Thermaltake
Never used, so did not know; but there might lie the core of your problems...
Sure you can try going back, just save config in case it dos not help.
I flash now 384.12 and I will test now again with this firmware.
I don't believe that wireless drivers have changed between versions.I flash now 384.12 and I will test now again with this firmware.
The messages were silent. They are not anymore. It is just letting you know of a state change in the devices connection ie: power saving feature on the device. There isn't necessarily anything wrong.
I reflash the firmware again, did factory reset, pull the plug for 5 minutes, plug it back, reconfigure, and still same.
After some time it switch back to 2.4Ghz @ 144Mbps, and If I disable wifi on phone and turn it on again it will connect to 5Ghz for some time and switch back to 2.4 on it's own, and phone is in same place all the time near router.
Should I downgrade to previous verions of firmware ?
Check your Roaming Assistant settings, compare the value with the RSSI of your phone when on the 5 GHz band.
Roaming Assistant was disabled in Wireless - Professional. Where is that values of RSSI, not familiar with that.
On 384.12 wifi is working as it should, I downgrade few hourse ago to 384.12.
And phone is always on 5Ghz when in range, and when it's not it switching back to 2.4Ghz and vice versa. Something is not right in 384.13 firmware with wifi on AC88U.
System log -Wireless logWhere is that values of RSSI, not familiar with that.
There has been zero changes to wifi for the RT-AC88U in 384.13, and there was no change in GPL code either. The vast majority of changes were at the webui level, with some changes to nvram handling for DHCP and firmware version checks.
Yes, I can confirm that this exact setup works perfectly, although my RT-AC68U node is running the (latest) stock factory Asus firmware, whereas my RT-AC86U router is running the Merlin 384.13 firmware.Does .13 allow you to use rt-ac86u as main aimesh router and rt-ac68u as a aimesh node? I read some issues people are having with this setup. I cannot find any documentation that this is doable. Any leads?
Turn off Network Monitoring to fix this.Dirty upgrade from .12 to .13
Internet Status shows as Disconnected (it is not, the internet is working fine),
where is this option? i have this problem tooTurn off Network Monitoring to fix this.
Administration -> System Tab -> Basic Config sectionwhere is this option? i have this problem too
You have DNSSEC enabled but someone on your network queried that domain and it is not signed properly. That is the domain owner’s fault.Code:dnsmasq[763]: Insecure DS reply received for zinphyra.com, could be bad domain configuration or lack of DNSSEC support from upstream DNS servers
Welcome To SNBForums
