I believe that ASUS download manager uses optware, whereas ABsolution is trying to use entware. The two don't play nicely with each other, so you won't be able to run the download manager and use pixelserv as part of AB at the same time.
I got to the point where i had to modify the ps install state from 5 to 6:
# Entware and pixelserv settings #
pixelserv="1"
psInstallState="6"
Like mentioned to do because i ran into the issue the other guy before me did. Once I do this and type 11, i get an error in the 22 menu listed as.
checking pixelserv-tls
192.168.1.254 responded, looks good
pixelserv-tls is not running, restarting
Shutting down pixelserv-tls... done.
Starting pixelserv-tls (AB-Solution)... done.
Also:
./S80pixelserv-tls.1 check
Checking pixelserv-tls (AB-Solution)... alive.
Nov 4 22:19:30 USER: Started pixelserv-tls (AB-Solution) from .
Nov 4 22:19:30 pixelserv[16289]: Listening on :192.168.1.253:80
Nov 4 22:19:30 pixelserv[16289]: Abort: Address already in use - :192.168.1.253:443
** my IP pool is up to .240 and nothing has .253 other then pixelserv after I set it.
Is this due to me having downloand manager installed at one point. Is there something I can do to remove it completley? or fix my issue
