spdMerlin spdMerlin - v4.x - speedtest and bandwidth monitoring
Thanks this is great.
I've only updated today and initially would not show any speed-tests even when hitting Run Speedtest, it would also not allow any change to data storage method or display the historical data. This was fixed simply by running a speed-test via CLi but has left those speed-tests from before upgrading to v4 with null value, was it previously not capturing latency or jitter?
Update: DOH my bad, Jack Yaz clearly mentioned must run first in CLi mode to accept licence in release notes.
correct, no latency or jitter prior to v4
Hi. I upgraded to version 4 today. Tried to do a CSV dump and get 404 error on the URL "http://192.168.1.254/ext/spdmerlin/csv/spdmerlindata.zip"
I can't find an spdmerlindata.zip file in the router filesystems. Is there some configuration I need to do ?
Pete
PS: Not tried a CSV dump before so no idea if it worked in previous versions
Running RT-AC68U with 384.19
do you get any errors running a speedtest in cli please?
Assuming this is what you referring to....Both of my routers have the config file disappearing issue and are on Trend Micro: Signature version 2.204. One of the routers shows "Updated 2020/11/12" while other router shows 2020/10/30. Clicking "Check" finds no new signatures yet but they may not be pushed yet? Just adding more detail in case others notice same issue.
Different signature files.
Ah - yes ...
Downloading http://pkg.entware.net/binaries/armv7/Packages.gz.
Updated list of available packages in /opt/var/opkg-lists/packages.
Package p7zip (16.02-1) installed in root is up to date.
/opt/bin/spdmerlin: line 2864: /opt/bin/7z: not found
mv: can't rename '/tmp/spdmerlindata.zip': No such file or directory
/opt/bin has this:
-rwxr-xr-x 1 delladmi root 994372 Jan 4 2018 /opt/bin/7za
but no 7z binary.
Ah - yes ...
/opt/bin has this:
but no 7z binary.
i wonder why the 7z binary isn't being included in entware...
ah well, changed in develop, will be in 4.0.1
Ah - yes ...
/opt/bin has this:
but no 7z binary.
How old is your Entware installation? My Packages.gz downloads from bin.entware.net.
Hmmm. I edited the spdmerlin script to change 7z to 7za, and get this:
/opt/bin/7za: /opt/lib/libstdc++.so.6: version `CXXABI_1.3.8' not found (required by /opt/bin/7za)
/opt/bin/7za: /opt/lib/libstdc++.so.6: version `CXXABI_1.3.9' not found (required by /opt/bin/7za)
Is entware installed by the merlin firmware updates or is it separate ? Looks like my entware install is borked ?
I installed entware a long time ago and haven't touched it since. I know this is off topic but anyone have an idea what to do ? Can I upgrade entware or do I need a complete reinstall of it ?
OK. I'd forgotten it was like a debian package management system. after opkg update and opkg upgrade it informed me
File /opt/etc/opkg.conf upgraded, new repository set!
Please run opkg update + opkg upgrade once more
so I've run the update/upgrade cycle twice and now I have the 7z binary installed.
Doh! Cheers guys and sorry to have wasted your time!
You can probably roll that back, because the 7za binary I had didn't work anyway. May be worth noting in the README that it is worth running a couple of cycles of opkg update/opkg upgrade to ensure that the entware packages are up to date ?
@NGI for your AutoBW threshold idea, do you think a single % threshold is sufficient, or separate for upload and download?
Jack - brilliant additions to latest SpdMerlin - sent you some appreciation:)
Thanks @Jack Yaz I'm happy with your choice. I will test it today and report.
@Jack Yaz I did a quick test and when I choose 0% threshold I still don't get the BW values to change see below in bold:
1. Update QoS bandwidth values now
2. Configure scale factor
Download: 90% - Upload: 90%
3. Configure bandwidth limits
Upper Limit Download: 0 Mbps - Upload: 0 Mbps
Lower Limit Download: 0 Mbps - Upload: 0 Mbps
4. Configure threshold for updating QoS bandwidth values
Download: 0% - Upload: 10%
5. Toggle AutoBW on/off
Currently: Enabled
e. Go back
Choose an option: 1
spdMerlin: Calculated Download speed (26241) Kbps does not exceed 0% threshold of existing value (26104 Kbps)
spdMerlin: Calculated Download speed (5289) Kbps does not exceed 10% threshold of existing value (5262 Kbps)
Press enter to continue...
I seems to work for Upload BW but not for Download BW
@Jack Yaz - Would it be possible to have an option to keep more than 30 days of data ? Perhaps an option to archive records > 30 days to a USB drive ?
Or do I need to pull down the sqlite database on a regular basis ?
