[Release] Asuswrt-Merlin 384.13 is now available
Merlin.nodes can operate user scripts if end user feels so inclined.
And which scripts will you have to run preferable on nodes than master router?
Merlin himself recommended to use Asus stock as he sees no or minimal benefit with his firmware on nodes.
I went from Merlin on N66U to a POS SmartRG router provided by my ISP. Put up with it for a few months until I got an AC86U off Ebay.
First thing I did was a factory reset and loaded up Merlin. So glad to back!!
I finally updated my N66U to a AC1900P, and i installed this release on the new router, and did a factory reset and set everything up.
My issue is that asuscomm.com DDNS on the new router isn't working. No matter what I put in for my hostname. It says "Request Error! Please try again."
The log says:
Aug  4 11:49:29 start_ddns: update WWW.ASUS.COM update@asus.com, wan_unit 0
Aug  4 11:49:29 inadyn[1161]: In-a-dyn version 2.5 -- Dynamic DNS update client.
Aug  4 11:49:30 inadyn[1161]: Failed resolving hostname anythingiputin.asuscomm.com: Name or service not known
Aug  4 11:49:30 inadyn[1161]: Update forced for alias anythingiputin.asuscomm.com, new IP# XX.XX.XX.XX
Aug  4 11:49:33 inadyn[1161]: Authentication failure
Aug  4 11:49:33 inadyn[1161]: Fatal error in DDNS server response:
Aug  4 11:49:33 inadyn[1161]: [401 |Authorization failed]
Aug  4 11:49:33 inadyn[1161]: Error response from DDNS server, exiting!
Aug  4 11:49:33 syslog: Error code 48: DDNS server response not OK
The ip address it states is the correct WAN ip.
Any ideas?
My AC87U logs have few of these errors. Anything that I should be afraid of? These probably don't have anything to do with the dead WAN port in AP mode issue?
Aug 3 09:59:30 kernel: ------------[ cut here ]------------
Aug 3 09:59:30 kernel: WARNING: at include/linux/skbuff.h:1478 fa_process_tx+0x188/0x194 [et]()
Aug 3 09:59:30 kernel: module: usblp bf712000 10321
Aug 3 09:59:30 kernel: module: thfsplus bf6f5000 85326
Aug 3 09:59:30 kernel: module: tntfs bf66d000 498773
Aug 3 09:59:30 kernel: module: tfat bf634000 189154
Aug 3 09:59:30 kernel: module: ext2 bf620000 52776
Aug 3 09:59:30 kernel: module: ext4 bf5df000 221674
Aug 3 09:59:30 kernel: module: jbd2 bf5cc000 48993
Aug 3 09:59:30 kernel: module: crc16 bf5c6000 1007
Aug 3 09:59:30 kernel: module: ext3 bf5a4000 106409
Aug 3 09:59:30 kernel: module: jbd bf593000 42367
Aug 3 09:59:30 kernel: module: mbcache bf58c000 4599
Aug 3 09:59:30 kernel: module: usb_storage bf57d000 34290
Aug 3 09:59:30 kernel: module: sg bf572000 19855
Aug 3 09:59:30 kernel: module: sd_mod bf566000 21983
Aug 3 09:59:30 kernel: module: scsi_wait_scan bf560000 416
Aug 3 09:59:30 kernel: module: scsi_mod bf53b000 108738
Aug 3 09:59:30 kernel: module: cdc_mbim bf535000 3137
Aug 3 09:59:30 kernel: module: qmi_wwan bf52e000 5792
Aug 3 09:59:30 kernel: module: cdc_wdm bf527000 7252
Aug 3 09:59:30 kernel: module: cdc_ncm bf51f000 8762
Aug 3 09:59:30 kernel: module: rndis_host bf518000 5256
Aug 3 09:59:30 kernel: module: cdc_ether bf512000 4036
Aug 3 09:59:30 kernel: module: asix bf50a000 10856
Aug 3 09:59:30 kernel: module: cdc_acm bf501000 12614
Aug 3 09:59:30 kernel: module: usbnet bf4f8000 11900
Aug 3 09:59:30 kernel: module: mii bf4f2000 3367
Aug 3 09:59:30 kernel: module: ohci_hcd bf4e8000 17926
Aug 3 09:59:30 kernel: module: ehci_hcd bf4da000 32382
Aug 3 09:59:30 kernel: module: xhci_hcd bf4c7000 51132
Aug 3 09:59:30 kernel: module: usbcore bf4a3000 102572
Aug 3 09:59:30 kernel: module: jffs2 bf485000 91274
Aug 3 09:59:30 kernel: module: zlib_deflate bf47b000 19489
Aug 3 09:59:30 kernel: module: nf_nat_pptp bf475000 1602
Aug 3 09:59:30 kernel: module: nf_conntrack_pptp bf46f000 3355
Aug 3 09:59:30 kernel: module: nf_nat_proto_gre bf469000 887
Aug 3 09:59:30 kernel: module: nf_conntrack_proto_gre bf463000 3296
Aug 3 09:59:30 kernel: module: nf_nat_ftp bf45d000 1144
Aug 3 09:59:30 kernel: module: nf_conntrack_ftp bf456000 4909
Aug 3 09:59:30 kernel: module: wl bf033000 4137245
Aug 3 09:59:30 kernel: module: et bf01c000 64930
Aug 3 09:59:30 kernel: module: igs bf014000 11887
Aug 3 09:59:30 kernel: module: emf bf00b000 15225
Aug 3 09:59:30 kernel: module: ctf bf000000 21079
Aug 3 09:59:30 kernel: Modules linked in: usblp thfsplus tntfs(P) tfat(P) ext2 ext4 jbd2 crc16 ext3 jbd mbcache usb_storage sg sd_mod scsi_wait_scan scsi_mod cdc_mbim qmi_wwan cdc_wdm cdc_ncm rndis_host cdc_ether asix cdc_acm usbnet mii ohci_hcd ehci_hcd xhci_hcd usbcore jffs2 zlib_deflate nf_nat_pptp nf_conntrack_pptp nf_nat_proto_gre nf_conntrack_proto_gre nf_nat_ftp nf_conntrack_ftp wl(P) et(P) igs(P) emf(P) ctf(P)
Aug 3 09:59:30 kernel: [<c0043ff8>] (unwind_backtrace+0x0/0xf8) from [<c0061d70>] (warn_slowpath_common+0x4c/0x64)
Aug 3 09:59:30 kernel: [<c0061d70>] (warn_slowpath_common+0x4c/0x64) from [<c0061da4>] (warn_slowpath_null+0x1c/0x24)
Aug 3 09:59:30 kernel: [<c0061da4>] (warn_slowpath_null+0x1c/0x24) from [<bf02550c>] (fa_process_tx+0x188/0x194 [et])
Aug 3 09:59:30 kernel: [<bf02550c>] (fa_process_tx+0x188/0x194 [et]) from [<bf0265f8>] (et_isr+0x2fc/0x488 [et])
Aug 3 09:59:30 kernel: unwind: Index not found bf0265f8
Aug 3 09:59:30 kernel: ---[ end trace a79e2116ac77f6bc ]---
how do i get rid of the new feature enabled for ai mesh every time i log into my router now? ac88u
Running into an interesting issue hoping some one can give me pointers on how to debug it.
What i am noticing on my phone is that when the phone is not in use after a while it disconects from the wireless. Now my android os has not updated so i am thinking this might be related to the firmware update of the router. I also enabled airmesh so not sure if that is causing this issue where its trying to figure out if to connect to the airmesh node or the main router.
If any one has any pointers on what i should look for in the log to determine what might be going on that would be great.
RT-AX88U:
Log file
Aug 3 09:34:13 kernel: FPM Pool 1: invalid token 0x23048000 freed
Aug 3 09:46:07 kernel: FPM Pool 0: invalid token 0x005a8000 freed
Aug 3 09:49:47 kernel: FPM Pool 0: invalid token 0x002a8000 freed
Aug 3 09:59:11 kernel: FPM Pool 1: invalid token 0x22288000 freed
Aug 3 09:59:39 kernel: FPM Pool 0: invalid token 0x00330000 freed
Aug 3 10:01:19 kernel: FPM Pool 0: invalid token 0x00378000 freed
May 5 09:05:05 syslogd started: BusyBox v1.25.1
Out of nothing my AX-88U started to reboot.
(I have two RT-AC5300 running the same firmware and ... never spontaneously reboot.)
There's already a separate thread about this. Try this link.
https://www.snbforums.com/threads/kernel-fpm-pool-1-invalid-token-0x21950000-freed.57827/
The log says:
Any ideas?
Are you trying to use the same host name? If so, put the N66U back in, change the DDNS host name on it then go back to the AC1900. Ot email Asus support and wait for them to change it for you.
I just noticed when comparing the AsusWRT Merlin 384.13 GUI's on my two routers -- Both RT-AC68U's that The Hardware Acceleration settings are slightly different. At the [Tools > Sysinfo] Window I see that one router shows "HW acceleration Enabled (CTF + FA)" and the other shows "HW acceleration Enabled (CTF only)"
1) What's the difference?
2) Can I set them myself and how?
3) Might this be the cause of why one router is running noticeably hotter than the other?
EDIT: just found this link/url: https://routerguide.net/nat-acceleration-on-or-off/
2nd EDIT: After reading that article I somewhat answered Questions 1 & 2.
  • Screenshot_2019-08-04 ASUS Wireless Router RT-AC68U - System Information.png
  • Screenshot_2019-08-04 ASUS Wireless Router RT-AC68U - System Information(1).png
Issue is it always apears every time i load the home page..... i dont want to click ok every single time.
Just "spit balling" here but what browser are you using? Possibly a cookie issue?
It does it with any hostname. I already, on my old router, went in and delisted the ddns i wanted by changing it on there. It worked. This new router doesn't want to register any domain.
I bought a new RT-AC66U-B1 to set up as an AiMesh node, I did the setup without any problem. My main router RT-AC68U saw the AC66U-B1 but couldn't connect to it. I ended up returning the new router.
Make sure your browser isn't interfering, and also that you aren't running out of nvram space. That page will set a flag on the router the first time you click on Ok to prevent it from being displayed again.
Make sure it's a genuine RT-AC1900P and not a modded model - these are not supported.
No performance issues after upgrading to v384.13 on the RT-AC3200, other than what looks like an error in the enclosed jpg indicates. Previously, the GUI has always displayed that the internet/WAN is connected when it is, unlike in this shot. Went from .12 to .13, otherwise, a great job as always. The update went smooth as always so as long as the machine keeps powering on, perking up and chugging along... :)
