[Release] Asuswrt-Merlin 380.64_2 is now available
Chrome in incognito or not shows like the attached, any fixes?
Updated RT-AC1900P from 380.63 to 380.64 running for 24 hours without problems.
hi upgraded to 380.64 on TM-AC1900 and having issues where 5ghz device (Amazon Fire Stick) is not showing in the connection list even though its working fine. Tried refreshing the browser and also tried in firefox and chrome but no difference.
Pinging 192.168.1.95 with 32 bytes of data:
Reply from 192.168.1.95: bytes=32 time=35ms TTL=64
Reply from 192.168.1.95: bytes=32 time=1ms TTL=64
Reply from 192.168.1.95: bytes=32 time=2ms TTL=64
Ping statistics for 192.168.1.95:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 1ms, Maximum = 35ms, Average = 9ms
It most certainly doesn't do that on any of my systems.
Clear browser cache and try again, if that doesn't help power off the router ( remove plug from power supply) leave for 5 minutes and power on again.
I believe there's something wrong with UI in the last couple releases. It is broken on my several macOS and iOS devices rinning Safari. Desktop Chrome works OK but desktop Safari and mobile Safari and Chrome on iPad display glitches all over the place, pages constantly reloaded after crashes and so on. Does anyone use Safari to work with web UI?
AC5300 if important.
What is also curious I cannot update the router from Safari. It uploads firmware file, indicates updating progress bar but after reboot the fw version stays the same. In Chrome though all works like a charm.
I installed 380.64 and everything was working great...until i noticed the flashing ! notifying me I am almost at maximum for NVRAM.
What can a NON linux coder do to free up space on the NVRAM? I read at some other site to use a flash drive and put
ca.crt, user.crt, user.key
on it so the router looks for that info on the flash drive? and not on the NVRAM?
How much space will be saved by doing that? and can a NON coder be given simple instructions to be able to do it?
My only reason for using asuswrt is to use vpn on the router for all attached devices.
I took the plunge and updated my AC5300 from 380.4164 to 380.64 and it is running without a problem. I am seeing the following afpd related log entries, but TimeMachine is working fine for two computers.
Dec 24 07:25:16 afpd[11188]: AFP3.3 Login by user
Dec 24 07:25:16 cnid_dbd[11190]: Couldn't open extension maping file /usr/etc/extmap.conf
Dec 24 07:25:16 cnid_dbd[11190]: Couldn't load extension -> type/creator mappings file "/usr/etc/extmap.conf"
Dec 24 07:27:47 afpd[11188]: AFP logout by user
Dec 24 07:27:47 afpd[11188]: AFP statistics: 129720.37 KB read, 485115.20 KB written
Dec 24 07:27:47 afpd[11188]: done
Dec 24 07:53:09 afpd[11288]: bad function 7A
Dec 24 07:53:09 afpd[11288]: AFP3.3 Login by user
Dec 24 07:53:09 cnid_dbd[11289]: Couldn't open extension maping file /usr/etc/extmap.conf
Dec 24 07:53:09 cnid_dbd[11289]: Couldn't load extension -> type/creator mappings file "/usr/etc/extmap.conf"
Dec 24 07:55:28 afpd[11288]: AFP logout by user
Dec 24 07:55:28 afpd[11288]: AFP statistics: 26934.39 KB read, 133827.26 KB written
Dec 24 07:55:28 afpd[11288]: done
Thanks!
Hi there,
Am I doing something wrong, or are the DNS Filter add/delete controls broken in this build?
Capture.jpg~original
Thanks!
ApK
I spoke too soon... TimeMachine is failing now on the client side wit the following in the system log:
Dec 24 09:30:26 afpd[12314]: AFP3.3 Login by user
Dec 24 09:31:35 kernel: BUG: Bad page state in process afpd  pfn:508a2
Dec 24 09:31:35 kernel: page:88213440 count:0 mapcount:0 mapping:(null) index:0x41a
Dec 24 09:31:35 kernel: page flags: 0x50000004(referenced)
Dec 24 09:31:35 kernel: [<8005701c>] (unwind_backtrace+0x0/0xf8) from [<800b3640>] (bad_page+0xb4/0x110)
Dec 24 09:31:35 kernel: [<800b3640>] (bad_page+0xb4/0x110) from [<803c01f0>] (get_page_from_freelist+0x51c/0x5e0)
Dec 24 09:31:35 kernel: [<803c01f0>] (get_page_from_freelist+0x51c/0x5e0) from [<800b43a8>] (__alloc_pages_nodemask+0xe0/0x58c)
Dec 24 09:31:35 kernel: [<800b43a8>] (__alloc_pages_nodemask+0xe0/0x58c) from [<800b6370>] (__do_page_cache_readahead+0x13c/0x2b4)
Dec 24 09:31:35 kernel: [<800b6370>] (__do_page_cache_readahead+0x13c/0x2b4) from [<800b6798>] (ra_submit+0x28/0x30)
Dec 24 09:31:35 kernel: [<800b6798>] (ra_submit+0x28/0x30) from [<800b6aac>] (page_cache_async_readahead+0x90/0xd0)
Dec 24 09:31:35 kernel: [<800b6aac>] (page_cache_async_readahead+0x90/0xd0) from [<803c2550>] (__generic_file_splice_read+0x2f4/0x4dc)
Dec 24 09:31:35 kernel: [<803c2550>] (__generic_file_splice_read+0x2f4/0x4dc) from [<80100788>] (generic_file_splice_read+0x88/0xf8)
Dec 24 09:31:35 kernel: [<80100788>] (generic_file_splice_read+0x88/0xf8) from [<800ff3a0>] (do_splice_to+0x7c/0x88)
Dec 24 09:31:35 kernel: [<800ff3a0>] (do_splice_to+0x7c/0x88) from [<800ff6f8>] (splice_direct_to_actor+0xac/0x1d4)
Dec 24 09:31:35 kernel: [<800ff6f8>] (splice_direct_to_actor+0xac/0x1d4) from [<8010092c>] (do_splice_direct+0x54/0x6c)
Dec 24 09:31:35 kernel: [<8010092c>] (do_splice_direct+0x54/0x6c) from [<800df410>] (do_sendfile+0x168/0x1c8)
Dec 24 09:31:35 kernel: [<800df410>] (do_sendfile+0x168/0x1c8) from [<800e00c4>] (sys_sendfile64+0x9c/0xd4)
Dec 24 09:31:35 kernel: [<800e00c4>] (sys_sendfile64+0x9c/0xd4) from [<80050ac0>] (ret_fast_syscall+0x0/0x30)
Dec 24 09:31:36 kernel: BUG: Bad page state in process afpd  pfn:508a3
Dec 24 09:31:36 kernel: page:88213460 count:0 mapcount:0 mapping:(null) index:0x41b
Dec 24 09:31:36 kernel: page flags: 0x50000004(referenced)
Dec 24 09:31:36 kernel: [<8005701c>] (unwind_backtrace+0x0/0xf8) from [<800b3640>] (bad_page+0xb4/0x110)
Dec 24 09:31:36 kernel: [<800b3640>] (bad_page+0xb4/0x110) from [<803c01f0>] (get_page_from_freelist+0x51c/0x5e0)
Dec 24 09:31:36 kernel: [<803c01f0>] (get_page_from_freelist+0x51c/0x5e0) from [<800b43a8>] (__alloc_pages_nodemask+0xe0/0x58c)
Dec 24 09:31:36 kernel: [<800b43a8>] (__alloc_pages_nodemask+0xe0/0x58c) from [<800b6370>] (__do_page_cache_readahead+0x13c/0x2b4)
Dec 24 09:31:36 kernel: [<800b6370>] (__do_page_cache_readahead+0x13c/0x2b4) from [<800b6798>] (ra_submit+0x28/0x30)
Dec 24 09:31:36 kernel: [<800b6798>] (ra_submit+0x28/0x30) from [<800b6aac>] (page_cache_async_readahead+0x90/0xd0)
Dec 24 09:31:36 kernel: [<800b6aac>] (page_cache_async_readahead+0x90/0xd0) from [<803c2550>] (__generic_file_splice_read+0x2f4/0x4dc)
Dec 24 09:31:36 kernel: [<803c2550>] (__generic_file_splice_read+0x2f4/0x4dc) from [<80100788>] (generic_file_splice_read+0x88/0xf8)
Dec 24 09:31:36 kernel: [<80100788>] (generic_file_splice_read+0x88/0xf8) from [<800ff3a0>] (do_splice_to+0x7c/0x88)
Dec 24 09:31:36 kernel: [<800ff3a0>] (do_splice_to+0x7c/0x88) from [<800ff6f8>] (splice_direct_to_actor+0xac/0x1d4)
Dec 24 09:31:36 kernel: [<800ff6f8>] (splice_direct_to_actor+0xac/0x1d4) from [<8010092c>] (do_splice_direct+0x54/0x6c)
Dec 24 09:31:36 kernel: [<8010092c>] (do_splice_direct+0x54/0x6c) from [<800df410>] (do_sendfile+0x168/0x1c8)
Dec 24 09:31:36 kernel: [<800df410>] (do_sendfile+0x168/0x1c8) from [<800e00c4>] (sys_sendfile64+0x9c/0xd4)
Dec 24 09:31:36 kernel: [<800e00c4>] (sys_sendfile64+0x9c/0xd4) from [<80050ac0>] (ret_fast_syscall+0x0/0x30)
Dec 24 09:31:37 kernel: thfsplus: recoff 36643 too large
Dec 24 09:31:37 afpd[12314]: afp_openfork(1e95): ad_open: Invalid argument
[... 30 more of these recoff too large followed by ad_open errors ]
Dec 24 09:33:00 afpd[12314]: afp_openfork(1e9): ad_open: Invalid argument
Dec 24 09:33:00 kernel: thfsplus: recoff 36643 too large
Dec 24 09:33:02 afpd[12314]: AFP logout by user
Dec 24 09:33:02 afpd[12314]: AFP statistics: 178979.84 KB read, 613633.62 KB written
Dec 24 09:33:02 afpd[12314]: done
Could be an out of memory situation: Do you have a a swap file get around memory shortages?
Do a factory default reset, and manually reconfigure everything. Otherwise, you HAVE to dive into the shell, determine which entries are taking too much space and considered obsolete, and manually clean things up.
Works for me. Try a different browser, and make sure you don't have any client with funny/weird names, or using apostrophes. If you open your web browser console, it will show you what is causing a Javascript error breaking the page.
I'm having a problem with my RT-N66U where when I copy large file (8GB for example) into any attached USB drive, the router would crash. It totally stop responding and all services are unavailable including access to internet to the clients. I tried the following methods to copy the file and all caused the router to crash,
  1. Connected via SSH and copy the file from attached disk 1 to attached disk 2 using "mv" or "cp". Router will crash. After a restart, the partial file is not available at the destination disk, meaning the file is never being created.
  2. Connected from a Windows PC via SAMBA shared directory. Copy from the PC and paste into the shared directory. Router will crash. After a restart, the partial file is not available at the destination disk, meaning the file is never being created.
However, if I download a file using transmission directly into the disk, it works properly.
Asuswrt-Merlin 380.64 is now available for all supported models.
Thanks for the update I just updated from a super old version 374.xx and my connection speed in bridge is a solid bars now with 877.5 Mbps connection speed. Before it would bounce to the 533 Mbps connection speed.
Ha! I believe you that it will, but I have no idea how to interpret it!
In any case, while it's happening in both Chrome and Firefox, and from my phone, it's apparently just an issue with the images loading. The button function still works if I click there, so it's not a show stopper.
Merlin, thanks again for the perennial holiday gift of this firmware!
Merry Happy!
ApK
Merry Happy!
ApK
If the issue is just the images, then something else is at play. If you have any plugin installed on both browsers (like an ad blocker), make sure it's not what's causing the files to fail to load.
Also try to flush your browser cache to see what happens.
No issues here with Safari. Are you connecting by IP or name? HTTP or HTTPS? Also, have you cleared the Safari's cache? When was the last time you reset the router back to factory defaults?
I've tried both ways. HTTPS, HTTP is blocked. As for Safari cache, I've even reinstalled the whole OS, nothing changed. And the problem exists on both of my Macs and an iPad. The only thing I haven't tried is resetting the router. Anyway it works well in Chrome though.
I have installed the latest version but after installing, transfer speed between HDD connected to USB3 to my computer decreased from 40MB/s to 500KB/s and almost impossible to use.
RT-AC68U
Meanwhile it is fine over the wifi just problem with LAN.
Any solution?
Turned out it was something deeper than just the images. The button area seemed to work, and the GUI would reflect the addition or deletion, but Apply would just hang with no percentage indicator and adds or deletions would not persist. Plus, changing settings often took me back to the login screen (which at first I thought was just a artifact of the new firmware, maybe the Chrome auto-fill handling or some such, but apparently no).
So I backed up the settings, did a factory reset (which was probably overdue) and re-flashed the .64 firmware.
The Filtering page images looked normal.
So then I restored my saved settings, wondering if I had some sort of setting corruption, but after the restore, everything still looks normal, and works properly now.
So the moral of the story is? When in doubt with a firmware upgrade, do a factory reset? I think I've probably seen that advice somewhere.
