[Release] Asuswrt-Merlin 384.18 and 384.13_10 is now available
Updated to 384.18 and now system log is flooded by these.......
Jun 29 19:25:27 dnsmasq[420]: failed to send packet: Operation not permitted
I know this has cropped up previously but I cant find an answer
I had to revert to 384.17 from 384.18 after a dirty upgrade. I've kept up with all releases via dirty upgrades, which has been fine thus far. All my VPN servers (OpenVPN, IPSec & PPTP) stopped working and even the port forwarding from my internet-facing main Fios router to the AC86u for the https router web page (I have it at port 9443) stopped working. Please ensure you have config backup before performing this upgrade. I have not done any troubleshooting for lack of time. Just rolling back.
Edit: after rolling back to 384.17, everything is working fine again.
Updated from .17 without any issues. Even 2 new menu items appeared - Game and OpenNAT
Anyone else with an AC88U losing channels 36, 40, 44 or 48 in 5G wifi settings? All I have available is 149, 153, 157, 161 and 165.
Where are these new menu items in the GUI?
Thanks in advance.
They’re still there for me. I have a US model.
+1 on this. Also on an RT-AC5300
Is Trend Micro updating? Or is this not a firmware issue? Friend's 86u hasn't updated since last year as mentioned somewhere here, and she is wondering whether to do this update since otherwise everything works well for her on .17.
Mine has been updating regularly forever. Latest : 2.182 Updated : 2020/06/26 18:11
One other case recently reported was due to router malware breaking the wget used by the Trend Micro update process. She may want to factory reset and start fresh on 384.18.
You may want to consider doing a factory reset and manual configure. For the RT-AC86U it is worth doing. The SmartConnect in the newer, Merlin and Asus, firmware works very well!
upgraded to .18 and im also being flooded with all these :
Jun 30 02:14:31 miniupnpd[945]: Failed to convert hostname 'fe80::290:a9ff:fed3:9ed2' to ip address
Jun 30 02:14:34 miniupnpd[945]: Failed to convert hostname 'fe80::290:a9ff:fed3:9ed2' to ip address
Jun 30 02:14:34 kernel: DROP IN=ppp0 OUT= MAC= SRC=82.14.80.37 DST=51.148.166.159 LEN=52 TOS=0x00 PREC=0x00 TTL=118 ID=43232 DF PROTO=TCP SPT=59925 DPT=7680 SEQ=3522953158 ACK=0 WINDOW=64240 RES=0x00 SYN URGP=0 OPT (020405B40103030801010402)
Jun 30 02:14:42 kernel: DROP IN=ppp0 OUT= MAC= SRC=82.14.80.37 DST=51.148.166.159 LEN=52 TOS=0x00 PREC=0x00 TTL=118 ID=43233 DF PROTO=TCP SPT=59925 DPT=7680 SEQ=3522953158 ACK=0 WINDOW=64240 RES=0x00 SYN URGP=0 OPT (020405B40103030801010402)
Jun 30 02:14:45 kernel: DROP IN=ppp0 OUT= MAC= SRC=91.240.118.10 DST=51.148.166.159 LEN=40 TOS=0x00 PREC=0x00 TTL=248 ID=25549 PROTO=TCP SPT=57600 DPT=24075 SEQ=1799265113 ACK=0 WINDOW=1024 RES=0x00 SYN URGP=0
Jun 30 02:14:56 kernel: DROP IN=ppp0 OUT= MAC= SRC=91.240.118.6 DST=51.148.166.159 LEN=40 TOS=0x00 PREC=0x00 TTL=248 ID=46420 PROTO=TCP SPT=45202 DPT=3208 SEQ=2267488067 ACK=0 WINDOW=1024 RES=0x00 SYN URGP=0
Jun 30 02:14:58 kernel: DROP IN=ppp0 OUT= MAC= SRC=45.145.66.64 DST=51.148.166.159 LEN=40 TOS=0x00 PREC=0x00 TTL=246 ID=37034 PROTO=TCP SPT=42755 DPT=10025 SEQ=996020508 ACK=0 WINDOW=1024 RES=0x00 SYN URGP=0
Jun 30 02:15:05 kernel: DROP IN=ppp0 OUT= MAC= SRC=45.145.66.64 DST=51.148.166.159 LEN=40 TOS=0x00 PREC=0x00 TTL=246 ID=9518 PROTO=TCP SPT=42755 DPT=8813 SEQ=924819932 ACK=0 WINDOW=1024 RES=0x00 SYN URGP=0
Jun 30 02:15:29 kernel: DROP IN=ppp0 OUT= MAC= SRC=219.138.150.220 DST=51.148.166.159 LEN=44 TOS=0x00 PREC=0x00 TTL=239 ID=14207 PROTO=TCP SPT=23535 DPT=17022 SEQ=2125190046 ACK=0 WINDOW=1024 RES=0x00 SYN URGP=0 OPT (020405B4)
Jun 30 02:15:38 kernel: DROP IN=ppp0 OUT= MAC= SRC=146.88.240.4 DST=51.148.166.159 LEN=49 TOS=0x00 PREC=0x00 TTL=245 ID=54321 PROTO=UDP SPT=35585 DPT=5683 LEN=29
Jun 30 02:15:38 kernel: DROP IN=ppp0 OUT= MAC= SRC=171.67.71.100 DST=51.148.166.159 LEN=40 TOS=0x00 PREC=0x00 TTL=245 ID=54321 PROTO=TCP SPT=33505 DPT=13 SEQ=2911678677 ACK=0 WINDOW=65535 RES=0x00 SYN URGP=0
Jun 30 02:15:40 kernel: DROP IN=ppp0 OUT= MAC= SRC=91.240.118.14 DST=51.148.166.159 LEN=40 TOS=0x00 PREC=0x00 TTL=247 ID=57540 PROTO=TCP SPT=45896 DPT=52871 SEQ=1788971228 ACK=0 WINDOW=1024 RES=0x00 SYN URGP=0
Jun 30 02:15:42 kernel: DROP IN=ppp0 OUT= MAC= SRC=91.240.118.6 DST=51.148.166.159 LEN=40 TOS=0x00 PREC=0x00 TTL=247 ID=49261 PROTO=TCP SPT=45202 DPT=3376 SEQ=254766018 ACK=0 WINDOW=1024 RES=0x00 SYN URGP=0
Jun 30 02:15:43 kernel: DROP IN=ppp0 OUT= MAC= SRC=118.97.13.146 DST=51.148.166.159 LEN=40 TOS=0x00 PREC=0x00 TTL=245 ID=58783 PROTO=TCP SPT=58671 DPT=1433 SEQ=783632025 ACK=0 WINDOW=1024 RES=0x00 SYN URGP=0
Jun 30 02:16:16 kernel: DROP IN=ppp0 OUT= MAC= SRC=91.240.118.8 DST=51.148.166.159 LEN=40 TOS=0x00 PREC=0x00 TTL=247 ID=39073 PROTO=TCP SPT=44055 DPT=17091 SEQ=2803334397 ACK=0 WINDOW=1024 RES=0x00 SYN URGP=0
Jun 30 02:16:23 kernel: DROP IN=ppp0 OUT= MAC= SRC=94.102.51.95 DST=51.148.166.159 LEN=40 TOS=0x00 PREC=0x00 TTL=249 ID=52077 PROTO=TCP SPT=52785 DPT=3101 SEQ=1455448559 ACK=0 WINDOW=1024 RES=0x00 SYN URGP=0
Jun 30 02:16:25 kernel: DROP IN=ppp0 OUT= MAC= SRC=71.6.146.186 DST=51.148.166.159 LEN=44 TOS=0x10 PREC=0x00 TTL=114 ID=52400 PROTO=TCP SPT=23788 DPT=4730 SEQ=1094710423 ACK=0 WINDOW=19378 RES=0x00 SYN URGP=0 OPT (020405B4)
Jun 30 02:16:33 kernel: DROP IN=ppp0 OUT= MAC= SRC=194.26.29.138 DST=51.148.166.159 LEN=40 TOS=0x00 PREC=0x00 TTL=242 ID=49749 PROTO=TCP SPT=42483 DPT=1507 SEQ=3637272873 ACK=0 WINDOW=1024 RES=0x00 SYN URGP=0
Jun 30 02:16:43 kernel: DROP IN=ppp0 OUT= MAC= SRC=45.14.150.140 DST=51.148.166.159 LEN=40 TOS=0x00 PREC=0x00 TTL=245 ID=41401 PROTO=TCP SPT=58910 DPT=10904 SEQ=2759601598 ACK=0 WINDOW=1024 RES=0x00 SYN URGP=0
Jun 30 02:21:20 miniupnpd[945]: Failed to convert hostname 'fe80::290:a9ff:fed3:9ed2' to ip address
Jun 30 02:21:29 kernel: DROP IN=ppp0 OUT= MAC= SRC=94.102.50.137 DST=51.148.166.159 LEN=40 TOS=0x00 PREC=0x00 TTL=249 ID=38189 PROTO=TCP SPT=51668 DPT=8110 SEQ=3855952924 ACK=0 WINDOW=1024 RES=0x00 SYN URGP=0
Jun 30 02:21:29 miniupnpd[945]: Failed to convert hostname 'fe80::290:a9ff:fed3:9ed2' to ip address
Jun 30 02:21:31 miniupnpd[945]: Failed to convert hostname 'fe80::290:a9ff:fed3:9ed2' to ip address
Jun 30 02:21:31 kernel: DROP IN=ppp0 OUT= MAC= SRC=91.240.118.11 DST=51.148.166.159 LEN=40 TOS=0x00 PREC=0x00 TTL=247 ID=34257 PROTO=TCP SPT=43675 DPT=31681 SEQ=601118863 ACK=0 WINDOW=1024 RES=0x00 SYN URGP=0
Jun 30 02:21:39 kernel: DROP IN=ppp0 OUT= MAC= SRC=91.240.118.14 DST=51.148.166.159 LEN=40 TOS=0x00 PREC=0x00 TTL=247 ID=36047 PROTO=TCP SPT=45896 DPT=52241 SEQ=1714153025 ACK=0 WINDOW=1024 RES=0x00 SYN URGP=0
Jun 30 02:21:41 kernel: DROP IN=ppp0 OUT= MAC= SRC=91.240.118.10 DST=51.148.166.159 LEN=40 TOS=0x00 PREC=0x00 TTL=248 ID=27181 PROTO=TCP SPT=57600 DPT=24619 SEQ=3145510041 ACK=0 WINDOW=1024 RES=0x00 SYN URGP=0
Jun 30 02:21:41 kernel: DROP IN=ppp0 OUT= MAC= SRC=45.145.66.64 DST=51.148.166.159 LEN=40 TOS=0x00 PREC=0x00 TTL=246 ID=64859 PROTO=TCP SPT=42755 DPT=9936 SEQ=1969585428 ACK=0 WINDOW=1024 RES=0x00 SYN URGP=0
Jun 30 02:21:46 kernel: DROP IN=ppp0 OUT= MAC= SRC=220.134.0.51 DST=51.148.166.159 LEN=40 TOS=0x00 PREC=0x00 TTL=48 ID=45144 PROTO=TCP SPT=40879 DPT=23 SEQ=865379999 ACK=0 WINDOW=59607 RES=0x00 SYN URGP=0
Jun 30 02:21:53 kernel: DROP IN=ppp0 OUT= MAC= SRC=94.102.51.17 DST=51.148.166.159 LEN=40 TOS=0x00 PREC=0x00 TTL=249 ID=57986 PROTO=TCP SPT=57661 DPT=59998 SEQ=3175591491 ACK=0 WINDOW=1024 RES=0x00 SYN URGP=0
Jun 30 02:21:59 kernel: DROP IN=ppp0 OUT= MAC= SRC=104.248.120.216 DST=51.148.166.159 LEN=40 TOS=0x00 PREC=0x00 TTL=242 ID=39651 PROTO=TCP SPT=54661 DPT=25016 SEQ=403070404 ACK=0 WINDOW=1024 RES=0x00 SYN URGP=0
Jun 30 02:22:02 kernel: DROP IN=ppp0 OUT= MAC= SRC=194.26.29.231 DST=51.148.166.159 LEN=40 TOS=0x00 PREC=0x00 TTL=242 ID=5943 PROTO=TCP SPT=55815 DPT=33896 SEQ=2804364736 ACK=0 WINDOW=1024 RES=0x00 SYN URGP=0
Jun 30 02:22:15 kernel: DROP IN=ppp0 OUT= MAC= SRC=167.99.8.129 DST=51.148.166.159 LEN=40 TOS=0x00 PREC=0x00 TTL=242 ID=10384 PROTO=TCP SPT=51528 DPT=23376 SEQ=4081964383 ACK=0 WINDOW=1024 RES=0x00 SYN URGP=0
Jun 30 02:22:33 kernel: DROP IN=ppp0 OUT= MAC= SRC=91.240.118.28 DST=51.148.166.159 LEN=40 TOS=0x00 PREC=0x00 TTL=247 ID=58205 PROTO=TCP SPT=41010 DPT=37136 SEQ=2088424658 ACK=0 WINDOW=1024 RES=0x00 SYN URGP=0
Jun 30 02:22:59 syslog: WLCEVENTD wlceventd_proc_event(466): eth1: Deauth_ind 1C:C7:2D:10:A6:95, status: 0, reason: Disassociated due to inactivity (4)
Jun 30 02:22:59 syslog: WLCEVENTD wlceventd_proc_event(481): eth1: Disassoc 1C:C7:2D:10:A6:95, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8)
Jun 30 02:23:21 kernel: DROP IN=ppp0 OUT= MAC= SRC=45.95.168.79 DST=51.148.166.159 LEN=40 TOS=0x00 PREC=0x00 TTL=51 ID=17666 PROTO=TCP SPT=50724 DPT=23 SEQ=865379999 ACK=0 WINDOW=45404 RES=0x00 SYN URGP=0
Jun 30 02:23:23 kernel: DROP IN=ppp0 OUT= MAC= SRC=91.240.118.28 DST=51.148.166.159 LEN=40 TOS=0x00 PREC=0x00 TTL=247 ID=37454 PROTO=TCP SPT=41010 DPT=37894 SEQ=3242631383 ACK=0 WINDOW=1024 RES=0x00 SYN URGP=0
Jun 30 02:23:25 syslog: WLCEVENTD wlceventd_proc_event(466): eth1: Deauth_ind 1C:C7:2D:10:A6:95, status: 0, reason: Class 3 frame received from nonassociated station (7)
Jun 30 02:23:26 syslog: WLCEVENTD wlceventd_proc_event(500): eth1: Auth 1C:C7:2D:10:A6:95, status: Successful (0)
Jun 30 02:23:26 syslog: WLCEVENTD wlceventd_proc_event(510): eth1: ReAssoc 1C:C7:2D:10:A6:95, status: Successful (0)
Jun 30 02:23:37 miniupnpd[945]: Failed to convert hostname 'fe80::290:a9ff:fed3:9ed2' to ip address
SAMPLE:
Im getting all these, very strange i might have to revert. to a previous build.
AX88U from Beta1 to 384.18. when I enable VPNC1 it kills my internet connection. if I enable VPNC2 it is fine. Not sure why that is.
Check your configuration. If you have it redirect traffic but don't configure it properly, then you will lose Internet access.
@RMerlin Is the listed GPL version for the AC88U correct?
Yes, what I wrote is correct. Note that I wrote "binary blobs", not "GPL". I only merged binary blobs that Asus specially compiled for me, as they didn't have any up to date GPL available for the RT-AC88U.
Bug in AiMesh code. Ignore it, it's in Asus's hands.
Channels are region-specific.
Will this update fix the 2.4ghz band on ax88u Or should I stick with .14?
I have zero problem with 2.4 GHz here. Check your configuration.
Should I upload some settings so u can help me
Out on this ? Or do u have some recommend settings for me ?
