jsmiddleton4
Is Alpha 4 a RMerlin release?
Its not my cable internet.did u try direct connecting from modem to pc and not use any router.
imo its ur cable internet connection thats the problem and not ur router .
any modem logs?
did u try a different router?
if u tried all above it could be router hw problem and not a fw problem
probably yes but:*edit2*
Router started again to slowdown and feel sluggish, no errors other than random drop connections by the firewall.
I guess my N66 U is dying?
If the CPU load ever get high again, use "top" to determine what's using all the CPU time.
alpha 4 is an unofficial build at the moment. you should post your question here: http://www.snbforums.com/threads/unofficial-build-380-58.29787/380.58_alpha4@cda869c
On AC68U and AC56Us up now for over a week, no problems except Traffic....
WAN (arris) 60mb service ok no restarts (charter) turned off IPV6 charter sucks on IPV6!
Look MA it's all black!
think I have a problem with 56Us and BL 1028 & 1029 going to load BL 1027 back on the 56U!
with the WAN led other 4 56Us (ap mode) (bl 1027) don't have a problem with the WAN led?? only diff is the BL being 1028
if did work (BL 1027) as this was my back up DHCP and main router for the AC68U!
So the slow down started again and SSH'd into router and used top to see whats causing the lag.
I also checked the logs and found some interesting dhcp msgs repeating every few seconds from my laptop... I saw the same dhcp msgs from my voip ata device last time the router slowed down. Can you guys make anything of it?
I did a search in the code today, and couldn't find anything hardcoded to "admin" in rc, so I'm not sure why the router's username would matter.
Can you try setting your username to something different than admin, and post me the output of this command?
Code:ps w
it will let me see if some process runs with the wrong user.
PID USER VSZ STAT COMMAND
1 test 6232 S /sbin/preinit
2 test 0 SW [kthreadd]
3 test 0 SW [ksoftirqd/0]
4 test 0 SW [kworker/0:0]
5 test 0 SW [kworker/u:0]
6 test 0 SW [migration/0]
7 test 0 SW [migration/1]
8 test 0 SW [kworker/1:0]
9 test 0 SW [ksoftirqd/1]
10 test 0 SW< [khelper]
11 test 0 SW [kworker/u:1]
57 test 0 SW [sync_supers]
59 test 0 SW [bdi-default]
60 test 0 SW< [kblockd]
114 test 0 SW [kswapd0]
160 test 0 SW [fsnotify_mark]
168 test 0 SW< [crypto]
240 test 0 SW [mtdblock0]
245 test 0 SW [mtdblock1]
250 test 0 SW [mtdblock2]
255 test 0 SW [mtdblock3]
277 test 0 SW [kworker/0:1]
278 test 0 SW [kworker/1:1]
281 test 0 SW [mtdblock4]
286 test 0 SW [mtdblock5]
290 test 664 S hotplug2 --persistent --no-coldplug
348 test 6208 S console
350 test 1388 S /bin/sh
355 test 0 SWN [jffs2_gcd_mtd4]
358 test 1380 S /sbin/syslogd -m 0 -S -O /tmp/syslog.log -s 256 -l 7
360 test 1384 S /sbin/klogd -c 5
363 test 660 S /usr/sbin/sd-idle-2.6 -i 10
453 test 728 S /usr/sbin/snooper -b br0 -s vlan1
463 test 6216 S /sbin/wanduck
465 test 1076 S dropbear -p 22 -j -k
467 test 1172 S /bin/eapd
469 test 6216 S wpsaide
471 test 1652 S nas
472 test 1260 S /usr/sbin/acsd
476 nobody 1208 S dnsmasq --log-async
481 test 1976 S avahi-daemon: registering [RT-AC68U-7C28.local]
482 test 6712 S httpd -s -p 8443
484 test 1392 S crond
485 test 1144 S /usr/sbin/infosvr br0
487 test 6296 S watchdog
488 test 6216 S sw_devled
492 test 1372 S rstats
494 test 6216 S ots
502 test 1188 S lld2d br0
505 test 1300 S networkmap --bootwait
507 test 6216 S bwdpi_check
527 test 1380 S /sbin/zcip -p /var/run/zcip0.pid vlan6 /tmp/zcip
540 test 1388 S /usr/sbin/pppd file /tmp/ppp/options.wan0
542 test 688 S /usr/sbin/igmpproxy /tmp/igmpproxy.conf
627 test 0 SW [khubd]
739 test 6216 S usbled
740 test 2192 S u2ec
741 test 1216 S lpd
743 test 2192 S u2ec
744 test 2192 S u2ec
799 test 1396 S /sbin/udhcpc -i vlan3 -p /var/run/udhcpc11.pid -s /tmp /udhcpc -O33 -O249
824 test 6216 S ntp
976 test 4024 S /etc/openvpn/vpnserver1 --cd /etc/openvpn/server1 --co nfig config.ovpn
991 test 6216 S disk_monitor
1010 test 2008 S wred -B
1011 test 2008 S wred -B
1012 test 2008 S wred -B
1013 test 2008 S wred -B
1014 test 2008 S wred -B
1015 test 2008 S wred -B
1016 test 2008 S wred -B
1017 test 2008 S wred -B
1018 test 2008 S wred -B
1019 test 2008 S wred -B
1020 test 2008 S wred -B
1050 test 3608 S data_colld -i 1800 -p 43200 -b -w /tmp/bwdpi/dc/
1053 test 3608 S data_colld -i 1800 -p 43200 -b -w /tmp/bwdpi/dc/
1054 test 3608 S data_colld -i 1800 -p 43200 -b -w /tmp/bwdpi/dc/
1055 test 3608 S data_colld -i 1800 -p 43200 -b -w /tmp/bwdpi/dc/
1056 test 3608 S data_colld -i 1800 -p 43200 -b -w /tmp/bwdpi/dc/
1057 test 3608 S data_colld -i 1800 -p 43200 -b -w /tmp/bwdpi/dc/
1070 test 6216 S bwdpi_wred_alive
1072 test 3608 S data_colld -i 1800 -p 43200 -b -w /tmp/bwdpi/dc/
1304 test 1144 S dropbear -p 22 -j -k
1342 test 1392 S -sh
1347 test 1384 R ps w
Hi RMerlin:
When the username is configured as "admin" 17 routes are loaded into routing table. If other user is used, only 7 and that´s the reason of wired behaviour when using IPTV.
probably yes but:
flash another fw like stock and/or tomato to test.
try another power adapter.
use another wall outlet for power, preferably on another phase.
test router at another location other than yours.
try another router, any will do, to test out ur current modem/wiring/internet connection.
without troubleshooting sometimes the best assumptions could be wrong
actually, I found the strangest phenomena ever.
It seems my speakers are starting to affect my router.
They did not affect them before.
Perhaps the "shield" of the speakers are damaged now?
Because when I turn on the speaker.. the loss of data and general sluggyness starts.
Once I turn off the speakers.. everything goes back to work at 100% 1 minute after.
Are they Bluetooth?
Try plugging them in a different power bar in case the issue is electrical,.
nope, normal cables. Its a logitech Z906 system.
And what do you mean with " a different power bar" ?
Everything is plugged to the same outlet (under 2 UPS units of 1500VA each one)
Right now I have separated my speakers a bit from the network cables and the Arris router.
So far the connection seems fine and stable.
The most recent beta has been working great on my RT-AC68U until yesterday when everything slowed down, I logged in to the GUI and found that Core 2 was stuck at 100%
Today the slow down started again however the cpu's were both under 10% ?
Any idea whats causing this or how I can diagnose this?
CPU: 0.2% usr 0.1% sys 0.0% nic 99.4% idle 0.0% io 0.0% irq 0.0% sirq
Load average: 0.01 0.05 0.05 1/102 10150
I can't think of any logical explanation as to how a different username could impact what routes get applied to the router, sorry. And I don't have IPTV to test anything either.
All your process do run under the correct userid as far as I can tell.
I need to check but seems that Asus has fixed this in GPL 380.1842. Do you plan to merge to this GPL on 380.58 final or once in beta no more Asus code updates until next release?
There's no GPL available for 1842. The only newer GPL I have is 2345, and it's beta and contains too many changes over 1354, so I don't want to merge it in the 380.58 release.
I backported the newer udpxy from 2345, so give the Beta 1 release a try.
ASUS RT-AC68U Firmware version 3.0.0.4.380.1842
Bug fixes
- Fixed Multicast issue when WAN is PPPoE/ PPTP/ L2TP
- Fixed IPTV GUI issue
- Fixed two guest networks had same mac address problem.
- Fixed view list in network map cannot be closed.
- Fixed network map device icon issue
- Fixed client cannot get new IP when changed router IP and subnet mask.
- Fixed wrong notification when using quick internet setup wizard in static IP environment.
- Fixed wrong notification when client was blocked by Time scheduling.
- Fixed ASUS Router App related issues.
- Fixed DNS response error issue.
- Fixed abnormal LED blinking issue when enabled IPTV.
- Fixed client list name cannot be changed issue.
Thread starter | Title | Forum | Replies | Date |
Wireguard benchmark test on RT-BE96U | Asuswrt-Merlin | 52 | |
Z | Speed Test Discrepancy | Asuswrt-Merlin | 5 |
Welcome To SNBForums
