scMerlin scMerlin - service and script control menu for AsusWRT-Merlin
@Jack Yaz, does it make sense to request a 'router uptime' indicator for scMerlin? Even if it isn't realtime, just executed when the script is run?
Edit: Also, would an 'l' command be possible to list all Entware scripts too? :D
I should be able to retrieve that (to both) - entware would simply list /opt/etc/init.d if that's what you'are after?
I've looked a bit at the directory you posted and it doesn't seem to show anything useful (at least to my eyes)?
I stumbled across /opt/bin and it seems to be a better 'hit'. But isn't /jffs/scripts/ a better place over all of the others?
All I originally was asking for was a way to see all installed scripts, your way may still be the best! :)
Is this what you want?
[redacted]@RT-AC86U-4608:/tmp/home/root# opkg list-installed
bind-dig - 9.12.3-P4-1
bind-libs - 9.12.3-P4-1
ca-bundle - 20180409-3
ca-certificates - 20180409-3
drill - 1.7.0-4
entware-opt - 227000-3
entware-release - 1.0-2
entware-upgrade - 1.0-1
file - 5.35-1
findutils - 4.6.0-3
glib2 - 2.58.3-1
grep - 3.3-1
htop - 2.2.0-2
libart - 2.3.21-1
libattr - 2.4.48-1
libblkid - 2.33-2
libc - 2.27-8
libcap - 2.26-1
libcurl - 7.64.0-1
libdbi - 0.9.0-4
libedit - 20181209-3.1-1
libffi - 3.2.1-3
libfreetype - 2.9.1-2
libgcc - 7.4.0-8
libhavege - 1.9.4-1
libiconv-full - 1.11.1-4
libintl-full - 0.19.8.1-2
libjson-c - 0.12.1-3
libldns - 1.7.0-4
libmagic - 5.35-1
libncurses - 6.1-3
libncursesw - 6.1-3
libopenssl - 1.1.1a-2
libpcap - 1.9.0-2
libpcre - 8.42-2
libpng - 1.6.36-1
libpopt - 1.16-2
libpthread - 2.27-8
libreadline - 8.0-1a
librrd - 1.2.30-3a
librt - 2.27-8
libsqlite3 - 3260000-3
libssp - 7.4.0-8
libstdcpp - 7.4.0-8
libuuid - 2.33-2
libyaml - 0.2.1-1
locales - 2.27-8
logrotate - 3.15.0-1a
ntp-utils - 4.2.8p12-2
ntpd - 4.2.8p12-2
openssh-keygen - 7.9p1-4
openssh-server - 7.9p1-4
openssh-sftp-server - 7.9p1-4
opkg - 2019-01-31-d4ba162b-1
parted - 3.2-1
pixelserv-tls - 2.2.1-1
rrdtool - 1.2.30-3a
sqlite3-cli - 3260000-3
syslog-ng - 3.19.1-2
tcpdump - 4.9.2-1b
terminfo - 6.1-3
tree - 1.8.0-1
zlib - 1.2.11-2
zoneinfo-asia - 2018i-1
zoneinfo-europe - 2018i-1
zoneinfo-northamerica - 2018i-1
drill - 1.7.0-4
file - 5.35-1
findutils - 4.6.0-3
glib2 - 2.58.3-1
grep - 3.3-1
htop - 2.2.0-2
libart - 2.3.21-1
libattr - 2.4.48-1
libblkid - 2.33-2
libc - 2.27-8
libcap - 2.26-1
libcurl - 7.64.0-1
libdbi - 0.9.0-4
libffi - 3.2.1-3
libgcc - 7.4.0-8
libhavege - 1.9.4-1
libldns - 1.7.0-4
libmagic - 5.35-1
libncurses - 6.1-3
libncursesw - 6.1-3
libpcap - 1.9.0-2
libpcre - 8.42-2
libpng - 1.6.36-1
libpopt - 1.16-2
libpthread - 2.27-8
librrd - 1.2.30-3a
librt - 2.27-8
libssp - 7.4.0-8
libstdcpp - 7.4.0-8
libuuid - 2.33-2
libyaml - 0.2.1-1
locales - 2.27-8
ntpd - 4.2.8p12-2
parted - 3.2-1
rrdtool - 1.2.30-3a
tcpdump - 4.9.2-1b
terminfo - 6.1-3
tree - 1.8.0-1
zlib - 1.2.11-2
Yes! Those, plus all the user scripts installed too. ;)
[redacted]e@RT-AC86U-4608:/tmp/home/root# ls -al /jffs/scripts/
drwxr-xr-x    2 [redacted] root             0 May  5 10:30 .
drwxr-xr-x   14 [redacted] root             0 May  5 10:34 ..
-rwxr-xr-x    1 [redacted] root         16834 Mar 18 15:11 ChkWAN.sh
-rwxr-xr-x    1 [redacted] root         37402 Mar 20 15:02 VPN_Failover.sh
-rwxr-xr-x    1 [redacted] root         60996 Apr 30 09:53 amtm
-rwxr-xr-x    1 [redacted] root         25323 May  4 10:57 connmon
-rw-rw-r--    1 [redacted] root         64360 May  5 10:45 connmonstats_rrd.rrd
-rw-rw-r--    1 [redacted] root          5235 May  2 12:13 connmonstats_www.asp
-rw-rw-r--    1 [redacted] root         20728 May  5 09:23 custom_menuTree.js
-rw-rw-r--    1 [redacted] root         24196 May  5 09:23 custom_start_apply.htm
-rwxr-xr-x    1 [redacted] root          3515 Apr 21 09:52 disk-check
-rwxr-xr-x    1 [redacted] root            39 Mar 18 15:11 dnsmasq.conf.add
-rwxr-xr-x    1 [redacted] root            73 Mar 18 15:11 dnsmasq.postconf
-rwxr-xr-x    1 [redacted] root        189875 Apr 16 18:38 firewall
-rwxr-xr-x    1 [redacted] root            99 Apr 29 08:51 firewall-start
-rwxr-xr-x    1 [redacted] root           432 Mar 23 20:22 init-start
-rwxr-xr-x    1 [redacted] root            56 Mar 18 15:11 ledsoff.sh
-rwxr-xr-x    1 [redacted] root            56 Mar 18 15:11 ledson.sh
-rwxr-xr-x    1 [redacted] root           108 May  4 10:43 nat-start
-rw-rw-rw-    1 [redacted] root        128320 May  5 10:45 ntpdstats_rrd.rrd
-rw-rw-rw-    1 [redacted] root          5150 May  3 14:04 ntpdstats_www.asp
-rwxr-xr-x    1 [redacted] root         32138 May  4 11:04 ntpmerlin
-rwxr-xr-x    1 [redacted] root            11 Apr 29 07:55 openvpn-event
-rwxr-xr-x    1 [redacted] root           333 Apr 30 09:58 post-mount
-rwxr-xr-x    1 [redacted] root           629 May  5 07:20 post-mount.div
-rwxr-xr-x    1 [redacted] root            53 Mar 18 15:11 pre-mount
-rwxr-xr-x    1 [redacted] root            98 Apr 16 07:04 rm_dcd_crash
-rwxr-xr-x    1 [redacted] root           726 Mar 21 19:47 rm_ovpn_cert.sh
-rwxr-xr-x    1 [redacted] root         13632 May  4 10:27 scmerlin
-rwxr-xr-x    1 [redacted] root         22177 May  4 07:27 scribe
-rwxr-xr-x    1 [redacted] root           245 May  4 11:12 service-event
-rwxr-xr-x    1 [redacted] root           309 May  4 10:59 services-start
-rwxr-xr-x    1 [redacted] root           121 Apr 16 18:37 services-stop
-rwxr-xr-x    1 [redacted] root         44779 May  5 06:16 uiDivStats
-rw-rw-rw-    1 [redacted] root          1613 May  5 10:02 uiDivStats_cache.tar.gz
-rw-rw-r--    1 [redacted] root         64360 Apr 30 11:38 uidivstats_rrd.rrd
-rw-rw-rw-    1 [redacted] root          8589 May  5 10:30 uidivstats_www.asp
-rwxr-xr-x    1 [redacted] root           408 Mar 18 15:11 unmount
-rwxr-xr-x    1 [redacted] root          3174 Mar 18 15:11 update-notification
-rwxr-xr-x    1 [redacted] root           351 May  4 20:51 wan-start
Or maybe OP wants the full list of available packages (it's long!):
opkg list
Or perhaps OP wants something like this?
./EntwareApps.sh
Downloading http://bin.entware.net/armv7sf-k2.6/Packages.gz
Updated list of available packages in /opt/var/opkg-lists/entware
List of Installed packages:
aria2 - 1.34.0-5                libcap - 2.26-1             libreadline - 8.0-1a          python-ctypes - 2.7.15-5
bash - 5.0-2                    libcares - 1.15.0-4         librrd - 1.2.30-3a            python-db - 2.7.15-5
bind-dig - 9.12.3-P4-1a         libcurl - 7.64.0-1          librt - 2.23-8                python-decimal - 2.7.15-5
bind-libs - 9.12.3-P4-1a        libdb47 - 4.7.25.4.NC-5     libsmartcols - 2.33-2         python-distutils - 2.7.15-5
ca-bundle - 20180409-3          libdbi - 0.9.0-4            libsqlite3 - 3260000-3        python-email - 2.7.15-5
ca-certificates - 20180409-3    libedit - 20181209-3.1-1    libssh2 - 1.8.0-3             python-gdbm - 2.7.15-5
column - 2.33-2                 libexpat - 2.2.6-1          libssp - 7.4.0-8              python-light - 2.7.15-5
coreutils - 8.30-1              libfdisk - 2.33-2           libstdcpp - 7.4.0-8           python-logging - 2.7.15-5
coreutils-base64 - 8.30-1       libffi - 3.2.1-3            libtirpc - 1.1.4-1            python-multiprocessing - 2.7.15-5
coreutils-nohup - 8.30-1        libfreetype - 2.9.1-2       libunbound - 1.9.0-1          python-ncurses - 2.7.15-5
coreutils-paste - 8.30-1        libgcc - 7.4.0-8            libuuid - 2.33-2              python-openssl - 2.7.15-5
diffutils - 3.7-1               libgdbm - 1.11-1            libxml2 - 2.9.9-1             python-pydoc - 2.7.15-5
drill - 1.7.0-4                 libhavege - 1.9.4-1         libyaml - 0.2.1-1             python-sqlite3 - 2.7.15-5
entware-opt - 227000-3          libiconv-full - 1.11.1-4    locales - 2.23-8              python-unittest - 2.7.15-5
entware-release - 1.0-2         libintl-full - 0.19.8.1-2   logrotate - 3.15.0-1a         python-xml - 2.7.15-5
entware-upgrade - 1.0-1         libjson-c - 0.12.1-3        lsof - 4.91-1                 rrdtool - 1.2.30-3a
fdisk - 2.33-2                  libldns - 1.7.0-4           mosquitto-client-nossl - 1.5.7-1    rsync - 3.1.3-2
findutils - 4.6.0-3             libmbedtls - 2.16.0-2       netdata - 1.12.1-1a           sqlite3-cli - 3260000-3
glib2 - 2.58.3-1                libmnl - 1.0.4-2            nmap - 7.70-1a                strace - 4.26-1
google-authenticator-libpam - 1.05-1    libmosquitto-nossl - 1.5.7-1        ntp-utils - 4.2.8p12-2          syslog-ng - 3.19.1-2
grep - 3.3-1                    libncurses - 6.1-3          ntpd - 4.2.8p12-2             tcpdump - 4.9.2-1b
htop - 2.2.0-2                  libncursesw - 6.1-3         oniguruma - 6.9.1-1           terminfo - 6.1-3
iftop - 2017-03-22-949ed0f7-1   libopenssl - 1.1.1a-2       openssh-sftp-server - 7.9p1-4 unbound - 1.9.0-1
jq - 1.6-1                      libopenssl-conf - 1.1.1a-2  openssl-util - 1.1.1a-2       wget-nossl - 1.20.1-3a
ldconfig - 2.23-8               libpam - 1.3.1-1            opkg - 2019-01-31-d4ba162b-1  xxd - 8.1-1
libacl - 20180121-1             libpcap - 1.9.0-2           pixelserv-tls - V35.HZ12.Kk-1 zlib - 1.2.11-2
libart - 2.3.21-1               libpcre - 8.42-2            psmisc - 23.2-1               zoneinfo-asia - 2018i-1
libattr - 20170915-1            libpng - 1.6.36-1           python - 2.7.15-5             zoneinfo-europe - 2018i-1
libblkid - 2.33-2               libpopt - 1.16-2            python-base - 2.7.15-5
libbz2 - 1.0.6-5a               libpthread - 2.23-8         python-codecs - 2.7.15-5
libc - 2.23-8                   libqrencode - 4.0.2-1       python-compiler - 2.7.15-5
Entware Apps/Scripts installed /opt/bin:
aria2c          dig         iftop           mosquitto_pub       peekfd                  python2.7       strace
ash             diversion   islebe          mosquitto_sub       pixelserv-tls           rbash           update-patterndb
base64          dqtool      jq              netstat             pixelserv-tls.backup    rrdtool         wget-nossl
bash            drill       killall         nmap                prtstat                 rrdupdate       xargs
cmp             find        locale.new      nohup               pslog                   rsync           xxd
column          fuser       localedef.new   openssl             pstree                  sdiff
diff            grep        loggen          paste               python                  sh
diff3           htop        lsof            pdbtool             python2                 sqlite3
amtm        diversion    scribe
Entware Apps installed /opt/sbin:
fdisk           logrotate           ntpdc           pam_tally2            syslog-ng-ctl       unix_chkpwd
ifconfig        mkhomedir_helper    ntpq            pam_timestamp_check   tcpdump             unix_update
ldconfig        netdata             ntptime         route                 unbound
logread         ntpd                pam_tally       syslog-ng             unbound-checkconf
NOTE: Output format looks better if Entware's 'column' utility is installed!!
curl --retry 3 "https://raw.githubusercontent.com/MartineauUK/Entware-Report/master/EntwareApps.sh" -o "/jffs/scripts/EntwareApps.sh" && chmod 0755 /jffs/scripts/EntwareApps.sh
P.S. Pity I have to explicitly code an exception for 'diversion'! ;)
I see, the others have symlinks. Bit of a hassle to change that for Diversion, it's complicated code I have for the main executable and I might brake things with so many installations out there.
But THIS IS NICE! I like the column arrangement, seems to adapt to terminal width. With your permission, I will add it to the sf (show file) function in Diversion, where you already contributed code.
This would also be a candidate script for amtm, within the Entware menu!
./EntwareApps.sh
How sweet it is!!! Very nice!
./EntwareApps.sh
Welcome to the party! I see you've published most of your scripts on Github now :)
Excellent, thank you [emoji106]
v1.0.3 is now available
Changelog:
Add ability to see CPU usage (via htop/top)
Add ability to see memory/RAM usage (free)
Hmm...think I beat you to it. Ran "SU" on amtm yesterday and saw the update but didn't see anything regarding it. Thanks, everything running smooth as butter on a hot tin roof!
I was just going to post the same. :)
@Jack Yaz, this addon is getting indispensable for me. :)
