Sorry I should have stated in my first post I am running 384.9 on a RT-AC86U.No not this time, but Asus.
Are you still on the 384.8_2 version or below? This issue is suppose to be fixed with 384.9
No, what I needed was the content of a specific config file, however another user provided me with his, and now it seems that the common element between the two of you is that both of you are using IPv6, so that might be the common cause.
Unfortunately since my ISP doesn't support IPv6, I doubt I'll be able to do much to troubleshoot this issue. I will have to see if it also happens with a HE tunnel, but that's a quite different setup.
Known issue from page 1.Nope on the latest 384.9 for the RT-AC86U
dcd process crashing on RT-AC86U (bug in Trend Micro's code, outside of my control).
The dcd crash isn't connected to httpd becoming unresponsive. httpd problems have been ongoing a long time, dcd crashes are recent. If httpd were actually crashing, there's a system process (I think) that would detect it and restart it, like it does with dcd.Known issue from page 1.
Code:dcd process crashing on RT-AC86U (bug in Trend Micro's code, outside of my control).
Has happened to me several times also. Not accessible from Microsoft Edge. But fully ok from Firefox.It is odd since everything works fine but the UI is unreachable.
I've had this happen on my AC86U as well, with the last 3 or 4 releases. I finally found a solution that works for me. The unresponsiveness occurs after about 2 weeks uptime. I set up a cron job in my /jffs/scripts/services-start script with this line that restarts httpd daemon every Sunday morning at 0715 hours.Have noticed there is a UI lockup at times which may coincide with increased connection to the router.
The UI becomes unreachable and a restart is needed to get access again.
Everything else seems to work though be it wifi and wired connections even if the UI isn't reachable.
AC86U
cru a httpd_restart "15 7 * * * Sun /sbin/service restart_httpd"
Sounds similar to this thread....I'm not sure if anybody experienced what I experienced recently:
I remotely viewed my RT-AC68R with HTTPS (with Merlin's 384.9 firmware running for 12 days) and saw that CPU core #2 was at 100% for a while. This wasn't normal, so I decided to reboot the router (GUI reboot button). I waited for the reboot to finish but I couldn't remotely log back into my router after a few minutes. I attributed the failed login due to DDNS not updating to new IP address (v4). Hours later, I still couldn't reboot it. Came home a couple of days later, logged into the router via computer WLAN, GUI shows internet disconnected, CPU utilization normal (few % for both cores). Did GUI reboot again. Still shows internet disconnected. Decided to pull the power and start the router back up. Internet is available again.
I never experienced this type of reboot failure before.
I'm with ya' tallytr! A big 15 days 21 hours 57 minute(s) 5 seconds here on my AC88U, and indeed it would be longer but a couple of reboots early on take safely make some significant settings changes. She's smokin'!!I never ever had that with any router before. RT-AC86U on Merlin 384.9, holy cow!
This thing will run forever without need for rebooting...before had to typically reboot every week for sure.
17 days 20 hours 0 minute(s) 13 seconds
yep.. except I've not had anything in the ports for years and I rebooted the router twice in the process of trying to flash it.opss
Same thread , same model !
https://www.snbforums.com/threads/r...-9-is-now-available.54843/page-22#post-467159
Do yourself a solid, reset the router and manually config.I still have problems connecting my Squeezebox Boom via WiFi. I also get occasional disconnects from my laptop where I never had problems before. Is there a way to debug WiFi connections so I can find out where the problems lies? Otherwise I would need to factory reset it completely and start from scratch![]()
I will at the end definitely do that. I just want to know why this happened, so it will not happen again in the future. Maybe it is unrelated to whatever I configured.Do yourself a solid, reset the router and manually config.
I have an AC86U with Merlin 384.9 and full time OpenVPN client with that lineHi, Guys after this update my client VPN connection is now broken to my VPN provider. All of a sudden get authentication error and even after updating the pull-filter ignore "auth token" within custom.
The version before
384.9
is still working great.
I have an AC86U with Merlin 384.9 and full time OpenVPN client with that line, all on one line with no quotes as you show. My VPN connection has been up for over six days at this pointCode:pull filter ignore auth token
RT-AC87U - no problems going from 384.7 to 384.9 and memory seems to be being released now instead of gradually going up and needing a monthly reboot.opss
Welcome To SNBForums
