[Release] Asuswrt-Merlin 384.17 (and 384.13_8) are now available
I'm back! Everything upgraded! @RMerlin doesn't deal in eye candy. The feature has a need or it's not added, period. This is at a glance network usage, nothing more. Great work on this firmware as usual!;)
Unrelated but.... Is it possible on terminal to have the uptime in "Unix" format? I mean, in seconds - instead of having a 1 hour uptime, getting 3600 as a value.
Thanks.
On point on all four points.
Thanks.
You mean the router's uptime in seconds?
You can use the proc filesystem:
cat /proc/uptime
This file contains two numbers: the uptime of the system (seconds), and the amount of time spent in idle process (seconds).
Your router must be running out of nvram space or JFFS space to store them.
NVRAM usage 66281 / 131072 bytes
JFFS 47.34 / 48.00 MB
JFFS seems almost full, but I didn't put anything there:
fbreve@RT-AC86U-4D48:/jffs# ls -la
drwxr-xr-x   12 fbreve   root             0 Apr 28 11:16 .
drwxr-xr-x   20 fbreve   root          1840 Apr 26 01:14 ..
drw-------    2 fbreve   root             0 Apr 27 11:33 .cert
drw-------    3 fbreve   root             0 Mar  4 21:09 .le
drwxrwxrwx    7 fbreve   root             0 Apr 27 11:33 .sys
drwxr-xr-x    2 fbreve   root             0 May  5  2018 addons
-rw-r--r--    1 fbreve   root           147 Apr 27 11:55 cfg.json
drwxr-xr-x    2 fbreve   root             0 May  5  2018 configs
-rw-r--r--    1 fbreve   root          3634 Apr 28 11:13 nmp_cl_json.js
drwxrwxrwx    2 fbreve   root             0 Apr 27 11:53 nvram
-rw-rw-rw-    1 fbreve   root             0 May  5  2018 nvram_war
drwxr-xr-x    2 fbreve   root             0 May  5  2018 scripts
drwxrwxrwx    2 fbreve   root             0 Apr 27 12:11 signature
-rw-rw-rw-    1 fbreve   root        152733 Apr 28 11:16 syslog.log
-rw-rw-rw-    1 fbreve   root        262145 Apr 28 11:16 syslog.log-1
drwxr-xr-x    2 fbreve   root             0 Apr 27 12:10 usericon
Use "du -h" command on /jffs and see the exact file sizes and figure out what's using the space.
Makaveli@RT-AX88U-0B10:/jffs# ls -la -h
drwxr-xr-x   13 Makaveli root           0 Apr 26 00:58 .
drwxrwxrwx   21 Makaveli root        1.8K Apr 26 00:28 ..
-rw-rw-rw-    1 Makaveli root         950 Apr 28 10:49 .ash_history
drw-------    2 Makaveli root           0 May  5  2018 .cert
drwxrwxrwx    5 Makaveli root           0 May  5  2018 .sys
drwxrwxrwx    9 Makaveli root           0 Feb 29 11:37 addons
-rw-rw-rw-    1 Makaveli root        2.7K Jan 11 21:27 cert.pem-bk
drwxr-xr-x    2 Makaveli root           0 Apr 25 20:02 configs
-rw-------    1 Makaveli root       50.8K May  5  2018 crashlog.log
-rw-rw-rw-    1 Makaveli root        2.7K Jan 11 21:27 key.pem-bk
-rw-r--r--    1 Makaveli root        1.3K Apr 27 21:53 nmp_cl_json.js
drwxrwxrwx    2 Makaveli root           0 Apr  3 13:17 nvram
-rw-rw-rw-    1 Makaveli root           0 May  5  2018 nvram_war
drwx------    2 Makaveli root           0 Jan  4 18:25 openvpn
drwxr-xr-x    2 Makaveli root           0 Apr  2 18:12 scripts
drwxrwxrwx    2 Makaveli root           0 May  5  2018 syslog.log
drwxrwxrwx    2 Makaveli root           0 May  5  2018 syslog.log-1
drwxr-xr-x    2 Makaveli root           0 Apr  6 18:47 usericon
My jffs size is fine but the question I have is the 50.8k crashlog file can I delete it or does it have to stay?
You can delete it without any issues. In fact you can delete any log file without worrying too much. (Assuming you're not using some externel scripts which pulls data out of it)
Check in /jffs/.sys/ , it's often caused by the Traffic Analyzer database.
Thanks. This is my Traffic Analyzer data:
fbreve@RT-AC86U-4D48:/jffs/.sys/TrafficAnalyzer# ls -la
drw-rw-rw-    2 fbreve   root             0 Apr 18 03:19 .
drwxrwxrwx    7 fbreve   root             0 Apr 27 11:33 ..
-rw-rw-rw-    1 fbreve   root      31483904 Apr 27 12:52 TrafficAnalyzer.db
-rw-rw-rw-    1 fbreve   root      27258856 Apr 18 03:29 TrafficAnalyzer.db-journal
My web interface stops responding whenever I enter the Traffic Analyzer Statistics tab. Maybe it's related.
Thanks. I didn't know this command:
fbreve@RT-AC86U-4D48:/jffs# du -h
0       ./scripts
0       ./.le/fabricio.asuscomm.com/backup
17.5K   ./.le/fabricio.asuscomm.com
20.0K   ./.le
0       ./addons
984.5K  ./signature
0       ./configs
45.0K   ./usericon
8.0K    ./nvram
293.0K  ./.sys/AiProtectionMonitor
512     ./.sys/cfg_mnt
4.5M    ./.sys/WebHistory
56.0M   ./.sys/TrafficAnalyzer
86.0K   ./.sys/nc
60.9M   ./.sys
2.5K    ./.cert
62.3M   .
Maybe I should leave Traffic Analyzer off.
Edit: Apparently there is no way to do it.
0       ./scripts
20.0K   ./.le
0       ./addons
984.5K  ./signature
0       ./configs
45.0K   ./usericon
8.0K    ./nvram
512     ./.sys/cfg_mnt
86.0K   ./.sys/nc
60.9M   ./.sys
2.5K    ./.cert
62.3M   .
Just SSH into the router and delete the TrafficAnalyzer file.
Also once you've cleared the file you can turn off TA from here.
there is any improve on asus rc5300 against the oem version last one updateVersión 3.0.0.4.384.81792?
mainly speed and distance on connections
And I believe the bin symbol right under the on/off switch is for deleting/resetting the traffic analyzer file...
I don't use TA as you can see from the screen shot but I also just noticed the Bin icon and I believe you're right.
Try it and you will like it
Dirty upgrade on an RT-AC88U, RT-AC68/1900U from 384.15 to 384.17, so far so good. These are 2 of my WAP only units. Saving the two main full routers an RT-AC86U and RT-AC68 for a quieter time as they are running the AMTM stuff too. THANKS!
All good after dirty upgrade . Many thanks!
the reset is mandatory to do it after update, because the user pass doesnt works after i understood
Only if you are running a current stock ASUS firmware and decide to flash Merlin. Merlin to Merlin updates should be fine without resetting.
On what router model? Going from Asus 384.81792 to Merlin 384.17 on RT-AC86U is a matter of flash and reboot. Also going back and forth few releases on Asus and Merlin doesn't require reset. The more basic config the better chance to jump firmware with no issues. Between firmware releases on the same branch. IT guy here on covid vacation. I reset only if there is no other option. I don't burn my entire backyard to get rid of few weeds. :D
