Martineau
Part of the Furniture
Yes indeed that's correct ...
So now you know why you don't see the new GUI option.
![Stick Out Tongue :p :p](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f61b.png)
All steps run again, no change.
https://github.com/kvic-z/goodies-asuswrt/wiki/Install-NTP-Daemon-for-Asuswrt-Merlin
service stop_httpd
umount /www
service restart_httpd
I uninstalled, then reinstalled FireFox, and I am now able to reach my 88 without issues.
This just happened again so I suppose that I'll have to roll back to 380.66_4.I just checked on my router and found that core 1 was pegged at 100%. I tried rebooting but that didn't help so I had to completely power off for a few and when it came back up it was running normally. This is the first time this has happened and I will keep an eye on it. If it happens again I'm going to roll back.
I see the same disk monitor sigalarm message on mine, however, I do have a usb laptop cooler plugged into it. I was using the usb 2 port on the back but after core 1 started sticking at 100% I moved it to the usb 3 port on the front to see if the behavior changed.my log just after resseting when connected to TP-LINK Archer T9E
Jun 7 17:53:17 rc_service: ntp 1208:notify_rc restart_upnp
Jun 7 17:53:17 ddns update: Asus update entry:: return: HTTP/1.1 200 OK^M Date: Wed, 07 Jun 2017 14:53:14 GMT^M Server: Apache^M X-Powered-By: PHP/5.6.30^M Content-Length: 0^M Connection: close^M Content-Type: text/html; charset=UTF-8^M ^M
Jun 7 17:53:17 ddns update: retval= 0, ddns_return_code (,200)
Jun 7 17:53:17 ddns update: asusddns_update: 0
Jun 7 17:53:18 rc_service: ntp 1208:notify_rc restart_diskmon
Jun 7 17:53:18 disk_monitor: Finish
Jun 7 17:53:19 ddns: ddns update ok
Jun 7 17:53:19 disk monitor: be idle
Jun 7 17:53:21 kernel: * Make sure sizeof(struct sw_struct)=160 is consistent
Jun 7 17:53:21 dhcp6 client: bound address 2a02:2f0a:700f:ffff::50c:c4cd/128, prefix 2a02:2f0a:7000:4a6::/64
Jun 7 17:53:22 kernel: sizeof forward param = 160
Jun 7 17:53:22 qtn: bootcfg.tgz exists
Jun 7 17:53:23 crond[490]: time disparity of 974332 minutes detected
Jun 7 17:53:23 rc_service: zcip 1258:notify_rc start_firewall
Jun 7 17:53:23 zcip client: configured 169.254.128.220
Jun 7 17:53:24 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
Jun 7 17:53:25 rc_service: ip-up 1030:notify_rc start_firewall
Jun 7 17:53:25 rc_service: waitting "start_firewall" via ...
Jun 7 17:53:27 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
Jun 7 18:00:19 disk_monitor: Got SIGALRM...
Any ideas why/what to do?
Everytime I start the desktop, the ASUS resets itself and it happens every single time. I uninstalled the drivers for TP-LINK and installed the latest one but useless. Usually it connects on 5 GHZ so maybe that is why.... Let me know if u need anything elseI don't see anything abnormal in this log. What's the problem?
I have a USB cooler pluged in and a swap of 256 MB
Welcome To SNBForums
