Thx, will try this tonight to see if it makes a difference.Try "SD Card Formatter" to set it back to "factory" format, and then try in router again..?
As mentioned before i do not have another USB stick.If this was a Merlin firmware issue many others would see it and your the only person with this issue.
Using another usb stick is just going to be faster then spending days trying to troubleshoot this which you have since you posted in the Diversion one.
But to each his own hopefully you figure it out.
My bet is on a hardware problem since you already performed several factory resets and loaded the original Asus firmware. Check with Asus to see if they won't accept a warranty claim since it's just a little over 2 years since you bought the router. Also check how you paid for the router, some credit cards offer an additional year of warranty.Hi,
I have an RT-AC5300 which now runs the latest Merlin FW but I still have the issue that I've tried to fix with Merlin. The issue started ~ a week ago (I'm not aware of any FW updates happened that time) when the router seems freeze up and none of the clients could get internet and couldn't reach the router either. A power cycle fixed the issue temporarily but a couple of hours later the same treeze happened again and it's going on now for a week. I've done a lot of factory resets, installed the latest stock firmware, installed the oldest firmware available on the Asus website and as a last resort I've installed Merlin but the freeze issue still happen. What I've noticed is that one of my 5G wifi has channel 0 and it can't be seen in any of my devices even though I'm not using AiMesh. The syslog doesn't seem to have any indication of the problem or it's not logged. I start to think that it's a HW issue but this router was running fine for only over 2 years now and I'd expect a bit more from a 400$ router. I've attached the syslog if someone expert could have a look and confirm if it's a HW or a FW issue... I don't really want to buy a new router if it's not a HW problem but at the moment I can't really see any other option. Thanks
Thanks for the confirmation... Since the warranty for these high end routers is 36 month I'm still good and after a call with Asus Tech Support they also advised to RMA it as it seems to be a HW issue but I have to contact the seller as Asus don't do warranty service for routers (???)... anyways a new AC88U is on it's way and RMA started with the seller... *fingers-crossed*My bet is on a hardware problem since you already performed several factory resets and loaded the original Asus firmware. Check with Asus to see if they won't accept a warranty claim since it's just a little over 2 years since you bought the router. Also check how you paid for the router, some credit cards offer an additional year of warranty.
Before you lose all hope, have you tried the “M&M config”?
https://www.snbforums.com/threads/n...l-and-manual-configuration.27115/#post-205573
How come you got the AC88U and not the AX88U? Not to scare you, but I had a terrible time with my AC88U. Changed it quickly for an AX88U which is night and day in performance and stability.Thanks for the confirmation... Since the warranty for these high end routers is 36 month I'm still good and after a call with Asus Tech Support they also advised to RMA it as it seems to be a HW issue but I have to contact the seller as Asus don't do warranty service for routers (???)... anyways a new AC88U is on it's way and RMA started with the seller... *fingers-crossed*
I've read the same the other way around, switch back to AC88U from the AX... I don't have any AX devices yet and the AC is still cheaper and meets my need... I think you need some luck to get a properly working one, each series could have faulty batchHow come you got the AC88U and not the AX88U? Not to scare you, but I had a terrible time with my AC88U. Changed it quickly for an AX88U which is night and day in performance and stability.
FYI, new firmwares are out: https://www.asus.com/us/Networking/RT-AC88U/HelpDesk_Download/
There is already an .14 Alpha build based on that GPL if I'm not mistaken.Will new 3.0.0.4.384.81116 from AC88U model be implemented into new 384.14 build ?
Oooops wrong assumption on my part then.There is no 384_81116 source code available.
Why not read the previous post right above yours...
Let's try to keep the sarcasm to a minimum. Is it really that hard to respond with a sentence or two? It's not like the poster is asking for your first-born child. Oh, and ps, the "search for the answer to your question" response is a joke. The search function generally returns so many marginal hits that it's next to useless in most cases. Chill everyone...
One day soon...I keep hoping one of these posts have something to do with 384.13.![]()
Welcome To SNBForums
