Stubby-Installer-Asuswrt-Merlin
Guys, I'm a beginner.
I already installed stubby through amtm.
I would like to use cleanbrowsing adult.
How can I do it?
thank you.
For the adult filter specifically:
Adult Filter
Blocks access to all adult, pornographic and explicit sites. It does not block proxy or VPNs, nor mixed-content sites. Sites like Reddit are allowed. Google and Bing are set to the Safe Mode.
Domain:: adult-filter-dns.cleanbrowsing.org
IPv4 address: 185.228.168.10:853 and 185.228.169.11:853
IPv6 address: [2a0d:2a00:1::1]:853 and [2a0d:2a00:2::1]:853
Which translates to the following in stubby.yml:
# # Cleanbrowsing-Security
  - address_data: 185.228.168.10
    tls_auth_name: "adult-filter-dns.cleanbrowsing.org"
  - address_data: 185.228.168.11
   - address_data: 2a0d:2a00:1::1
  - address_data: 2a0d:2a00:2::1
Source: https://cleanbrowsing.org/guides/dnsovertls
Cleanbrowsing might not yet support TLS 1.3
Try changing the following line in stubby.yml to allow TLS 1.2
tls_min_version: GETDNS_TLS1_2
@bbunge @owine
The default installation works, with DNS 1.1.1.1.
With cleanbrowsing does not work.
After modifying the script and rebooting, the router gets WAN IP but does not browse.
admin@RT-AC86U:/# /opt/etc/init.d/S61stubby check
 Checking stubby...              dead.
Is my stubby.yml correct?
# stubby.yml configuration file created by Xentrk
# version 1.0.0
tls_ca_file: "/rom/etc/ssl/certs/ca-certificates.crt"
resolution_type: GETDNS_RESOLUTION_STUB
dns_transport_list:
  - GETDNS_TRANSPORT_TLS
tls_authentication: GETDNS_AUTHENTICATION_REQUIRED
tls_query_padding_blocksize: 128
edns_client_subnet_private : 1
round_robin_upstreams: 1
idle_timeout: 2000
tls_connection_retries: 5
tls_backoff_time: 900
timeout: 2000
appdata_dir: "/opt/var/cache/stubby"
listen_addresses:
  - 127.0.0.1@5453
  - 0::1@5453
upstream_recursive_servers:
# Quad 9 Secure Primary
#  - address_data: 9.9.9.9
#    tls_auth_name: "dns.quad9.net"
#  - address_data: 2620:fe::fe
# Cloudflare Primary IPv4
# - address_data: 1.1.1.1
#   tls_auth_name: "cloudflare-dns.com"
# Cloudflare Secondary IPv4
# - address_data: 1.0.0.1
# Cloudflare Primary IPv6
# - address_data: 2606:4700:4700::1111
# Cloudflare Secondary IPv6
# - address_data: 2606:4700:4700::1001
# Tweaks for statically linked binaries
tls_min_version: GETDNS_TLS1_3
tls_ciphersuites: "TLS_AES_128_GCM_SHA256:TLS_AES_256_GCM_SHA384:TLS_CHACHA20_POLY1305_SHA256"
DNS changes to router IP, is this correct?
Here is a version of syubby.yml that I have used for Cleanbrowsing Adult. Am using this on a public access WIFI/Router running OpenWRT. Also works on Asus Stubby:
# version 1.0.0
dns_transport_list:
idle_timeout: 2000
timeout: 2000
listen_addresses:
  - 127.0.0.1@5453
  - 0::1@5453
# Cleanbrowsing-Adult servers
#  - address_data: 2a0d:2a00:1::1
#    tls_auth_name: "adult-filter-dns.cleanbrowsing.org"
# Cleanbrowsing-Adult Alt servers
#  - address_data: 2a0d:2a00:2::1::
The IPV6 resolver addresses are commented out. If you use IPV6 remove the "#" like this:
I strongly recommend you do not enable DNSSEC in Stubby or Merlin as I have had connection issues with CleanBrowsing.
You do not have to restart your router to get the changes to work. Run:
/opt/etc/init.d/S61stubby restart
You may have to turn off the DNS WAN up check to get a reliable connection.
@bbunge @owine
# version 1.0.0
dns_transport_list:
idle_timeout: 2000
timeout: 2000
listen_addresses:
  - 127.0.0.1@5453
  - 0::1@5453
Based on Stubby not starting, I am assuming there is a syntax issue with your yml. It looks like the first IPv6 entry has an extra leading space on both lines at the very least.
stubby -i -C /opt/etc/stubby/stubby.yml
Might provide hints.
Does this installation of stubby include a statically linked, more up to date (ie the 1.1 branch) version of OpenSSL, like pixelserv-tls? Or does it dynamically use the OpenSSL bundled with the merlin fw, which is 1.0 branch and thus does not support TLS 1.3.
That is a good point. I chose the statically linked stubby.
I am successfully using CleanBrowsing DNS over TLS via TLS 1.2.
CleanBrowsing requires alternate TLS port 853. Add the "tls_port: 853" attribute to the upstream_recursive_server section in the stubby.yml config file.
UPDATE: I may have spoken too soon -- this does not appear to resolve the failures.
Yup, Port 853 is standard DoT port.
If you are having problems connecting:
Check stubby.yml format with: stubby -i .yml files can be tricky. Make a copy of the original file before you edit it that way you will have a good reference or a place to go back. I use WinSCP to browse the router directories and edit files. With a right click on a file you can duplicate a file with a new file extension. I have several stubby.yml files saved so I can switch resolvers in a heartbeat to check if things are working. Example: for Quad9 I duplicate the file as stubby.yml.q9.
Disable dnssec in Merlin. Get stubby to work first...
Check the router time. Failure to get time can cause the router to not connect. This was corrected with an entry in dnsmasq.conf.add but sometimes may not work. If all else fails set the time server to an IP address vs. a URL (129.6.15.28 worked for me in US)
Disable router WAN connection check. In 384.9 Beta1 it is a setting called Network Monitoring in Administration/System. In prior versions it is in Tools/Other Settings (and as I remember it was called something else).
Still does not work.
There is an error in the beginning, but I do not understand it.
/tmp/opt/etc/stubby$ stubby -i -C /opt/etc/stubby/stubby.yml
Reader error: invalid trailing UTF-8 octet: #E3 at 34
Could not parse config file # stubby.yml arquivo de configuração criado por Xentrk
# versão 1.0.0
dns_transport_list:
edns_client_subnet_private: 1
idle_timeout: 2000
timeout: 2000
appdata_dir: "/ opt / var / cache / stubby"
listen_addresses:
  - 127.0.0.1@5453
  - 0::1@5453
# Servidores Cleanbrowsing-Adulto
  - endereço_dados: 185.228.168.10
# - endereço_dados: 2a0d: 2a00: 1 :: 1
# Servidores Alt Cleanbrowsing-Adult
  - endereço_dados: 185.228.168.11
# - endereço_dados: 2a0d: 2a00: 2 :: 1 ::
# tls_auth_name: "adult-filter-dns.cleanbrowsing.org", "Generic error"
Could not parse config file "/opt/etc/stubby/stubby.yml": Generic error
Sorry, google translator.
Stubby is in English.
# version 1.0.0
dns_transport_list:
idle_timeout: 2000
timeout: 2000
listen_addresses:
  - 127.0.0.1@5453
  - 0::1@5453
# Cleanbrowsing Primary IPv4
# Cleanbrowsing Secondary IPv4
  - address_data: 185.228.169.11
# Cleanbrowsing Primary IPv6
# Cleanbrowsing Secondary IPv6
# version 1.0.0
dns_transport_list:
idle_timeout: 2000
timeout: 2000
listen_addresses:
  - 127.0.0.1@5453
  - 0::1@5453
@EmeraldDeer @bbunge @dave14305 @visortgw @Xentrk and others.
Many thanks to all for the help.
Apparently it's working now.
[01:35:19.850516] STUBBY: Read config from file /opt/etc/stubby/stubby.yml
[01:35:19.851556] STUBBY: DNSSEC Validation is OFF
[01:35:19.851727] STUBBY: Transport list is:
[01:35:19.851865] STUBBY:   - TLS
[01:35:19.852009] STUBBY: Privacy Usage Profile is Strict (Authentication required)
[01:35:19.852123] STUBBY: (NOTE a Strict Profile only applies when TLS is the ONLY transport!!)
[01:35:19.852266] STUBBY: Starting DAEMON....
[01:35:33.382446] STUBBY: --- SETUP(TLS): : Verify locations loaded
[01:35:33.383219] STUBBY: 185.228.168.10                           : Conn opened: TLS - Strict Profile
[01:35:33.455078] STUBBY: 185.228.168.10                           : Verify passed : TLS
[01:35:35.760571] STUBBY: 185.228.168.10                           : Conn closed: TLS - Resps=     1, Timeouts  =     0, Curr_auth =Success, Keepalive(ms)=  2000
[01:35:35.760630] STUBBY: 185.228.168.10                           : Upstream   : TLS - Resps=     1, Timeouts  =     0, Best_auth =Success
[01:35:35.760639] STUBBY: 185.228.168.10                           : Upstream   : TLS - Conns=     1, Conn_fails=     0, Conn_shuts=      1, Backoffs     =     0
[01:35:45.764912] STUBBY: 185.228.169.11                           : Conn opened: TLS - Strict Profile
[01:35:46.379259] STUBBY: 185.228.169.11                           : Verify passed : TLS
[01:35:48.535606] STUBBY: 185.228.169.11                           : Conn closed: TLS - Resps=     1, Timeouts  =     0, Curr_auth =Success, Keepalive(ms)=  2000
[01:35:48.535666] STUBBY: 185.228.169.11                           : Upstream   : TLS - Resps=     1, Timeouts  =     0, Best_auth =Success
[01:35:48.535675] STUBBY: 185.228.169.11                           : Upstream   : TLS - Conns=     1, Conn_fails=     0, Conn_shuts=      1, Backoffs     =     0
[01:36:16.934685] STUBBY: 2a0d:2a00:1::1                           : Conn closed: TLS - Resps=     0, Timeouts  =     0, Curr_auth =   None, Keepalive(ms)=     0
[01:36:16.934746] STUBBY: 2a0d:2a00:1::1                           : Upstream   : TLS - Resps=     0, Timeouts  =     0, Best_auth =   None
[01:36:16.934755] STUBBY: 2a0d:2a00:1::1                           : Upstream   : TLS - Conns=     0, Conn_fails=     1, Conn_shuts=      0, Backoffs     =     0
[01:36:16.934781] STUBBY: 2a0d:2a00:2::1                           : Conn closed: TLS - Resps=     0, Timeouts  =     0, Curr_auth =   None, Keepalive(ms)=     0
[01:36:16.934791] STUBBY: 2a0d:2a00:2::1                           : Upstream   : TLS - Resps=     0, Timeouts  =     0, Best_auth =   None
[01:36:16.934799] STUBBY: 2a0d:2a00:2::1                           : Upstream   : TLS - Conns=     0, Conn_fails=     1, Conn_shuts=      0, Backoffs     =     0
[01:36:16.935019] STUBBY: 185.228.168.10                           : Conn opened: TLS - Strict Profile
[01:36:19.070751] STUBBY: 185.228.168.10                           : Conn closed: TLS - Resps=     1, Timeouts  =     0, Curr_auth =Success, Keepalive(ms)=  2000
[01:36:19.070816] STUBBY: 185.228.168.10                           : Upstream   : TLS - Resps=     2, Timeouts  =     0, Best_auth =Success
[01:36:19.070826] STUBBY: 185.228.168.10                           : Upstream   : TLS - Conns=     2, Conn_fails=     0, Conn_shuts=      2, Backoffs     =     0
[01:36:33.453898] STUBBY: 185.228.169.11                           : Conn opened: TLS - Strict Profile
[01:36:36.128927] STUBBY: 185.228.169.11                           : Conn closed: TLS - Resps=     1, Timeouts  =     0, Curr_auth =Success, Keepalive(ms)=  2000
[01:36:36.128991] STUBBY: 185.228.169.11                           : Upstream   : TLS - Resps=     2, Timeouts  =     0, Best_auth =Success
[01:36:36.128999] STUBBY: 185.228.169.11                           : Upstream   : TLS - Conns=     2, Conn_fails=     0, Conn_shuts=      2, Backoffs     =     0
[01:36:39.632171] STUBBY: 2a0d:2a00:1::1                           : Conn closed: TLS - Resps=     0, Timeouts  =     0, Curr_auth =   None, Keepalive(ms)=     0
[01:36:39.632228] STUBBY: 2a0d:2a00:1::1                           : Upstream   : TLS - Resps=     0, Timeouts  =     0, Best_auth =   None
[01:36:39.632237] STUBBY: 2a0d:2a00:1::1                           : Upstream   : TLS - Conns=     0, Conn_fails=     2, Conn_shuts=      0, Backoffs     =     0
[01:36:39.632262] STUBBY: 2a0d:2a00:2::1                           : Conn closed: TLS - Resps=     0, Timeouts  =     0, Curr_auth =   None, Keepalive(ms)=     0
[01:36:39.632272] STUBBY: 2a0d:2a00:2::1                           : Upstream   : TLS - Resps=     0, Timeouts  =     0, Best_auth =   None
[01:36:39.632280] STUBBY: 2a0d:2a00:2::1                           : Upstream   : TLS - Conns=     0, Conn_fails=     2, Conn_shuts=      0, Backoffs     =     0
[01:36:39.632446] STUBBY: 185.228.168.10                           : Conn opened: TLS - Strict Profile
[01:36:42.024019] STUBBY: 185.228.168.10                           : Conn closed: TLS - Resps=     1, Timeouts  =     0, Curr_auth =Success, Keepalive(ms)=  2000
[01:36:42.024087] STUBBY: 185.228.168.10                           : Upstream   : TLS - Resps=     3, Timeouts  =     0, Best_auth =Success
[01:36:42.024096] STUBBY: 185.228.168.10                           : Upstream   : TLS - Conns=     3, Conn_fails=     0, Conn_shuts=      3, Backoffs     =     0
# version 1.0.0
dns_transport_list:
idle_timeout: 2000
timeout: 2000
listen_addresses:
  - 127.0.0.1@5453
  - 0::1@5453
Get rid of the last three lines. You do not need tweaks...
Just for people to know, stubby and getdns is updated in Entware
getdns - 1.5.1-1
stubby - 0.2.5-1
Anyone can try help compile it with statically-linked OpenSSL 1.1.1a?
Can anyone shed some light on why Stubby is being called to start just moments before the router powers down in a reboot?
getdns - 1.5.1-1
stubby - 0.2.5-1
Upgraded successfully to the new versions on my "older" router.
opkg update
opkg upgrade
You will get an error message which you can ignore:
Collected errors:
* resolve_conffiles: Existing conffile /opt/etc/stubby/stubby.yml is different from the conffile in the new package. The new conffile will be placed at /opt/etc/stubby/stubby.yml-opkg.
I rebooted the router to make sure everything works. If you want just restart getdns and stubby.
bb
