[Alpha] Preview builds for Asuswrt-Merlin 380.61
No problem here. Make sure to choose yes on "Create or reset data files" in Tools --> Other Settings.
Reset data did clear the log entries but still no data saved after 2+hours.
Will try factory reset later. Thanks!
(ac66u)
@RMerlin Does it require a hard reset coming from 380.60 B2 build? Thanks
I can't seem to disable b/g protection it the 2.4GHz wireless settings
Apparently thats an ASUS issue. The stock version is the same way.
Page: Internet status.
There is an option to change (set, increase) lease time? Or it is fixed to 1 hour?
(If it exists sorry, but I can not find it)
Thank You
The area shown in your image is the lease time that your ISP is granting you... They run the DHCP server, so they dictate the lease times (and so there's no way for you to change it.)
Typically, a DHCP client (your router) will attempt to renew a DHCP lease when it's time is 1/2 expired. So, in your image, the router will likely attempt to renew the lease when it gets to a "lease expires" in "30 minutes."
Can't find any link for 380.61 Alpha for AC5300. Anybody help...Can only find links to AC66 and AC68
Read the first post carefully and you will find your answer.
OK. Thanks. I thought so, but I wanted to be sure. I guess it is the same reason that 3831 is not to be found on the ASUS page either.
Updated from 380.58 to 380.60B2 for the time being....WiFi keeps dropping on some of our Childrens devices.
Both ac68u and n66u running fine nothing exciting to report.
Neither hasn't as yet gained independent thought and joined dancing with the stars.
RT-AC68U owners, any of you used to be on 380.60 beta, and used to have WAN-related issues? Are these fixed so far in 380.61 alpha 1 ?
I ll give it a try this this week-end(will flash it when back from job).I am one of those with this problem.
I haven't since it's been installed on the 19th; however, I did have a power outage one night where I had to power cycle both the cable modem and router to get the internet working again so lot in the logs from that crap where it couldn't ntp sync for over 8 hours, etc.
Since this happened on the 20th I've not got any messages; although, my internet has been sluggish a few times since then but that might have been ISP issues. Nothing in the logs that corresponded with it. So.. yeah.
When it went sluggish last time, here's what PingPlotter did:
My AC-66R is dependable as always, 20 minutes after the upgrade to 380.61_alpha1. Running as an AP only, with both Wl0 and Wl1 enabled.
Model RT-AC66R
Firmware Version 380.61_alpha1-g5e5f250
Firmware Build Wed Jul 20 04:38:07 UTC 2016 merlin@5e5f250
Bootloader (CFE) 1.0.1.4
Driver version wl0: Mar 24 2016 10:28:30 version 6.30.163.2002 (r382208)
Uptime 0 days 0 hours 17 minute(s) 21 seconds
Temperatures 2.4 GHz: 52°C - 5 GHz: 59°C
CPU Model Broadcom BCM5300 chip rev 1
CPU Frequency 600 MHz
CPU Load Average (1, 5, 15 mins) 0.04, 0.13, 0.08
Total 233.92 MB
Free 188.19 MB
Buffers 5.44 MB
Cache 15.32 MB
Swap usage 0.00 / 0.00 MB
NVRAM usage 49375 / 65536 bytes
JFFS 1.18 / 32.00 MB
EDIT: As other have reported, B/G Protection is forced-on with 2.4. Normally I keep this off since I'm using N-band only on 2.4, so I can't be sure if B/G protection is actually on since I have B/G bands turned-off.
