev/sdb1 on /tmp/mnt/optware type ext4 (rw,nodev,relatime,barrier=1,data=writeback)
/dev/sdb2 on /tmp/mnt/data type ext4 (rw,nodev,relatime,barrier=1,data=ordered)
Welcome To SNBForums
