spdMerlin spdMerlin - v4.x - speedtest and bandwidth monitoring
v4.1.0 is now available
Changelog:
  • NEW: Set a threshold that must be broken for AutoBW calculated values to be applied over existing values
  • FIXED: Data usage over 1GB now reports correctly
  • FIXED: Last 10 results table would incorrectly populate columns when result URL collection is disabled
  • CHANGED: Use 7za instead of 7z (for older Entware installs)
Changelog:
@Jack Yaz would it be possible to implement a decimal into the MBPS for those who have low connections. I believe it may benefit me for my upload to keep between 1.7 and .8 or so. Thanks!
@Jack Yaz on v4.1.0 when I use "Update QoS bandwidth values now" from the CLI I can currently see a strange 2.4% difference between the values of the DB/UB speed from the CLI compared to the GUI. E.g. Download Bandwidth from CLI "...existing value (24677 Kbps)" from the GUI - 24.0986328125 Mb/s and for the Upload Bandwidth from the CLI "...existing value (5289 Kbps)" and from the GUI - 5.1650390625 Mb/s.
by GUI do you mean the adaptive qos page?
edit: divide the kbps by 1024....looks right to me
Yes the GUI from the Adaptive QoS page. I allways thought that the conversion from kbps to Mbps is a division by a 1000. But a Google search brings multiple results that show division by 1024 as well as 1000 :rolleyes: so I'm confused but please ignore my question.
The QoS page takes Mb/s as input and stores nvram in kb/s (* 1024). But the underlying QoS tc structure takes those kb/s and applies them using 1000 (SI) instead of 1024 (IEC) bits per kilo.
Hi @Jack Yaz , I'm getting some unexpected results with ABw setting the DL speed in NVRAM so I will welcome your help if you could have a look at it.
You can see from the attached that the last scheduled speedtest at 18.42 had DL of 23.61 Mbps and 95% of it is 22.4295 Mbps but the value in the QoS page is 20.62597656 Mbps which is outside of the 5% update threshold I setup so it should have been undated. I'm not sure if it did nto get updated or it get update with a wrong value but I also can't match it with any of the previous values of the scheduled speed-tests. Am I missing something?
Many thanks in advance.
PS I have v4.1.0 and also have done force update
AutoBW calculations should go to syslog
Thanks Jack for clarifying that. Below is the syslog:
Nov 30 18:42:00 RT-AC86U-4AB0 spdMerlin: Starting speedtest using Structured Communications (London, United Kingdom) for WAN interface
Nov 30 18:42:20 RT-AC86U-4AB0 spdMerlin: Speedtest results - Download: 23.61 Mbps (data used: 28.0 MB) - Upload: 5.32 Mbps (data used: 2.4 MB)
Nov 30 18:42:20 RT-AC86U-4AB0 spdMerlin: Connection quality - Latency: 14.77 ms (0.19 ms jitter) - Packet Loss: 0.0%%
Nov 30 18:42:22 RT-AC86U-4AB0 spdMerlin: Calculated Download speed (22022) Kbps does not exceed 5%% threshold of existing value (21121 Kbps)
I see where is the discrepancy, I thought that the calculated speed should have been 22,968 Kbps (23.61 Mbps*95%*1024) as oppose to 22022 Kbps. Is that correct?
The AutoBW feature currently uses the average of the last 10 speedtests, not the last result.
