DarkKnight75
Just upgraded my AC86U to .13..running smooth so far.
+1 - coming from 384.12 with no issues (all below services work)!Dirty upgrade on my RT-AC87U. Thanks for the firmware.
Put the command into the startup-scripts.
Some discussion:That may be true. I updated both routers to 384.13. Before the update BOTH routers were performing very similar heat wise. I am waiting for a ebay order of thermal pads/fans before I take on opening the case and taking a look. right now using active cooling -- that one is still running hot (not to the touch on the case, just on the GUI)
There were some discussion on the internet about ASUS screwed the heatsink too tight on some of the AC68U, causing it to bend a little and lose contact with the CPU. Some people losened the screws a little, some others reapplied thermal pastes. These all helped somewhat.
Hmm, AX88U dirty update from 384.12 = +10° CPU temperature.
They may be trying to fix no boot issue after soft reboot on some RT-AC86U and RT-AX88U. Let's see...![]()
Switch: enabledInteresting, it didn't work for me. Can you please connect to the router via ssh and run 'robocfg show' and paste here the result?
I tested reverting to 384.12 and this issue was resolved, upgrading back to 384.13 broke things again, so you've definitely broken something in 384.13.Updated yesterday on my 86U, now devices on my guest network can’t see each other.
Before the update my brother use to be able to cast YouTube videos from his phone to the living room TV which is also on the guest network, now the YouTube app doesn’t show the TV.
The only change was updating to 384.13.
Aug 2 08:09:59 nat: apply nat rules (/tmp/nat_rules_eth0_eth0) error!
Guest network/s have an on/off toggle for this.
Did you select the right one? (Access intranet y/n).
This only affects the RT-AX88UMy 86U is running as cool as it ever had.
2.4 GHz: 51°C - 5 GHz: 56°C - CPU: 75°C
Asus disabled it, likely because it caused a problem. Enable it at your own risk, it may cause you problems.AX88U has cpu speed power management, but it off by default. Any idea on it or off?
I have access intranet off as I don’t want people on my guest network accessing devices on my non guest networks. The TV and phones are on the guest network and are able to cast to the TV on 384.12, just not on 384.13.
Welcome To SNBForums
