Hi.
Is ASUS RT-AC5300 Firmware version 3.0.0.4.380.7743 part of current Alpha-2?
No offence...thought you maybe had received a prerelease.....7743 came out less than 12 hours ago, and alpha 2 was compiled well over a week ago...
Thanks for a quick reply.
@RMerlin I thought Asus was supposed to do a big redesign release for AsusWRT or am I mistaken?
Off topic but 7743 works very good. I think Asus is heading in the right direction.![]()
Already one user saying the complete opposite.
<shrug>
Is what it is - like I mentioned in another thread - moving walkway is nearing it's end...
Asus seems to be going in a certain direction....
I updated to alpha2 (later june version) on the RT-AC3200 yesterday just before enabling dual WAN (ISP outage, so I configured my old ISP which isn't yet canceled).
Once the ISP fixed service the router correctly flipped back to primary and speedtests, pings etc - all normal yesterday evening.
This morning a speedtest showed high latency (150ms ish) and around 30-50 Mbps instead of 220 Mbps over Ethernet. This was from 2 separate machines.
Yet on wifi I was still getting the full 220 Mbps (my initial thought was ISP fault again).
The router didn't show anything abnormal I could see in syslog, nor was cPU high (2-4%), but I rebooted the router (I didn't touch either the cable or vdsl modems)
Following this a quick few mins on secondary (I set along timeout for failback),m back on primary, and Ethernet speedtests were fine.
Very odd. Not sure I can think what could cause that which could relate to the alpha firmware but thought I'd mention it. I'll keep an eye out for any reoccurance
Don't know if I am doing something wrong, but I can't use the Samba Server with an USB 3.0 32GB Stick.
Its formated with GPT ext2. Trying to push a 2GB ISO file onto the stick from my PC with 5GHz WLAN but the transfare rate never goes over 1MB/s oO (speedtest shows 120Mb/s down and up 6Mb/s is possible)
The USB 3.0 WLAN thing is activated. CPUs are not in use. RAM is fine too.
/dev/sda1 ext2 28.5G 173.1M 26.9G 1% /tmp/mnt/router_usb
Any hint?
EDIT: Reformatting the stick with MBR and ext2 at the moment, perhaps that was the reason.
EDIT2: Did not fix the problem. But I found another one: When you check your usb device for errors over the gui, there is no result displayed after the check has finished. You have to refresh the site.
EDIT3: Same on USB2
EDIT4: Rebooted my pc, tried it again: Starts with about 30MB/s and goes down in some seconds to 0. GUI tells me CPU1 100%, CPU0 does nothing, RAM 50%, but top shows CPU: 0.2% usr 0.8% sys 0.0% nic 0.0% idle 98.6% io 0.0% irq 0.1% sirq
EDIT5: With small files, it seems to work, but I can't even push a 400MB ZIP file on it..
Welcome To SNBForums
