vpnmgr vpnmgr - Manage and update VPN Client configurations for NordVPN and PIA
Which VPN provider do you use?
  • Total voters
    315
This brings to mind something I've been wondering about. Your configuration options are slightly different than what NordVPN has listed on their How-To. Was there something you discovered along the way that made you decide to add the additional options? I'm hoping to get a better understanding of what it all means.
remote-cert-tls server
remote-random
nobind
tun-mtu 1500
tun-mtu-extra 32
mssfix 1450
persist-key
persist-tun
ping-timer-rem
reneg-sec 0
#log /tmp/vpn.log
remote-random
resolv-retry infinite
ping 15
ping-restart 0
ping-timer-rem
persist-key
persist-tun
reneg-sec 0
fast-io
disable-occ
mute-replay-warnings
auth-nocache
sndbuf 524288
rcvbuf 524288
push "sndbuf 524288"
push "rcvbuf 524288"
pull-filter ignore "auth-token"
pull-filter ignore "ifconfig-ipv6"
pull-filter ignore "route-ipv6"
tun-mtu 1500
tun-mtu-extra 32
mssfix 1450
Just wondering can I add this custom config in replace the one that nordvpn uses in their setup without using your vpnmgr ?
Yes... just drop it into your clients' custom configuration window, and it'll utilize whatever you have in there. ;)
Thanks can I remove the one there and replace it with the said script? or just add it the one there?
No prob! You would just replace it... this is what I have in all of mine:
remote-random
ping 15
ping-restart 0
ping-timer-rem
persist-key
persist-tun
reneg-sec 0
fast-io
disable-occ
auth-nocache
sndbuf 524288
rcvbuf 524288
explicit-exit-notify 3
tun-mtu 1500
tun-mtu-extra 32
mssfix 1450
remote-random
ping 15
ping-restart 0
ping-timer-rem
persist-key
persist-tun
reneg-sec 0
fast-io
disable-occ
auth-nocache
sndbuf 524288
rcvbuf 524288
tun-mtu 1500
tun-mtu-extra 32
mssfix 1450
Thanks which router are you using? I have the AC86u
This actually brings up a good point that I've been wondering about, and have not been able to find much supporting documentation about this. @Jack Yaz, what exactly does the function "Use vpnmgr custom settings" do? I'm not sure what options there are for this, or what exactly its purpose is? l looked at your code, and it seems to refer to /jffs/addons/custom_settings.txt? I'm unfortunately not versed enough to decipher how it should be used. Lol.
Does it have any effect leaving it on or off? Thanks!
Same here... Here's a good tip - throw info like this into your signature line, and we'll all know what you have to work with. :)
Sorry not sure what signature line is
No prob... at the top right of your screen, click on your username/icon... it'll drop down, and one of the items in there is labeled "signature". Hit that, and you will have the ability to add a short tag to each of your posts. It's definitely helpful to include your router model/firmware version you're running, and optionally, any addons you might be using.
Thanks a lot for your help.
it overwrites anything you put in custom configuration of the vpn client with settings i've found to work best, like send buffer etc.
Great to know... I believe I was already using your custom settings by default, which is probably why I didn't see much of a difference. ;) Thank you!
The vpnmgr page also doesn't load.
What am I doing wrong? How can I fix this?
I just changed to the RT-AX86U and have this exact same problem. The CLI works, but the GUI doesn't have any options. Is there something I can try to fix the Web GUI?
Just wanted to run down a list of things to try, or you may have already tried?
1.) Reboot?
2.) Delete/refresh your browser cache?
3.) Uninstall/reinstall vpnmgr?
Check for errors in the browser Console (f12) please
1.) Reboot?
Yes.
Yes.
Not an uninstall, but I did switch back and forth from stable to develop and then back to stable.
i wonder if wevpn have changed the download location
can you try option r at the CLI SSH and see if that errors?
It takes longer than Nord and PIA, but this is the ultimate result:
Mine is pretty much instantaneous going from "No changes in WeVPN OpenVPN file archives" to the "Press enter to continue".
Can you make sure you're able to reach these URLs/files?
https://wevpn.com/resources/openvpn/UDP.zip
https://wevpn.com/resources/openvpn/TCP.zip
